Author Topic: bucking up firewood  (Read 1072 times)
Offline doc henderson
bucking up firewood
« on: October 23, 2019, 08:11:04 PM »
remember the locust tree that chomped on my bands and chains, and found a 3 foot column of concrete in it.  well i made something from the 5 x 5 stuff i made from it.  some is used for dunnage under logs in the yard.  i am moving some log piles as I try to grade the yard to drain since the new clinic construction behind my place.  my brother did road construction and gave me trough rollers from an obsolete conveyor.  i can put 36 inch trees on this and cut between the rollers and get my 16 inch logs to split for my stove.  this is mulberry that has been in the log for a few years drying.
Offline Old Greenhorn
Re: bucking up firewood
« Reply #1 on: October 23, 2019, 09:21:59 PM »
Very cool! If you need a place to store that, I can hold it for you. ;D :D
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Online thecfarm
« Reply #2 on: October 23, 2019, 09:24:32 PM »
Looks better than me putting pieces of wood under my logs.
Offline Nebraska
  • I'm new! Lurked for quite a while, learning !
« Reply #3 on: October 23, 2019, 10:12:52 PM »
Gee what a good brother, that turned into a nifty jig.
Offline woody_88
  • If it can be done, it can be re-done
« Reply #4 on: October 24, 2019, 06:26:14 AM »
I like how the rollers have a bow to em, keeping the log in place from side to side. Great stuff right there Doc!  ;)
Offline hedgerow
« Reply #5 on: October 24, 2019, 09:05:46 AM »
Doc
You got a nice start for a wood processor. Its always nice to get those logs off the ground. I am to the point I don't do much bucking by myself. If I do I buck it some with that skid loader and the hyd saw. Most of the time I wait until one of my firewood helpers is around and I hold them with the skid loader and grapple and he bucks them up.
« Reply #6 on: October 24, 2019, 09:17:50 AM »
thanks for the feedback.  I have had those rollers sitting for close to 10 years.  It worked as expected, but now the blocks from a 30 inch tree are kinda heavy.  I have used the grapple as well to hold, but always end up with the last or middle chunk that has to be done by different.  I am able to pick up 4 blocks at a time with the grapple and set them near the splitter.  the roller lets me adjust the log to get all even cuts at about 16 inches.  my stove will hold a 24 inch piece sideways, but with a raging fire, it is easier to load front to back.  the smaller stuff falls through and I can lift the jig up and they fall through.
Offline 711ac
« Reply #7 on: November 09, 2019, 09:34:23 PM »
Nice rig doc!
For those of us without a dandy set of rollers...
A bunch of hemlock 2x4's from the mill.
iirc, they are 8" centers. My apologies for cutting into your thread, just spreading ideas around thumbs-up
« Reply #8 on: November 09, 2019, 09:39:30 PM »
the more the merrier.  looks good!  the 8 inch centers keep the logs from falling through, with mine I pick it up with the forks for the little stuff, the beg stuff I can pick off the top with the grapple.
Offline dave_dj1
« Reply #9 on: November 10, 2019, 03:22:36 PM »
I like your set up doc but unless you're a dwarf it needs to be much taller, I'm 6'-2" and that would kill my back  8)
« Reply #10 on: November 10, 2019, 07:12:47 PM »
It is for the big stuff, so a 30 inch log is at a good height.  you stay upright and rotate through so you do not hit the back.  It could easily be lifted if needed.  goes a little faster and keeps the chain out of the dirt. :)
Offline Logging logginglogging
« Reply #11 on: November 11, 2019, 08:27:58 AM »
tell me about that concrete column you found? did someone pour concrete in a hollow tree in order tor try and shur it up?
Offline Southside
« Reply #13 on: November 11, 2019, 10:02:54 AM »
Hedgerow - how often does your help come back?  Not sure I would hang around much if you tried to hold onto me with your skid loader grapple, but to each his own I guess.  :D
« Reply #14 on: November 11, 2019, 10:21:40 AM »
 :D :D :D :D :D :D :D
« Reply #15 on: November 11, 2019, 10:30:46 AM »
bucking firewood there has to be a better way
Started by Splinter on Forestry and Logging
Last post January 09, 2019, 06:39:50 PM
by g_man
thumbup
Felling, Limbing and Bucking a Firewood
Started by Allar on Firewood and Wood Heating
Last post January 24, 2019, 03:54:52 PM
by Allar
bucking saw
Started by AmyB on Sawmills and Milling
Last post December 05, 2006, 04:47:50 AM
by thecfarm
How's your bucking?
Started by Ron Wenrich on Forestry and Logging
Last post May 07, 2007, 10:00:19 PM
by IndyIan
