Author Topic: NEW WOOD-MIZER 7/47 BLADES (VIDEO)  (Read 1249 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: October 15, 2019, 12:04:48 PM »
Here is the video showing a few cuts being made with the new Wood-Mizer 7/47 blades.
I am running the 7/47 1 1/4 blades @.055 thickness on a Diesel Woodmizer LT40 Wide head. Also to note I think after making a few cuts I could probably push them harder than I did. Also keep in mind if you are familiar with my videos I am not the fastest operator around, trying to run 3 to 4 cameras while sawing maxes out my span of control at the sawmill.  In conclusion these blades are sharp and cut perfectly at the speed I was running my 40.  The only remaining question is sharpness, I am heading out to finish up that red oak today and will do another video which hopefully will show how long the blade last before going dull.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline 123maxbars
Re: NEW WOOD-MIZER 7/47 BLADES (VIDEO)
« Reply #1 on: October 15, 2019, 12:16:28 PM »
Also toward the end of the video is Tim Fuller trying out his new LX250 for the first time on some Pine/Oak and Walnut,
outofthewoods
Youtube page
Out of the
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: October 15, 2019, 12:57:46 PM »
   Nice vid. Thx for the tip on measuring off the top of the side supports.
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
« Reply #3 on: October 15, 2019, 08:38:44 PM »
@123maxbars what bands were you using before you tried the 7/47?
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Offline 123maxbars
« Reply #4 on: October 15, 2019, 10:06:00 PM »
7 degree double hard .055
outofthewoods
Youtube page
Out of the
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #5 on: October 15, 2019, 10:58:49 PM »
Thats a very useful video, good job.  The band certainly seems to leave a very nice finish and cuts at a good speed.  I guess Ill have to call WM and get a few to try out.  Thanks for the info.
HobbyHardwoodAlabama.com
Online Bruno of NH
« Reply #6 on: October 16, 2019, 10:04:36 AM »
I have 5 coming in on Friday
I will let all the 38hp gas folks know how they work for me.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Online Bruno of NH
« Reply #7 on: October 21, 2019, 02:08:11 PM »
FF member Mike Dillon came over today with some pine logs to big for his mill.
We slabed them both the second log I used a 747 band cut flat and fast.
Offline PAmizerman
    • Byrne Millwork
« Reply #8 on: October 21, 2019, 05:32:20 PM »
@Bruno of NH is there a noticeable difference between the 7/39 and 7/47?
WM bms250 sharpener
WM bmt250 setter
Online Bruno of NH
« Reply #9 on: October 21, 2019, 06:32:13 PM »
@PAmizerman Yes it cut faster without putting my engine on the governor.
Also flater as these are the first .055  I have run
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #10 on: November 25, 2019, 06:05:59 PM »
@Bruno of NH , i run the same 38hp gas, WIDE unit as you.
I put a new 747, .055 blade on today and I was completely satisfied.
I slabbed Post Oak, 9/4, 25" to 33" wide and they were dead flat.  Not even the slightest wave even going through the wide, crotch parts.
Used one blade on approx 650bf.......Mostly Post Oak, and a couple Water Oak and a SG.  I can't wait to try them on some WIDE Pecan logs.  That will be the test for me.
I've been running Turbo 7 and 4 in .045 and they are fine, BUT, I will be buying more 747's / .055.
Very Happy!
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Online Bruno of NH
« Reply #11 on: November 25, 2019, 06:39:45 PM »
I like the 747's
They will cut
I like the 38hp gas
Offline PAmizerman
    • Byrne Millwork
« Reply #12 on: November 26, 2019, 09:32:24 PM »
I'm liking the 7/47. Doing great.
Sawing hemlock. WM 1¼ .055 7/47 - YouTube
WM bms250 sharpener
WM bmt250 setter
Wood-mizer video
Started by Madman_Mark on Sawmills and Milling
Last post April 11, 2005, 05:30:23 PM
by ARKANSAWYER
ALL NEW Video Walkthroughs on Every Wood-Mizer Sawmill
Started by CWarner on Wood-Mizer
Last post April 30, 2018, 01:03:12 PM
by CWarner
Wood-Mizer blades
Started by Hi-Country Orange on For Sale
Last post November 28, 2008, 08:47:16 PM
MY Wood-Mizer L150 Kiln Build Video
Started by 123maxbars on Drying and Processing
Last post October 23, 2017, 03:44:00 PM
by 123maxbars
