Tally-I/O
Author Topic: Recognize this resaw?  (Read 858 times)
Offline firefighter ontheside
  • I like trees.
« on: November 06, 2019, 09:47:43 PM »
This is in a local auction.  Does this look like something you recognize or is this homemade?  It has a predator engine, which I believe is Harbor Freight.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Southside
Re: Recognize this resaw?
« Reply #1 on: November 06, 2019, 09:55:05 PM »
Is that a re-saw or an edger?
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
« Reply #2 on: November 06, 2019, 10:01:50 PM »
Looks like a home made edger to me
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Online moodnacreek
  • Sawin by the notches
« Reply #3 on: November 07, 2019, 08:04:15 AM »
If it is a edger at least one blade will shift on the mandrel.
  • I like trees.
« Reply #4 on: November 07, 2019, 11:40:59 PM »
It appears to have 2 blades about 6 inches apart.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Don P
    • Calculator Index
« Reply #5 on: November 08, 2019, 07:49:18 AM »
Looks like a homemade edger to me. I was in the reading room this morning and in an old '03 sawmill and woodlot was an ad from Burlee Machinery from Licking, MO for a circular thin kerf resaw that used 10" blades and had visible hold down tires like yours. Looking at the welds and layout I think yours is a homemade edger but just putting it out there that there are or were circular resaws in your neck of the woods.
  • I like trees.
« Reply #6 on: November 08, 2019, 01:34:09 PM »
Interesting.  Licking is only about 90 minutes from my house.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
  • I like trees.
« Reply #7 on: November 09, 2019, 08:28:59 PM »
Ive never used an edger.  How does it work?  What guides it straight thru the blades?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Southside
« Reply #8 on: November 09, 2019, 09:44:37 PM »
Depends on the design.  Mine has power feed rollers in and out, top rollers are held down with spring pressure and the bottom ones don't move.  The board is forced in and pulled through, as long as they are parallel and exerting the same pressure they will hold the board true and you can cut one or both sides of the board at the same time.  The other design has a feed in and feed out belt.  The space where the blades turn is open, same theory but my experience is that that design tends to have more maintenance issues.
  • I like trees.
« Reply #9 on: November 09, 2019, 11:38:16 PM »
This thing appears to be all manual....have to push it in one side and pull it out the other.  Cant really tell from pictures.  Im winning it currently in online auction for $1.50.  Probably will go up, but I doubt many will know what it is.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Southside
« Reply #10 on: November 10, 2019, 08:35:52 AM »
Will be interesting to see it run if you get it. Any other photos of the unit?
  • I like trees.
« Reply #11 on: November 10, 2019, 07:55:05 PM »
O
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Don P
    • Calculator Index
« Reply #12 on: November 10, 2019, 10:27:35 PM »
Def not a resaw. It looks like an edger or gang rip with some thinking issues. I suspect you are bidding on an engine and some steel for future projects.
  • I like trees.
« Reply #13 on: November 11, 2019, 02:38:48 PM »
Yeah, Ive considered that I can just use the engine for something else.  The infeed and outfeed roller tables appear to be separate, so those could be used somewhere else.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
recognize this moth?
Started by Wendy_H on Tree, Plant and Wood I.D.
Last post September 20, 2009, 01:03:16 PM
by Wendy_H
Anybody recognize this puppy?
Started by Stu Redman on Tree, Plant and Wood I.D.
Last post July 07, 2015, 09:34:23 AM
by Jeff
recognize this fungus?
Last post March 03, 2010, 03:10:51 PM
by tonich
anyone recognize this craftsman planer?
Started by Ocklawahaboy on General Woodworking
Last post April 18, 2014, 07:03:08 PM
by petefrom bearswamp
