Husqvarna x-cut chain and roller guide.
Started by Allar, October 20, 2019, 01:47:47 PM
Allar
Hey,
I've been looking for a new chain for a while now and decided to ditch Oregon and go with a Husqvarna X-cut for .325.
What caught my eye is that there seems to be new roller guide just for x-cut chains.
So the question is, will i be able to sharpen with a basic .325 husqvarna roller guide?
Like what's the difference between new and old style roller guide.
Firewood & Chainsaw videos: Firewood Warrior - YouTube
lxskllr
I don't know how the roller guide works, but if the angle's fixed, that could be the difference. From their site...
Quote
Optimal cutting angle
A saw chain's cutting angle is critical. The tighter the angle, the higher the sharpness – however, if you overdo it, the cutter will lose sharpness and break. With the X-Cut® chain, Husqvarna has found the perfect angle.
Introducing the X-Cut® Chainsaw Chain - Husqvarna
I'm definitely interested in hearing what you think of it, especially compared to Stihl.
outinthewood
I've tried one of the now not so new X-Cut .325 chains ( it came on my 550 mark 2) and as it's a semi chisel I was pretty impressed with it. It digs in very well and not so much slower than full chisel. When I run out of the Oregon I have I'll most likely go for the X-Cut. Now the C 85 3/8 is a very good chain, the first chain I've used out of the box that cut well with out touching it if you can get it give it a try you won't be disappointed.
Allar
Well it's not really fixed angle but if you keep the file paralel with the sides of the gauge it'll give you 30 degree angle.
I checked the package of the x-cut chain and the sharpening angle on it is also 30 degree.. so i don't know ..
Outinthewood yeah i watched your videos of 550xp mark II, seemed to cut nicely. I was kinda hesitant of it being semi chisel but i have only heard good things about it, cant wait to try it out :)
Once i get myself bigger saw i'll give the C 85 a try.
Thanks guys.
Old Greenhorn
I have been following this hoping somebody would find a link or diagram that shows the new tooth profile completely. If the side plate angle is the same at 30°, and they say you need a different roller guide, then I am guessing that it's the top plate angle that has changed, or is it the drop angle (normally 10°)?
 I sure would love to find out if anybody knows.
Allar
Not sure why Husqvarna makes such a secret out of it  >:(
Attached some pictures if anyone interested.
Edit: the down angle along the tooth seems to be around 6 degrees.
