Author Topic: Oops!  (Read 2046 times)
Offline GAB
Re: Oops!
« Reply #20 on: October 20, 2019, 12:52:56 PM »
AH! You guys with all that fancy powered equipment! Now us manual load and mill guys may be slow, but I for myself, have never rolled a log off like that. We are thoughtful and careful.  ;D :D
Unless you rid yourself of the mill yesterday, just like me, your turn is coming.
GAB
Offline GAB
Re: Oops!
« Reply #21 on: October 20, 2019, 12:58:52 PM »
Mr. Sheepkeeper, Sir,
I hate it when that happens :).
BTW, this is the modified Robert's Reverse Roll Quartersawing Technique (RRRQS).  It requires a few more detailed steps than the one described in the manual  ;D.
Danny:
For some reason I think you got the wrong lever.  Got the log stop one instead of the clamp one.
Sure hope it does not take too long to rebuild you pride.
GAB
Online Old Greenhorn
Re: Oops!
« Reply #22 on: October 20, 2019, 03:43:35 PM »
GAB
No doubt! But today was not that day. Instead I chose a different 'first time for that'. I found some barbed wire....... the hard way. :-[ :-[
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Offline Sheepkeeper
  • I'm not so new anymore!
Re: Oops!
« Reply #23 on: October 20, 2019, 05:30:23 PM »
Wondering how you saw with the fender on?
Easy, it's not in the way and I just step a little wider to get around it. I only leave it on when I'm sawing at home, on mobile jobs it comes off.
The hurry-er I go the behind-er I get.
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: Oops!
« Reply #24 on: October 20, 2019, 05:35:31 PM »
Just surprised that the head clears the fender.  On my mills there is about 1-1/2 to 1-3/4 " clearance above the tire itself in a setup where most of the weight is taken off of the tire.  No way the head can pass by a fender.  Lt40 super or LT70 super
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Southside
Re: Oops!
« Reply #25 on: October 20, 2019, 06:03:44 PM »
My 70 will pass by. Do you have the off set insert?
Re: Oops!
« Reply #26 on: October 20, 2019, 06:23:34 PM »
Yes- I was thinking about height.
Offline Southside
Re: Oops!
« Reply #27 on: October 20, 2019, 06:56:05 PM »
Mine will clear it, I put it on before I park the head.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Oops!
« Reply #28 on: October 20, 2019, 10:01:29 PM »
Both of my fenders are the first things removed during setup and the last things installed after take down.  My saw head will not pass the right fender and the loader will not clear the left fender.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Oops!
« Reply #29 on: October 21, 2019, 12:43:40 AM »
Iíve done this particular Oops once or twice, but never was calm enough to snap a photo.
Sooner or later, when during the RRRQS technique, there will be an ďover roleĒ.
HobbyHardwoodAlabama.com
Offline Bindian
  • Gender: Female
Re: Oops!
« Reply #30 on: October 21, 2019, 01:03:42 AM »
The ones you throw off the mill with a chain turner and completely clear the tire - those are the ones you remember.   ;D
I did that yesterday with a 5.5 x 20 inch ten foot cant, with my turning claw.  Guess I blinked or something.  I was hot and ready for a break.  It went over the backstops, all but one.  Half on and half off.   I chained it to the the grapple and lifted it back onto the mill.  Going to get the tractor is what I call the walk of shame.
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel.
My Hero is Johnny Jett
Offline East ky logging
Re: Oops!
« Reply #31 on: October 21, 2019, 04:05:32 AM »
Iíve done that a couple times myself. I have a lt-15 set up stationary and I do it when Iím loading the log ramps up with logs and try to get one more on and push just a little bit and one will roll just right and across the mill it goes.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Oops!
« Reply #32 on: October 21, 2019, 07:04:46 AM »
The "Modified" Version ;D
Re: Oops!
« Reply #33 on: October 21, 2019, 07:59:53 AM »
Hey-that's how to get around the little back bungee problem!  thumbs-up
Offline alanh
Re: Oops!
« Reply #34 on: October 21, 2019, 08:15:25 AM »
the last time I did it was with a 16 'ft long 22" diameter red oak log, did I mention my mill is inside a shed, on blocking, 3 ft away from a concrete wall...getting the log out from between the mill and the wall was an adventure I`d rather forget, but the memory keeps me from doing it again,,, for a while
Offline Ed_K
Re: Oops!
« Reply #35 on: October 21, 2019, 08:48:04 AM »
 Alanh, I'm right with you exactly.The only diff. was mine was 14'. I spent a couple hrs getting it up enough to get a strap around to winch it out with the tractor. Ended up re-leveling the base then the mill.
Ed K
Offline Southside
Re: Oops!
« Reply #36 on: October 21, 2019, 09:01:00 AM »
And that's why I do it that way. I can barely touch the front bungee, forget about the other one otherwise.
Offline Sheepkeeper
Re: Oops!
« Reply #37 on: October 23, 2019, 07:23:02 AM »
I have modified the dust chute to be more like that on the LT35 so that it throws the sawdust a little further away from the walking path. Probably wouldn't work without the mod. Here is a pic to illustrate. Sawhead is at 1 inch.
Offline GDinMaine
Re: Oops!
« Reply #38 on: November 01, 2019, 07:26:31 AM »
 I haven't done that ... more than 2 or three times. It took a few four letter words to put that back on there.
It's the going that counts not the distance!
WM LT-40HD-D42
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
Re: Oops!
« Reply #39 on: November 01, 2019, 08:01:07 AM »
I aint sayin nuthin
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
oops
Started by Kevin on General Board
Last post May 18, 2003, 12:09:16 AM
by J Beyer
OOPS
Started by Wildflower on The Outdoor Board
Last post October 29, 2006, 05:30:07 PM
by Jeff
1 Oops=new bar!
Started by Caloren on Chainsaws
Last post October 21, 2014, 08:48:00 PM
by Wild Man Jack
The $100,000 OoPs
Started by Jeff on Forestry and Logging
Last post February 24, 2004, 05:32:09 PM
by Ron Scott
