Author Topic: LT15Wide Not Starting After 1 Month Idle  (Read 1304 times)
Offline Pepe_Silvia
« on: October 23, 2019, 09:26:33 PM »
I wasn't able to run my saw for about a month, and now it won't start.  I don't know how old the fuel was, but at most a couple-few months old. I can get it to fire with carb cleaner and checked that it is pumping fuel into the carb, so I think that basically narrows it down to the carb being gummed up.
First of all, I typically just shut it down after use, but I'm thinking maybe I need to start shutting off the fuel shutoff and letting it starve itself, is that correct?
Second, is there a 'quick fix' on this?  Maybe one spot where it's prone to gum up that I can get to without taking the whole carb apart?  That's probably wishful thinking.
Saw is an LT15Wide with the 25HP Kohler.
Offline Just Right
    • JustRightSawing
Re: LT15Wide Not Starting After 1 Month Idle
« Reply #1 on: October 23, 2019, 09:29:37 PM »
You could try SeaFoam to see if that helps.  Other than that,  rebuild the carb.
If you are enjoying what you are doing,  is it still work?
Offline Southside
« Reply #2 on: October 23, 2019, 09:34:31 PM »
I let my welder sit once too long, same engine, and it was just a case of taking the carb off and cleaning it really well.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #3 on: October 23, 2019, 09:35:08 PM »
One month should not be anywhere near time enough to gum a carb with bad fuel.   My guess would be water in the carb bowl.  Try doing a carb bowl rinse first.  If there's a drain screw do that first, then only remove the bowl if you have to.
EDIT : a 25hp Kohler will not likely have a drain screw.  You could start it and keep it running with a squirt bottle while you choke it to suck the water out of the bowl.  I can't believe that fuel could go bad in a month.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: October 23, 2019, 09:35:49 PM »
I have a 25hp Kohler on my mill, but I don't remember if there's a drain plug on the bottom of the carb, but if there is, drain it and feed it some fresh gasoline!
I only use 91 octane, non ethanol gas in my small engines!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Pepe_Silvia
« Reply #5 on: October 23, 2019, 11:04:50 PM »
Thanks for the advice everyone.  I took the carb apart and cleaned it as suggested and it works now.  So either bad gas or water.  There was some green corrosion on the interior parts.  Is this indicative of water?
There turned out to be no drain on it.
Offline charles mann
« Reply #6 on: October 24, 2019, 12:51:28 AM »
for copper/brass, green is indicative of corrosion, aluminum, white. as recommended, run a little seafoam even though you got it running. my miller has a kohler and i let it sit for a while too, but my fuel tank is below the engine. i poured a couple bottles of denatured alcohol in the tank, put 5 gal of 100LL av gas and let it sit for a couple hrs. since the lift pump is whacked, i installed a primer bulb from a boat fuel tank, primed it, turned it over and it fired right up. i now only run 100LL in ALL my air cooled engines, including my chainsaw.
Temple, Tx
Offline firefighter ontheside
  • I like trees.
« Reply #7 on: October 24, 2019, 05:10:43 PM »
Ive never ran my kohler engines dry of fuel, but I do shut off the fuel petcock.  My mower always starts fine the next spring.  If youre going to let it sit that long, put a little bit of sea foam or other stabilizer in once in a while.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: October 25, 2019, 08:43:31 AM »
I'm surprised because most small engines have a drain screw on the bottom of the float bowl.
Offline Pepe_Silvia
« Reply #9 on: October 25, 2019, 09:29:45 AM »
I don't know a whole lot about them, but this seems to be a little bit different design.  The bowl is basically part of the body of the carb.  There's a solenoid on the side (it attaches where the brass part is in my original post) that could probably be removed to drain the bowl, but I'm not sure the screws are accessible while the carb is mounted.
This isn't my picture but I snagged it from a youtube video I watched.
Offline Ed_K
« Reply #10 on: October 27, 2019, 12:30:10 PM »
 I had problems with my garden tractor not starting if not used every day. It ended up that electric shut off on the side of the carb was sticking. Just a little sticky film on it and it wouldn't open. Not saying what happened to that rod ;D.
