Author Topic: Breez wood ban mill  (Read 382 times)
Offline Alaskabob
Breez wood ban mill
« on: September 19, 2019, 11:23:42 AM »
need to replace the brass bushings on slides, any one know were i can buy them
Offline 47sawdust
Re: Breez wood ban mill
« Reply #1 on: September 19, 2019, 04:59:47 PM »
Might have to get them custom made by a machine shop.Breezewood is long gone.
Mick
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #2 on: September 19, 2019, 05:03:12 PM »
The only info I could find :
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline 47sawdust
« Reply #3 on: September 19, 2019, 05:40:01 PM »
Forum member BradS used to own a Breezewood many years ago.You might contact him directly to see if he can help.
If you type that forum name into the search box it should take you to his profile and contact info.
Mick
Offline luap
  • Not as good as I once was
« Reply #4 on: September 19, 2019, 06:06:33 PM »
Mc Master Carr sells generic size brass bushings.
Offline Brian_Rhoad
« Reply #5 on: September 19, 2019, 09:42:45 PM »
I have a Breezewood mill. I got my bushings from MSC Tool. I'm not sure on the size. I think they are 1 1/2" ID. I got longer than what came on the mill when new. They are soldered in from the factory. I drilled and tapped holes to use small allen head screws to hold them in the tube.
Here is a link to MSC. Check the size to be sure.
https://www.mscdirect.com/browse/tn/Motion-Control-Fluid-Power/Bearings/Sleeve-Bearings?navid=12104209#navid=12104209+4288233194
Best wood to mill?
Started by 50 Acre Jim on Sawmills and Milling
Last post July 27, 2017, 05:04:21 AM
by 50 Acre Jim
wood pellet mill
Started by wolverine on Firewood and Wood Heating
Last post January 07, 2009, 02:50:33 PM
by Brad_S.
Wood-fueled mill
Started by dboyt on Alternative methods and solutions
Last post June 06, 2007, 05:26:27 PM
by Larry
Standing mill wood...
Started by mrcaptainbob on Sawmills and Milling
Last post August 02, 2010, 07:40:58 PM
by Dave Shepard
