Author Topic: Manjisann's Chainsaw Milling Adventures  (Read 9767 times)
Offline ManjiSann
  • Doing more with less because I can't afford more;)
Re: Manjisann's Chainsaw Milling Adventures
« Reply #80 on: November 09, 2019, 11:36:35 PM »
ManjiSann,
If you are planning (hoping) to get some bigger logs, you are going to need a way to move them.  You are gonna need a log arch of some sort.  In keeping with your free/scrap mantra, here is something I made (and remade) to move my timbers and lumber but was originally built to move some redwood logs.
A simple log arch...
@ljohnsaw That's friggen amazing! How much weight have you had on it?  Love the simplicity of the design and the adaptability.
Brandon
Poulan Pro 5020AV, Husky 390XP
Offline ljohnsaw
« Reply #81 on: November 09, 2019, 11:46:13 PM »
I've loaded way too much on it! :D The old, little one would carry a 8x12x14' pine post no problem as long as the tires were aired up.  My new one I have only used it to carry wood from my SkyTrak to my wood piles inside my basement.  I've loaded up three or four 2x10x16' green pine boards.  Quite heavy!  Its a little tippy - need to make it wider.
To use it to move logs, you drive over your log, lift the handle up until the lower crossbar hits the log.  Strap it with ratchet straps or some chain.  Pull the handle back down and haul it away.  You can put a ratchet strap around the handle end and the log to keep it stable and easy to move.
John Sawicky
Offline ManjiSann
« Reply #82 on: November 09, 2019, 11:54:02 PM »
I talked to the tree service fellow and gave him my contact info. He said he'd let me know if he's taking a tree down on my day off and I can come by and they'll help load it in my truck... I need a bigger truck  ;D He said he'd taken down a nice 3' DBH burr oak last week... I shed a couple tears over that one.
Since fortune favors the prepared (that's the saying right  ;)) I finally figured out what I'd do with this large pallet I never got around to cutting up
I layed an old tarp on the ground as a moisture barrier and some keystones I had lying around and leveled it all as best I could
Put the pallet on
Now I have somewhere to put the lumber I cut if/when I get logs from the sources I'm hoping to cultivate  ;D  I figure when I have the logs is probably not the best time to be trying to figure out where to put stuff as I'll want to be milling so I'm trying to think ahead a bit. As I've mentioned, I'd love to build a shed eventually but right now this is more my budget and speed  :) :) I'll keep an eye out for something I can use as a roof/cover, hopefully some corrugated tin roofing will find its way into my truck bed  :)
I thought I was done for the day, but ljohnsaw's log arch got me thinking and I started surfing the local ads for free stuff hoping to find some wheels or something for a log arch. So far nothing on that front but I did find...
A FREE ALUMINUM LADDER!!!!  Well most of it.
One section is busted, hence why it was free. Both sections look pretty straight though so I'm planning to use this as the guide for my chainsaw mill. Now I won't have to mess with 2x4's as much. The large section I believe is 12' the broken section is a little less than half that so I figure between the two I should be set for anything I expect I'll handle  8) 8)
All in all a good day!
Hope everyone has a safe and blessed weekend!
Brandon
Offline ljohnsaw
« Reply #83 on: November 10, 2019, 12:02:37 AM »
SCORE!  I count 16 rungs on the big section in the picture so it is at least a 16' ladder (32' designation).
John Sawicky
Offline doc henderson
« Reply #84 on: November 10, 2019, 08:44:31 AM »
get some plastic and watch the timbergreen farms simple cycle solar kiln video.  If you cannot do the former...you still have the ladder!!! 8) 8) 8) :) :) :) what too early?
Offline ManjiSann
« Reply #85 on: November 10, 2019, 09:02:55 AM »
I think the sticker on the side said 24' ladder but I'll check. Whatever the length it was a great deal for the price  8) 8)
Brandon
Offline ManjiSann
« Reply #86 on: November 10, 2019, 09:05:13 AM »
Only have a few minutes this morning so I quickly checked out their website, looks like a great idea and should be in my shoestring budget  8) 8) Thanks for pointing me in that direction!
Maybe my brain isn't up to speed yet... too early for what?  :-[
Brandon
Offline ManjiSann
« Reply #87 on: November 10, 2019, 10:10:04 AM »
@ljohnsaw good call! You are right, it was a 32' ladder, so 16' sections. I'm impressed!
On a side note, why is everything rated for 250lbs? Most people I know are over that weight limit (including me  :'( ).
Brandon
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #88 on: November 10, 2019, 10:16:26 AM »
You''ve had a pretty good two days, dont fret that oak tree more will show up. I will say that a 36 in Burr Oak will be a challenge to do anything  with, (very heavy) i would quarter or mill it in place, it before you tried to move it.  I would need to borrow the neighbor's  wheel loader and forks as it is way to much for my tractors  to move.
Nice haul on the ladder section if it's pretty straight you are set.
I'm on call this weekend in the office waiting for someone  to show up from 40 miles away so catching up on your  adventures  made this time pass much better. :)
« Reply #89 on: November 10, 2019, 10:25:51 AM »
did you get a back story on the ladder sheared in half?  most ratings can be pushed a bit, but I would not double it!
Offline ManjiSann
« Reply #90 on: November 10, 2019, 03:34:31 PM »
I'm not really that broke up about the oak, just sad to think it went to firewood. You're right though, there's no way I'd have been able to move it with my little S-10 even if the tree service was able to lift it in for me... if was more than 4 feet long it'd likely have folded my poor truck into a taco given the weight.
