Author Topic: Solar kiln vents  (Read 335 times)
Offline D6c
Solar kiln vents
« on: November 09, 2019, 01:34:33 PM »
Trying to get back to finishing up my Virginia Tech style solar kiln....other things have gotten in the way for months.
My question is about what type of lower vents you put in your kiln.  My upper vents are built with a sliding door that has a rain cap and flashing to keep out rain.
I was looking for ideas for something a little simpler for the lower vents that will still be weather tight, and preferably adjustable from the outside.
Any ideas?
Online btulloh
Re: Solar kiln vents
« Reply #1 on: November 09, 2019, 02:01:54 PM »
I put mine on the inside to avoid that problem.  I put a handle on the outside, so they're still adjustable from outside.  I also put an overhang on the front to lessen the weather effects.  Some people have just not worried about it at all and they seem to be fine.  Maybe I overthought it, or underthought it,  but it's worked out fine and I'm happy with the vents.  I suspect most people are happy with theirs too.
HM126
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: November 09, 2019, 06:28:01 PM »
I use 2 of the $15 black plastic sliding foundation vents from Lowes.
HobbyHardwoodAlabama.com
Offline D6c
« Reply #3 on: November 09, 2019, 08:03:40 PM »
Thanks, I'll have to check those out.
Btullo,
I like the overhang... might do that.
Offline GeneWengert-WoodDoc
« Reply #4 on: November 10, 2019, 08:40:03 AM »
The 1/4 scale model solar kiln I have has the vent design that btulloh has except they are on the outside.
Offline D6c
« Reply #5 on: November 12, 2019, 11:19:39 AM »
YH,
My local Lowes doesn't stock foundation vents...is this about what you're talking about?
https://www.ebay.com/itm/Speedvent-Crawl-Space-Foundation-Air-Vent-Cover-New-Any-Quantity-Gray/254179865149?hash=item3b2e4cf23d:g:1BYAAOSwyGhbdk2e
Stopped at Menards but all they had were automatic vents and they're sized to fit an 8x16 cement block opening, which would be too wide for 16" stud spacing.
Online btulloh
« Reply #6 on: November 12, 2019, 11:39:02 AM »
I had trouble sourcing foundation vents that I liked and would fit. Maybe the trick is to surface mount them. I gave up and made the sliders. A little more time but essentially free. Trade offs.
HM126
« Reply #7 on: November 12, 2019, 02:12:36 PM »
I used these, I guess I got them from Home Depot.
I use two up top, two on the bottom.
https://www.homedepot.com/p/Master-Flow-16-in-x-8-in-Plastic-Slider-Foundation-Vent-in-Black-PS168BL/206624404
Offline Nebraska
  • I'm new! Lurked for quite a while, learning !
« Reply #8 on: November 12, 2019, 05:14:37 PM »
Don't know if these would work but I had contemplated recycling the 2 inch plastic ball valves from the chemtote tanks I cut firewood into. Just need several.  A person could use a 3 inch pvc  ball valve with an elbow  covered with screen pointed down. Just cut the hole and use sealer to hold in place.  Might not be as econominical but weatherproof and infinitely  adjustable. Just something I have thought about  during less busy times at work and just read this thread.
Vents on VTech solar kiln
Started by RussMaGuss on Drying and Processing
Last post May 14, 2019, 05:04:47 PM
by OlJarhead
vents in DH kiln
Started by brdmkr on Drying and Processing
Last post April 27, 2009, 09:59:33 AM
by Ronnie Hubbell
New Kiln Build Video, Finishing up Insulation and adding the vents.
Started by 123maxbars on Drying and Processing
Last post August 21, 2017, 07:34:22 AM
by WDH
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
