Author Topic: 'Nother Hoss for da Farm  (Read 8475 times)
Offline EOTE
  • I don't suffer from insanity-I enjoy every minute.
    • Weather at EOTE
Re: 'Nother Hoss for da Farm
« Reply #140 on: July 06, 2020, 11:35:35 PM »
Da hoss musta thrown a shoe.
I got into some thorny Mock Orange and I reckon that some got into my tire.  That tire was old anyway so it is getting shod.  $122 + +.  :-X
Put water in both rear tires for ballast.  It won't hurt the tires.  It will definitely help with traction
EOTE (End of the Earth - i.e. last place on the road in the middle of nowhere)  Retired.  Old guys rule!
Buzz Lightsaw, 12 Mexicans, and lots of Guy Toys
Offline Tacotodd
  • To learn and help
« Reply #141 on: July 07, 2020, 12:54:03 AM »
OR...or use some of the stuff called liquid tube. OTR truckers are known for using it quite often. Its white in color and prevents rust, unlike slime. It works well. Ive even used it in my trail buggy (truck) tires and never had a flat on anything except for the time that I had a very tight obstacle that put 5 large 4+ gashes in the sidewall. Nothing that you could do that time. I have even run it at 60mph without balance weights, and 1gal in each tire. BTW, the tire size, 35x12.50x15. Not cheap, but not the end of the world. I dont play like that anymore. Cant afford it, now that Im married and WE have a house!
Trying harder everyday.
Offline Tacotodd
  • To learn and help
« Reply #142 on: July 07, 2020, 01:03:52 AM »
And these tires were just over $200 each 15yrs ago. My, how time flies. Like several of my USMC buddies and Dad (was also USMC) said, would never do it again, but wouldnt trade it for anything.
And I didnt even coax those comments from any of them.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #143 on: July 07, 2020, 07:55:58 AM »
No loaded tires for me.....too many thorns.  Yes it helps with balance, traction, and smooths out the ride, but a flat is a killer.  Been there, done that, and have the T shirt.  :-X
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #144 on: July 07, 2020, 10:00:39 AM »
The loader tire I put Amerseal in late last fall hasn't needed air since 8)  http://www.amerseal.com/
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #145 on: July 07, 2020, 10:08:06 AM »
I got serious tractor envy!
I've had a few tractors, none newer than 1954 vintage.
I hope to some day soon have a very modern Kubota myself.
Jon
Imagine, Me a Tree Farmer.
Offline EOTE
    • Weather at EOTE
« Reply #146 on: July 07, 2020, 11:22:23 AM »
Jon
I did it with the Kubota financing plan - 0% down, 0% interest.  Sell off your old tractors and pay down the balance. :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #147 on: July 07, 2020, 11:50:56 AM »
This tire was old, badly cracked, and had a tube in it.  I will go back tubeless so I can use Strings to make repairs as needed.
Offline EOTE
    • Weather at EOTE
« Reply #148 on: July 07, 2020, 01:14:56 PM »
I've been using those on my truck and trailer tires for years.  You can repair tires that the tire shops won't touch (fear of liability).  However, on my tractor I use industrial brown goop in the front tires and water for ballast in the rear tires.  Having worked as an ag mechanic for 10 years, we rarely saw any large tire punctures unless the tire was old and cracking.  In Montana they added calcium chloride to the tires to prevent freezing.  It is still easy to repair tires with the strings that have water in them, but you have to rotate the puncture to the top of the tire and allow the air pressure to normalize before repairing.  Use the reamer to open up the tire puncture and help normalize the air pressure before inserting the string.  Works like a charm.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #149 on: July 10, 2020, 09:07:25 PM »
New front tire and we were back at the farm today doing some welding on the broken disc.
Lift the disc frame up and off of the disc assembly.
Grind and bevel the broken weld.
That should hold.
And the disc is back together and ready for this Fall's Food Plot planting. Thank You Kubota FEL.