Both sections of the ladder are pretty straight so as you say, I think I'm pretty set :) Now to figure out where to store it  :D
Glad I could entertain  8)
Brandon
Offline ManjiSann
« Reply #91 on: November 10, 2019, 03:41:36 PM »
Fellow said it was in the house when he bought it. Would be interesting to know how it was broke as both sections are pretty straight. Oh well, one more of those mysteries I'll likely never know the answer to  ???
I don't plan to use it as a ladder, just commenting on the weight limits of things  ;D
On a totally different note, spoke with my neighbor that runs a construction crew and let him know I'm interested in any tree trunks they take out. He's a good neighbor so I'm sure if he remembers he'll hit me up.
Fingers are crossed I get a text from the tree guy on Wednesday for a log or two  :)
Brandon
Offline JoshNZ
« Reply #92 on: November 10, 2019, 04:21:11 PM »
You'll have to weld the ladder sections together along a straight edge surely? They're not much good to you in two sections, for logs over 16" at least. Unless you fancy carrying a string line etc and some clever mounts
Offline ManjiSann
« Reply #93 on: November 10, 2019, 08:42:04 PM »
I don't expect to be handling logs much over 10' in length as I don't have the equipment to handle any heavy weight (10' is very optimistic in reality but I'm trying to not limit my thinking  :) )
Brandon
Offline ManjiSann
« Reply #94 on: November 10, 2019, 09:07:21 PM »
Been mulling over what @Old Greenhorn said about rustic furniture and Adirondack chairs came to mind, getting a bit excited about the idea.
What other styles of building would be considered rustic and would allow for the movement of air dried wood? Not sure what search terms to use, "Rustic" seems to mean different things to different people. I saw some "Farm" style stuff that looked interesting but if I search for that exactly then you end up with all sorts of stuff. I'm fine continuing to search on my own but figured I'd ask and see what everyone else has seen and done  :)
I'm not ruling out the kiln @doc henderson posted about, I'm thinking I'll likely do that as well but I am liking the idea of doing something rustic for some patio furniture  :)  One thing the wife and I are really hoping to build in our back yard is an awning and extended porch area and I think some Adirondack chairs and/or other rustic style furniture would be a lot of fun to build  8)
Brandon
Offline Old Greenhorn
« Reply #95 on: November 10, 2019, 09:39:31 PM »
Go back to my earlier reply (55, I think) and look at the things those guy are building. Simple, functional, yet elegant stuff. Don't overthink. Bench with 4 legs, start with that. After that the path will reveal itself.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
« Reply #96 on: November 10, 2019, 09:54:42 PM »
search, rustic, log furniture, live edge.  select images and if you see something you like, click it and it will head you down that road. the plastic kiln just shows you a way to keep stuff going this winter.  until you have a shed or a kiln.
Offline miro
« Reply #97 on: November 10, 2019, 10:45:49 PM »
I have been following this thread with great interest. It follows a very similar trajectory that I had. I got into CSM after seeing it in Fine Woodworking about 40 years ago.
Ultimately I designed and built most of my own furniture in colonial American style ( 1760-ish)- lots of carving -mainly walnut and black cherry etc,
I ended up also forging my own carving chisels because I couldn't afford the store bought ones.
As for drying - outdoor gets you down to about 15% and then indoors to get it to 6-8%  - ready to work. I did my own re-sawing on an old Rockwell bandsaw.
I coated my ends with several coats of the cheapest latex paint I had - colours indicated when I sawed the trees. I've sawn maple, black cherry, walnut, birch, basswood, but not much softwood - not really worth  the effort.
I learned to carefully sharpen - got good at it.
Eventually had too much wood in storage so I stopped milling.
My latest CSM adventure was 2 years ago -  walnut tree that I had planted over 40 years ago - sad to do it, but it started to be a hazard. But I DID get the lumber out of it.
Maybe I make my own coffin out of it - delicately and generously carved :-} .
miro
Offline thecfarm
« Reply #98 on: November 11, 2019, 05:59:28 AM »
@miro went to your gallery to see if you had pictures of some of the furniture you made. :(  I did see lumber and a CSM.
Offline ManjiSann
« Reply #99 on: November 11, 2019, 08:03:45 AM »
OG, thanks, I'll look at it more closely. I remember the benches you and WV Sawmiller were posting about, don't recall seeing anything else but I must not have read enough (or my memory is even worse than I thought :(.)  I often want to jump right to all the super amazing advanced stuff, and I've pulled it off once or twice in my life but more often than not I lack the skills and knowledge so things don't go quite how I envisioned and I get frustrated or discouraged. So I will endeavor to take your advice and start with something simple like the log bench or similar. As you say, simple can still be elegant and I'm usually more of a function over form sort of person :)
"Don't overthink"  HAHAHA that'll be the real challenge for me now won't it  ;)  I think that will end up on my tombstone "He lived so long because he overthought his ending" or something of the like  :D :D
Brandon
Chainsaw Milling
Started by pneese on Sawmills and Milling
Last post October 28, 2019, 05:55:10 PM
by Brad_bb
Chainsaw Milling
Started by iain on Chainsaws
Last post March 10, 2006, 10:00:43 AM
by beenthere
chainsaw milling
Started by gginseng4 on Sawmills and Milling
Last post November 08, 2013, 08:28:12 PM
by Gasawyer
chainsaw milling
Started by 76gmc on Sawmills and Milling
Last post January 02, 2012, 01:20:45 AM
by Brucer