Ed K
Offline Don P
    • Calculator Index
« Reply #11 on: October 27, 2019, 02:39:54 PM »
On the denatured alcohol thing, I've removed the fuel pickup tube from the tank and stuck it in a bottle of fuel treatment (denatured alcohol) and sucked up a very healthy snort. The alcohol will mix with water and also mixes with gas so it soaked up the water that was in the bowl and it got burned over the next couple of minutes of rough running.
Offline Pepe_Silvia
« Reply #12 on: November 08, 2019, 07:09:01 PM »
Well, it wasn't actually running as well as I thought.
When putting the carb back together the gasket was curling on me and would not seat properly.  I got it back in as best as I could.
It would run at first, then got to where it was dying every time I throttled down.
Eventually it stopped running and would cough but not start.
I ordered a new gasket, got it in today.  Went ahead and siphoned all the old gas out of the tank as best as I could, unhooked the fuel line and cranked the motor a few times to clear the line.  When I was putting it back together, the spring that wraps around the throttle and is connected to the carb and linkage came off, and I'm not 100% sure I put it back on in the right place.
At idle now it cycles between idling well and almost dying.  At full throttle it surges.  When I throttle down from full throttle it dies.
I'll try to take some video if that will help.
Offline btulloh
« Reply #13 on: November 08, 2019, 07:17:51 PM »
That spring must be related to the governor and you probably put in the wrong place so the engine is hunting.
Do you have a manual for the engine?  Or you should be able to find it on a parts diagram online.
Sounds like the gasket and the other things you did took care of your original problem.
HM126
Offline Pepe_Silvia
« Reply #14 on: November 08, 2019, 07:35:41 PM »
I found the manual here: http://www.kohlerengines.com/engines/onlinecatalog/pdf/24_690_06_EN.pdf
It is the spring that's on part F here, the throttle linkage.  It looks like I have it in the right place.
Offline Ed_K
« Reply #15 on: November 09, 2019, 08:36:31 AM »
 I found that when my engine was surging/hunting the float was not set right.
Ed K
Offline btulloh
« Reply #16 on: November 09, 2019, 08:56:10 AM »
X2 on the float.  I'm not a real good carb guy and I always think the float is adjusted OK because I didn't change it when I'm rebuilding a carb.  I'm usually wrong.
The real story is everything needs to be right with the carb and linkage and it's easy to miss something.  If the original problem was a gummed up carb, it's also easy to miss cleaning some of the tiny internal passage ways.
Another thing that gets skipped with a casual cleaning is removing the Welsh Plugs - the little domed things that look fragile (they are). They are usually supplied with a rebuild kit.  Removing them allows access to the internal passage ways that like to gum up.
HM126
Offline sealark37
« Reply #17 on: November 09, 2019, 09:04:11 AM »
Just a re-cap of the obvious.  Are you using ethanol-free gas?
Offline Pepe_Silvia
« Reply #18 on: November 09, 2019, 09:59:25 AM »
I'm not.  Ethanol-free is not readily available around here.
Offline Pepe_Silvia
« Reply #19 on: November 09, 2019, 10:07:54 AM »
Thanks for the tip.  I've never adjusted a float before, but I'll search and see what I can find.
Any tips?
Woodmizer LT15 Idle side rail scraped by idle side vertical mast
Started by Hunter1000 on Sawmills and Milling
Last post March 27, 2016, 07:46:33 PM
by thecfarm
LT15wide cut width
Started by Brad_bb on Sawmills and Milling
Last post July 25, 2019, 07:41:14 PM
by Brad_bb
New EPA fuel tank for LT15WIDE
Started by booman on Sawmills and Milling
Last post August 12, 2019, 05:52:48 PM
by RAYAR
Setting LT15Wide On Beams
Started by Pepe_Silvia on Sawmills and Milling
Last post December 11, 2018, 05:48:55 PM
by Pepe_Silvia
