Author Topic: Wood Mizer MP-260 Feed Question  (Read 380 times)
Offline Luke_Eames
    • Holland Timber Company
« on: October 17, 2019, 06:54:21 PM »
Hello Everyone,
Question on the MP260 and boards jamming up.  1 of 5 boards put through are jamming up on the teeth of the bed right after the bottom cutter.  It looks like the bottom cutter isn't taking off enough wood and the boards aren't lining up correctly to continue down the bed.  Is this just an issue with the bottom cutter knives not adjusted correctly or could it be some other issue?
Thanks!
Luke
Wood Mizer LT-70 Super Wide
Wood Mizer EG200
Cat IT18
Offline CHill8903
Re: Wood Mizer MP-260 Feed Question
« Reply #1 on: October 23, 2019, 10:29:14 PM »
Yes it is most likely your bottom knives  too low. I have a logosol ph260(same machine). The bottom knives should be set like a jointer, the top of the knife arc should be even with your out feed side. I use a straight edge inside the machine and feel for the knives to just graze the straight edge.
Offline Luke_Eames
« Reply #2 on: October 25, 2019, 08:26:12 PM »
Thanks for the reply!  We put a new set of bottom blades in, raised them up a bit and everything is working good now.  Thanks!
Wood Mizer EG200
Cat IT18
Wood Mizer Power feed LT35 and LT40 new design
Started by MartyParsons on Sawmills and Milling
Last post December 05, 2017, 12:11:12 AM
by MartyParsons
Wood Mizer single blade edger power feed
Started by Luke_Eames on Sawmills and Milling
Last post July 04, 2016, 11:42:06 AM
by Luke_Eames
Question for the Wood Mizer owners
Started by delvis on Sawmills and Milling
Last post October 04, 2014, 05:14:16 PM
by delvis
Wood-mizer lt40 question
Started by RedRebel on Sawmills and Milling
Last post July 12, 2020, 12:10:11 PM
by RedRebel
