Tally-I/O
Author Topic: Rotary Phase Converter for Logosol Planer/moulder  (Read 377 times)
Offline NorthJersey
« on: October 17, 2019, 11:46:10 PM »
What is "farm phase," and do you think this converter will do the trick for my Logosol PH260?
Offline Don P
    • Calculator Index
Re: Rotary Phase Converter for Logosol Planer/moulder
« Reply #1 on: October 18, 2019, 07:45:23 AM »
The farm phase is just a marketing term. I can't tell from the plate if it is a rotary or static, if it is on a rotary motor and within the specs needed for the logosol there is no reason it wouldn't work. Worth a call to the logosol folks.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: October 18, 2019, 08:35:41 AM »
There are several levels of output power accuracy, consistency, and noise levels in 3 phase converters, as well as the balance of the created phase leg to the other legs.  So a farm phase would be a less accurate version for non sensitive 3 phase equipment such as 3 phase air compressors, conveyors, lifts and other “farm” stuff.
More accurate and clean systems run equipment that requires greater consistency and balance, and generates a much higher quality 3 phase leg (called a “manufactured leg”) such as anything computer controlled, electronically controlled, or otherwise heavy with electronics, or with motors can’t take or won’t like poorer quality input power.
Personally, I recommend American Rotary equipment, they have a life time warranty, are very quiet, and they offer several different grades of equipment.  When I bought my 3  phase straight line rip saw, the only way the manufacturer would provide a warranty was if it was driven with an American Rotary ADX Series phase converter.  I have run American Rotary equipment for years and never had any problem on the SLR, our facer, and also our edger.  In addition, sizing a phase converter for your specific application is critical, and is also discussed on their website, or just give them a call.
Like anything else, you get what you pay for.
HobbyHardwoodAlabama.com
Offline Al_Smith
« Reply #3 on: October 19, 2019, 01:08:44 AM »
A rotary phase converter is just a three phase motor with a capacitor start system and balancing capacitors across the manufactured phase .In essence it's an induction generator .Properly designed they are around 92 percent efficient .
I've made about 20 of them myself ,it's not rocket science .You can find any info you need from the internet so I won't go into any theory about them only to say they work well .
My shop has a 5 HP converter using two single phase transformers to boost the 240 volt single phase to 480 volt and use that for 480 three phase .Then going through a three phase transformer to get 240 volt three phase . I have an old Walker-Turner drill press that has a single voltage 240 volt motor so the 240 three phase was necessary .
Generally speaking a rotary will start up to the same size as the converter .Meaning a 5 HP will start another 5 but will run up to around three times that amount .My 5 is running 6.5 HP at this time .Fact I've got a large enough start cap on the converter it will start the whole lot at one time which I found out strictly  by accident .
Offline Al_Smith
« Reply #4 on: October 21, 2019, 07:27:15 AM »
You have to keep in mind they also tout "solid state" converters .All those are is a start circuit with running capacitors across the "dummy " phase to keep from burning the winding out .Those are only about on a 56-58 percent efficiency though meaning about 5-6  HP from a 10 HP motor .They work in some situations,some they don't .But keep in mind you aren't paying for a 10 HP and only getting 6 out of it,doesn't work that way .
Offline Don P
    • Calculator Index
« Reply #5 on: October 21, 2019, 07:51:26 AM »
That's what I know as a static phase converter. I made one and it worked ok but with the same parts and a spare 3ph motor I turned it into a rotary pretty quick.
Offline Al_Smith
« Reply #6 on: October 21, 2019, 10:21:51 AM »
Yes plus the fact a salvage 3 phase motor is pretty cheap to find .At the risk of sounding like a know it all  many people over complicate rotary converters .Like it's something new which it's not .Nor is it black magic or rocket science .
Companies like Roto Phase have made a bloody fortune selling these things which are very easy to make .
As a side note when I retired about a year ago I had in excess of 50 years doing electrical work .I would come up with some unusual methods which really had the apprentices scratching their heads .I used to say give me enough transformers and capacitors I could make a bolt of lightning .They didn't know if I was serious about that or not  . 8)----Well you have to get a little fun out of life you know . ;D
moved
MOVED: I need to buy a large used Rotary Phase Converter to power a wood moulder!
Last post April 22, 2009, 08:45:35 PM
by Jeff
3 phase rotary converter
Started by Dana on General Board
Last post March 16, 2009, 12:54:58 PM
by logwalker
3 Phase rotary converter
Started by Kbeitz on General Board
Last post April 13, 2018, 08:52:12 AM
by petefrom bearswamp
help with rotary phase converter problem for shop
Started by Kelvin on Sawmills and Milling
Last post June 29, 2009, 08:03:28 PM
by Al_Smith