The spraying that I did Monday looked like 100% success!!  ;D
Offline Walnut Beast
« Reply #150 on: July 10, 2020, 11:35:35 PM »
Looking good Magicman. Keep them big bucks growing. What are you planting for the food plot
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #151 on: July 11, 2020, 07:44:11 AM »
Oats and Wheat.  I have many volunteer grasses such as Fescue, but the plots give them something special.  I wish that I would have had time yesterday to take a picture of the spraying success.
Offline Bruno of NH
« Reply #152 on: July 12, 2020, 01:03:30 PM »
I know this is not a tractor question.
Big Bob is my first skid steer.
Can you load tires on them?
Is there a benefit to doing it.
I have had 3 tractor and have had the rear tires loaded in all of them.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline EOTE
    • Weather at EOTE
« Reply #153 on: July 12, 2020, 10:30:20 PM »
Ballast in rear tractor tires is generally to offset the loader and move the CG rearward and allow the rear tires to have more traction.
Adding ballast to the tires on a skidsteer will put more weight (traction) to the ground and will also compact the ground more.  Usually as small as skidsteer tires are you are not going to get more than 5 to 10 gallons max per tire so at 10 gallons that would be approximately 75 pounds per tire.
The way skidsteers are configured I am not sure if there is a benefit.  Usually the weight pivot point is the front tires so ballast in them would be neutral.  Skidsteers are generally designed for balanced load and traction.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #154 on: July 19, 2020, 08:31:16 AM »
Da hoss got another workout yesterday along with it's brother John.
But first John got outfitted with PAT's quick hitches.  I have a Speeco quick hitch but I believe that this will give me more flexibility.
I am/was needing more White Oak for bridge decking so this tree shown in the center would be the donor.
27" butt.
It gets measured, marked, and trimmed.
The 18' butt log and a 12'.
The top logs.
John is hooked up.
And I am ready to make the mile skid with this 18',  27" butt and 22" top log.
Marty and John will skid these two 12' top logs.  We will come back and make the final mile long skid with the other 12' logs.
Making the first skid.
The logs are skidded, staged, and ready for the sawmill.  It was very hot  smiley_sweat_drop smiley_sun  but it also was a very productive and rewarding afternoon.
Offline Bruno of NH
« Reply #155 on: July 19, 2020, 12:01:00 PM »
Nice family workout .
Hot here in NH to.
95 to 100
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #156 on: July 20, 2020, 07:30:03 PM »
Marty added another "Hoss" to his stable.
This is the first purchase of his new "start up" construction company.  Not new but it should serve him well.  It is an F350, e/w a 6.7 Diesel.
Offline Bruno of NH
« Reply #157 on: July 20, 2020, 08:09:03 PM »
That Henry will get the job done.
Good luck Marty with your business venture.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #158 on: August 06, 2020, 09:07:03 PM »
Marty added another "Hoss" today to his stable.
It is a Kubota U25 for his new "start-up" construction company.
And it met my Kubota M4900 for the first time this morning.  "Hi there, nice to meet you".  :)
Tomorrow Marty and Ben are traveling to the Dallas, TX area to pick up his second work truck; a 2013, F250 e/w a 6.7 Diesel.  It will join the F350 pictured in Reply #156 above.
Offline Southside
    • White Oak Meadows
« Reply #159 on: August 06, 2020, 09:26:00 PM »
Very nice addition!!  Once you have a track-hoe around you wonder how you ever got along without it.
White Oak Meadows
Horse and a Hoss
Last post October 02, 2003, 08:37:30 PM
by Jeff
The One Hoss Shay
Started by Don P on General Board
Last post November 20, 2007, 09:36:32 PM
by Don P
old farm trash dump is actually a Farm Pond - clean up help
Started by kwendt on Ask The Forester
Last post January 10, 2015, 12:35:33 PM
by kwendt
angry
'Nother New Laptop
Started by Magicman on Technical Support Topics
Last post December 01, 2018, 04:54:23 PM
by Magicman
