Tally-I/O
Author Topic: WoodMizer Board Guide Mounting Location.  (Read 262 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: November 07, 2019, 06:08:20 PM »
I am in the process of modifying and installing the Wood-Mizer LT70 board return guide fingers on my LT40 Super-wide.   I need to relocate the mounting point of the horizontal bar the holds the fingers so they are aligned properly on my mill.   What I need to know from those that have the return guide is where does the end finger hang in relation to the rail the mill head travels on?    Also, where do the bottoms of the fingers hang in relation to the blade?
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
Re: WoodMizer Board Guide Mounting Location.
« Reply #1 on: November 07, 2019, 07:52:08 PM »
I made my own. I made it so the fingers are about an inch below the blade.
My original design was like woodmizers.
I redid it with roller chain. It's much lighter.
Doesn't make any noise and is "see" through.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
    • Byrne Millwork
« Reply #2 on: November 07, 2019, 07:58:30 PM »
The inside of the left most finger is flush with the side supports.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
    • Byrne Millwork
« Reply #3 on: November 07, 2019, 08:03:06 PM »
You may have to weld the main "T"  tube off center since you have a wide mill. And put some extra weight on one side just to keep it balanced so it isn't pulling down on one side more than the other.
If you have any questions pm me I'll give you my cell. Or you can get my number off my website.
WM bms250 sharpener
WM bmt250 setter
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #4 on: November 07, 2019, 08:38:06 PM »
The current WooodMizer made unit is made off centered but it is the wrong direction.   I've already cut it apart and will be welding it back together to be off centered the other direction, the correct amount.
Hidden Acres Farm
Hitch vs Drag- Skid trail vs Twitch rd....Location Location Location
Started by riverlogger on Forestry and Logging
Last post February 23, 2014, 11:47:13 AM
by Rick Alger
Chainsaw Mill: Milling a log thats longer than your guide board
Started by danf26 on Sawmills and Milling
Last post April 01, 2012, 09:04:54 PM
by Dave VH
question
WoodMizer guide rollers
Started by isawlogs on Sawmills and Milling
Last post December 17, 2006, 06:26:14 AM
by DWM II
Woodmizer guide arm shield breaking
Started by irvi00 on Sawmills and Milling
Last post December 10, 2017, 07:53:53 AM
by Peter Drouin
