Author Topic: 'Nother Hoss for da Farm  (Read 11948 times)
Online Southside
    • White Oak Meadows
Re: 'Nother Hoss for da Farm
« Reply #20 on: September 17, 2019, 09:56:37 PM »
Quick attach is a different story. Pretty much a must-have. Wish I had one, but nothing to fit my loader.
There is a shop in Richmond that will make them for anything - among other places they advertise on CL in the heavy equipment section, they fabricate lots of skid steer attachments.
White Oak Meadows
Online btulloh
« Reply #21 on: September 17, 2019, 10:07:45 PM »
Good info. Iíll check them out and get a quote. Thanks.
HM126
Offline pineywoods
« Reply #22 on: September 18, 2019, 10:19:24 AM »
MM when you see the need for aux hydraulic outlets, I can show you how to add them without breaking the bank. I added 2 more on mine to run a logging winch and hydraulic top link..
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #23 on: September 18, 2019, 09:21:13 PM »
Thanks.  For now she is sleeping alone 'cause I have got to catch up on my sawing after getting out of the "sand box".  ;D
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #24 on: September 19, 2019, 05:58:19 PM »
Happy for you MM 🚜🚜🚜
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: September 21, 2019, 05:58:41 PM »
I installed the "Pat's Easy Change System" today.  This is a quality setup and I'm gonna order one for the old John Deere.  I will also still use the Quick Hitch with the Bushhog, grader blade, & subsoiler but this "Easy Change"will make installing the Quick Hitch much easier for me.
PatD took her first look at "Big O" today and I think she approved.  :)
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #26 on: September 21, 2019, 08:23:41 PM »
   Now you will never get it back. smiley_hairbow smiley_gorgeous
Online btulloh
« Reply #27 on: September 21, 2019, 08:25:45 PM »
Donít let her park this one in the shade.
HM126
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #28 on: September 22, 2019, 05:58:10 PM »
I think you will like the new tractor.  The FEL and the 4wd are a game changer compared to a 2wd farm tractor.  I could not tell if you have the skid steer hook up for the FEL but if you don't it is a relatively inexpensive modification that will enable you to go from grapple to forks to bucket in a minute or so - much quicker than driving out pins.
Caveman
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #29 on: September 22, 2019, 06:16:53 PM »
It's the older Bushhog style system with spring loaded pins.  At this time a grapple is not in my plans so it will have to stay as is.  $$
I replaced the rotten shift boot so the tractor hydraulic fluid is contaminated.  :-X   I probably would have replaced it anyway so tomorrow all fluids/filters get changed.  Yup, probably to the tune of $350.  :o
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #30 on: September 22, 2019, 08:39:13 PM »
Money well spent on that. I did that with the JD and Cat. Know what you have that way.  smiley_thumbsup
Even the hot rod  ;D
A&P saw Mill LLC.
License NH softwood grader.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #31 on: September 23, 2019, 07:36:22 PM »
Big O said that she was happy.  ;D  Me, a bit lighter in the butt log.  :-X
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #32 on: September 24, 2019, 07:46:00 AM »
Kubota is very proud of it's oil.
The First 60 some years of childhood is always the hardest.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #33 on: September 24, 2019, 08:00:00 AM »
Yup, and I don't know why I didn't just get some 303 from NAPA.  Probably all came out of the same tank.  ::)
A new saddle for da hoss will be delivered by UPS today and a new floor mat should be here soon.  Gotta find some rattle grey paint.
Offline samandothers
« Reply #34 on: September 24, 2019, 11:15:11 AM »
On the bright side if it had been hydrostatic it would have been about 12 gallons!  Good to do the fluids and filters so you have a 'clean' start.  Enjoy the new toy it will be a big difference with 4 wheel drive for traction and its increased lift ability.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #35 on: September 24, 2019, 12:06:31 PM »
Be glad you didn't have to get the SUPER UDT, that stuff is liquid gold. ($$$ :o!)
Offline dirtmotor
« Reply #36 on: September 24, 2019, 12:39:33 PM »
Just changed hydro oil in my baby bota , yep the super was 103 dollars for 5 gallons they said gotta use it , I wonder ... You know the front  uses the same oil or 80 weight makes no sense to me .
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #37 on: September 24, 2019, 07:40:43 PM »
The new saddle came today so it got installed.  Also an "ammo box" which will be painted Orange and serve as a mini toolbox.  The new floor mat comes Friday.
I peeked in on a couple of Orange Forums today and read their responses regarding Kubota UTD tractor fluid.  There were arguments both ways and with some instances where dealers regularly use non-Kubota UTD.  My opinion is that with non-hydrostat setups it would be OK.  Of course there is a valid argument that since the fluid is only changed every 600 hours, bit the bullet.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #38 on: September 24, 2019, 09:14:31 PM »
TSC/Traveller Premium, meets Super UDT specs. $42/pail. I've put many pails  through my Kubota  L48 with no problems. I buy only Kubota filters, however.
Online Southside
    • White Oak Meadows
« Reply #39 on: September 24, 2019, 10:44:44 PM »
I run the TSC 303 in my old iron, buy a pallet of it every couple of years on Black Friday at $17 or so a pail, it has never caused me a problem, but I would not run it in something late model like your Bota there.  The new pumps have a lot tighter tolerances, more bushings, etc. and require the additives in the expensive formulas to last the test of time.  Of course if you are switching implements between tractors and they have hydro lines then you will have a contamination issue there due to the spit swapping.
White Oak Meadows
Horse and a Hoss
Last post October 02, 2003, 08:37:30 PM
by Jeff
The One Hoss Shay
Started by Don P on General Board
Last post November 20, 2007, 09:36:32 PM
by Don P
old farm trash dump is actually a Farm Pond - clean up help
Started by kwendt on Ask The Forester
Last post January 10, 2015, 12:35:33 PM
by kwendt
'nother WM success..
Started by zopi on Sawmills and Milling
Last post April 15, 2008, 07:56:23 PM
by zopi
