Dynamic Green Products Inc.
Author Topic: building a round walnut table  (Read 4872 times)
Offline tule peak timber
  • roborob
    • tule peak timber
Re: building a round walnut table
« Reply #40 on: October 01, 2019, 07:48:46 PM »
Love your pup pics......
    The old redwood pattern is 7 5/16 face with 70 degree +- edge relief. Clear heartwood. More pics of the pizza tomorrow.
  • roborob
    • tule peak timber
« Reply #41 on: October 03, 2019, 07:43:45 PM »
The last piece of walnut pizza set tonight. Delicious :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #42 on: October 03, 2019, 08:06:50 PM »
Oh that is making my eyes hurt!!!   :o
Offline DWyatt
« Reply #43 on: October 04, 2019, 06:30:33 AM »
The precision to cut all of those pieces knowing you would not tolerate gaps is incredible. Something that is very rare in woodworking. That looks fantastic.
  • roborob
    • tule peak timber
« Reply #44 on: October 04, 2019, 09:37:33 AM »
DWyatt, Thanks. I did get a small gap between the first two boards and quickly figured out a "fix" by double cutting all subsequent boards for really tight joints. This is one time where clamps don't help---the boards either fit, or they don't. Each board was developed from a 6/4 blank and  immediately glued in, one at a time. This process took all week to fill in the field.
  Equally challenging was getting all the needle like tips to converge on a single point, again not perfect, but close.  Cheers Rob
  • roborob
    • tule peak timber
« Reply #45 on: October 05, 2019, 06:33:18 PM »
Router the edge and the start of sanding today.
Offline samandothers
« Reply #46 on: October 05, 2019, 06:40:26 PM »
Kinda looks like a big mushroom cap.
The book matched pieces give it a nice look! It's a biggun.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #47 on: October 06, 2019, 09:51:32 AM »
Sand, sand, sand, and then sand some more :).
Looks fantastic.
  • roborob
    • tule peak timber
« Reply #48 on: October 09, 2019, 05:03:12 PM »
After days of sanding,,,, a one piece 3 inch thick top today. The grain is starting to pop with the seal coat.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #49 on: October 09, 2019, 06:41:18 PM »
Catching up on reading, yust got in from 'analog land': nuthin digital out in the boonies.
That table looks GREAT!
Book matched pizza slices, and a base underneath that has the strength of an anvil.
I wouldn't want you to reveal any super secret trade tricks, but is a Festool track saw the best way to get those air tight joints?
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
  • roborob
    • tule peak timber
« Reply #50 on: October 09, 2019, 07:03:50 PM »
Andries, for the "air tight" joints I resaw, plane , sand, cut and glue immediately-one set at a time.I use a sliding table saw to cut the shape, than 1/4 of a blade width and a fence to "double cut " a small fraction off each face easing it against the fence until I get zero clearance. I then go immediately to glue with very little or no clamping.
 When I started the walnut pie shapes I noticed a hairline gap between number 2 and 3 and quickly went to "double cutting" which solved the problem. If you can see the joint, I call it a bad joint !  Cheers Rob
  • roborob
    • tule peak timber
« Reply #51 on: October 10, 2019, 02:16:13 PM »
Routing the back bevel this morning.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #52 on: October 10, 2019, 03:10:25 PM »
You are working and I am watching enjoying;D
Offline Southside
    • White Oak Meadows
« Reply #53 on: October 10, 2019, 04:17:24 PM »
Good golly!!  Do you have a "custom made two piece pool cue" too?   :D
  • roborob
    • tule peak timber
« Reply #54 on: October 10, 2019, 04:49:17 PM »
All halt........Smoked the router!
Offline doc henderson
« Reply #55 on: October 10, 2019, 04:52:22 PM »
I knew some folks in CA smoked some weird stuff, but never heard of routers!!! :) :) :)
Offline Don P
    • Calculator Index
« Reply #56 on: October 10, 2019, 05:28:05 PM »
If you let the magic blue vape out its toast, if it just quit I've jumped around the soft start on my big porter cable and she fired back up and is still trucking, just hold on when you hit the go button.
  • roborob
    • tule peak timber
« Reply #57 on: October 10, 2019, 05:53:44 PM »
No blue tape on this guy. A bearing went and the stater and rotor collided----smoke literally :D
  • roborob
    • tule peak timber
« Reply #58 on: October 11, 2019, 03:11:12 PM »
Edge done and coloration applied. I'm working on the geometry for the base in another room.
Offline Nebraska
« Reply #59 on: October 11, 2019, 04:15:35 PM »
Thank you, enjoying the thread.
Building a Walnut Table
Started by WDH on General Woodworking
Last post December 23, 2008, 04:43:55 PM
by metalspinner
Help for 7ft round table
Started by CGIII on General Woodworking
Last post September 30, 2019, 07:48:53 AM
by cbla
question
colonial style round table
Started by Polly on General Woodworking
Last post June 09, 2013, 05:08:58 PM
by Jay C. White Cloud
round table cut on my table saw
Started by yukon cornelius on General Woodworking
Last post December 03, 2015, 06:53:58 PM
by kettlekorn
