Author Topic: Problem with the Wide Head Turbo 7 Blade  (Read 942 times)
Offline moodnacreek
  • Sawin by the notches
Re: Problem with the Wide Head Turbo 7 Blade
« Reply #20 on: September 27, 2019, 08:13:35 PM »
Yeah, right, thought the problem was in N.H.   Eastern red cedar and frozen hemlock knots will chip carbide teeth, just an example of how these two share a sawing problem.  If you are sawing with chipped tooth corners [and heating the bands and cracking them] I would think you would not be able to saw straight enough to do this.
Offline millwright
« Reply #21 on: September 28, 2019, 03:36:40 PM »
I am surprised to see some of you only get 2-3 sharpenings , if I dont get at least 8 or more it is unusual . I am using a WM cbn wheel on a homemade sharpener and set every other time.
LT40 mill problem, chattering blade in wide cuts
Started by Kelvin on Sawmills and Milling
Last post March 07, 2009, 09:34:34 AM
by pineywoods
Turbo 747 Blade Question
Started by Tarheel on Sawmills and Milling
Last post December 13, 2019, 01:38:50 PM
by Tarheel
Somebody said you had a Wide head.......
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post March 25, 2019, 07:07:09 PM
by Percy
Blades for the new WoodMizer Wide Head
Started by DR_Buck on Sawmills and Milling
Last post September 29, 2018, 01:24:00 AM
by redbeard
