Author Topic: Large Order of EWP  (Read 748 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Large Order of EWP
« on: November 04, 2019, 07:17:25 PM »
I just quoted and received an order for 2268 LF of 6x6 EWP, milled to a nominal 5.5x5.5 at 8' and 10' lengths
I have done work for this gentlemen before. Great guy to do buisness with.
I now need to source the logs.
It would be great to be able to buy only 8' and10' lengths.
There is no concern about free of heart or center cut. It would be great to be able saw more than 1 per log.
My real concern efficiency, and time as winter is fast approaching and it needs to be done by December
What size small end are best sizes to maximise that size with out a lot of waste?
Stephen!
Offline btulloh
Re: Large Order of EWP
« Reply #1 on: November 04, 2019, 07:22:45 PM »
7.779Ē diameter small end inside the bark. Thatís of course a perfect log. So 8.5 or 9 inches small end
HM126
Offline Bruno of NH
« Reply #2 on: November 04, 2019, 08:08:27 PM »
8' and 10' should be cheap and easy to find most big mills don't want 8' and 10' pine.
Lots find there way to my mill
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline GAB
« Reply #3 on: November 04, 2019, 09:00:41 PM »
If my math is correct and the logs are straight a 20" diameter small end should get you five 6X6's.
GAB
Offline highleadtimber16
  • Learning Everyday
« Reply #4 on: November 04, 2019, 09:16:57 PM »
When making boxed heart 6x6 I prefer a 9" top. Gives me a bit of side lumber too depending on the length of the log.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline moodnacreek
  • Sawin by the notches
« Reply #5 on: November 05, 2019, 07:50:23 AM »
The problem with buying 8 and 10' w.p. that I had was you got all top logs.   In good diameter logs this order would be fast with a big edger.
Offline btulloh
« Reply #6 on: November 05, 2019, 09:14:51 AM »
Absolute minimum log diameters for 6x6's.  (Allowing 1/8" kerf.)
I usually saw 5 5/8 on SYP to end up with 5 1/2 x 5 1/2 after drying, FWIW.
Offline Stephen1
    • muskoka Sawmill
« Reply #7 on: November 05, 2019, 08:11:29 PM »
I like the diagrams.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: November 05, 2019, 08:22:09 PM »
Remember that there are no perfect logs; a little sweep, slightly oval, flutes, etc.  Log setup and face opening often determine what your log will actually yield.
Offline Stephen1
    • muskoka Sawmill
« Reply #9 on: November 05, 2019, 08:36:28 PM »
Exactly, there are very few perfect logs.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #10 on: November 05, 2019, 09:54:14 PM »
Or perfect sawyers.....
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline donbj
« Reply #11 on: November 06, 2019, 12:44:53 AM »
Good info in those diagrams. They have valuable information to quickly assess a log. They also say "everything works on paper". But good info.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline btulloh
« Reply #12 on: November 06, 2019, 07:53:48 AM »
The diagrams are of course for perfect logs and perfect sawyers.  The practical sawyer would add enough to the log diameter to accommodate reality.
HM126
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: November 06, 2019, 07:56:51 AM »
For square cants, "half again bigger" works very well.  ;D
Offline Stephen1
    • muskoka Sawmill
« Reply #14 on: November 06, 2019, 08:45:10 AM »
I have been sourcing the logs, RP or WP , the RP comes out of plantaions and so down in small end size, ussually around the 16"
The white pine is all over the map as they are coming out of a bush lot, natural growth. I can specify small end but then the cost goes up. It is a challange to source, a sharp learning curve to be sure.
I figure I need 7k bd ft of logs which is a truck load or two
The last sawing I did for him, I picked the logs at a local tree service, hit 2 nails, but still made money.
wanted a large order of green hardwood for decking
Started by Quebecnewf on Wanted
Last post January 22, 2008, 09:03:22 PM
by floorboy
How do medium large companies dry large slabs?
Started by KODAK on Drying and Processing
Last post July 16, 2018, 08:31:32 AM
by 123maxbars
How do I order a hat?
Started by bmill on General Board
Last post January 11, 2009, 09:08:25 PM
by isawlogs
In what order to you cut them?
Started by francismilker on Sawmills and Milling
Last post November 06, 2012, 08:47:30 PM
by Magicman
