Author Topic: LT40 hydraulics not working  (Read 1159 times)
Offline Southside
Re: LT40 hydraulics not working
« Reply #20 on: November 01, 2019, 04:35:49 PM »
Was your jumper wire considerably smaller than the wire feeding the hydraulic pump?  If so it was just pulling too many amps through it.
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #21 on: November 01, 2019, 04:53:08 PM »
Iím working from memory of several years ago, but...
There is a (I think) red trigger wire going to the solenoid (itís really a car starter relay) and it activates the electromagnet and pulls it into position to engage the main power contacts to energize the pump.  The trigger wires are smaller than the main feed wires so they are easy to find going into the solenoid.  With the hydros off, the trigger would read zero, with the hydros calling for active it should read 12 volts, if my memory serves.  If you have 12 volts going into the solenoid on the input side in the main feed line, and 12 volts on the trigger wire when commanding hydros, and zero or most likely a low voltage coming out of the solenoid, say 4 volts or so because of a poor or partial contact, then itís the solenoid.  You should also hear it click when you activate the trigger wire.  I had to replace 2 on my LT40.  They are just starter motor relays for automobiles.
When you jumped with the shunt wire, it bypassed the solenoid and full power draw caused the wire to shunt to burn because itís not rated for the high current that the motor of the hydros use.  So that says the open circuit is at the solenoid, so it could and probably is, the main contractors not closing adequately. However, check the trigger wire also, if there is no signal to the trigger the solenoid wonít be calling to close, and itís not the problem.  There would be an issue with the trigger circuit.
They are pretty cheap if I remember correctly, and I bought two, one as a spare, and eventually used it also.  You could also go to your local auto parts store and find a similar item.
HobbyHardwoodAlabama.com
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: November 01, 2019, 08:34:59 PM »
Your voltmeter will verify whether the "trigger" wire is being energized.  Get your replacement 200amp solenoid from Wood-Mizer.  I always keep a couple of spares.  Both of those solenoids are the same.
Online Bandmill Bandit
« Reply #23 on: November 01, 2019, 08:45:39 PM »
Dont jump across the solenoid. Put power to the switch terminal on the solenoid. (probably and 1/8th or 3/16ths diameter stud) it is a small terminal that will likely have a red or black #14 or 12 wire going to it from the key switch.
Disconnect that wire and then jump 12 volts to that small terminal from the hot side of the solenoid. You can check that terminal with a voltage meter too, and if there is no voltage there your back power supply to/ from key. You will hear the contacts click closed when you apply power to this terminal IF the solenoid is working.  Can do it with about a 6 inch piece of wire. No clicky No worky! Need new solenoid.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2018 F150 FX4, Husqvarna 340
2007 Woodmizer LT40HDG28 almost Super
2 Logright 36 inch cant hooks and a bunch of stuff I built myself
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #24 on: November 01, 2019, 10:12:52 PM »
Pretty sure there is a 15a breaker In between the key switch ACC terminal and the little 12v post on the solenoid. Maybe one of the 5 that are right under the controls.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: November 01, 2019, 10:22:05 PM »
Even of the solenoid clicks, there is no guarantee that it is making electrical contact.
Offline brooksmill
  • retired!
« Reply #26 on: November 03, 2019, 02:23:17 PM »
Doing more testing. With key sw on I have 12v on bottom red wire on solenoid. Nothing on wire going to spring loaded block. Will call woodmizer tomorrow and probably order solenoid. Unless someone here has different ideas.
« Reply #27 on: November 03, 2019, 04:15:34 PM »
I will assume you mean the little #14 red switch wire is hot at solenoid with key in the on position.
This would indicate a failed solenoid.
Lynn is correct on the click sound. It doesn't mean the solenoid is working.
Offline brooksmill
  • retired!
« Reply #28 on: November 03, 2019, 04:36:44 PM »
thanks guys, will let you know the outcome
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #29 on: November 03, 2019, 05:23:40 PM »
   If you by-pass it do your hydraulics work?
Offline brooksmill
  • retired!
« Reply #30 on: November 03, 2019, 06:20:33 PM »
wv sawmiller YES
lt40 hydraulics stop working
Started by widfam on Sawmills and Milling
Last post December 27, 2015, 05:06:37 PM
by Chuck White
Lt70 hydraulics quit working
Started by just_sawing on Sawmills and Milling
Last post February 13, 2013, 07:48:26 PM
by just_sawing
lt40 hydraulics
Started by Mcwhorter111 on Sawmills and Milling
Last post March 03, 2017, 08:53:29 AM
by paul case
Hydraulics on LT40
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 29, 2016, 09:11:18 PM
by paul case
