Author Topic: Portable Bridges  (Read 2914 times)
Offline Wudman
  • Forester
  • Eat, drink, and be merry before you go on quota!
Portable Bridges
« on: November 12, 2019, 11:53:15 AM »
We routinely use portable bridges for stream crossings here in Virginia.  Most of my contractors have access to a set (or two).  The pictures below are crossing an intermittent stream on the skid trail.
We lay poles on the edges of the bridge to keep slash out of the channel.  These bridges can support the weight of a loaded truck on a haul road as well.  These bridges are 40 feet in total length.
Slash is added to the approaches to minimize compaction and provide for erosion control.
Here they are being used to cross a natural gas pipeline.  The pipeline company allows us to place them over the line and skid across.
Wudman
Offline Gearbox
Re: Portable Bridges
« Reply #1 on: November 12, 2019, 08:56:41 PM »
You are lucky here gas pipes they want 3 feet of fill then bridges . Thank you for using best logging practice .
Offline Ron Scott
  • Forester
« Reply #2 on: November 21, 2019, 06:23:09 PM »
That's generally the practice here also.
~Ron
Offline Texas Ranger
  • Forester
  • Texan, by God and by choice.
« Reply #3 on: November 21, 2019, 06:50:37 PM »
Loggers in Texas use oil field mats, can cover pipelines and wet ground.  Not so much bridging
Offline Randy88
« Reply #4 on: December 01, 2019, 05:19:59 AM »
Curious, what do the bridge panels themselves look like?   What do they have for gussets under them for strength?
Also how deep are the pipelines you need to have mats or bridging over to cross them, around here you can drive over any pipeline without doing anything to protect them unless they are too shallow.
Offline tacks Y
« Reply #5 on: December 01, 2019, 08:59:02 AM »
Local company here makes steel ones with guard rails. Hinged in the middle open and pin. They go all over this country.
Offline mike_belben
  • Pulp Friction
« Reply #6 on: December 01, 2019, 09:32:25 AM »
Ive hauled these out of peachland NC.  Edwards lumber off 74 makes em for "yak-mat" who is jones group out of missouri i think.
Must be pretty good as dozens of truckloads went to a project in massachusetts with $2500 freight bill per truck.
Revelation 3:20
Offline Wudman
  • Forester
« Reply #7 on: December 02, 2019, 10:21:51 AM »
The structural components of these bridges are 8" steel I-beams.  They are skinned with 1/4 inch plate.  The panels are built in 4 foot wide sections so they can be moved and placed with a grapple skidder.  The depth on these gas lines tends to vary.  Most are 4 to 8 feet in the ground, but I have seen some that were shallower.  The owner of them plays a role in the difficulty to cross.  Some companies are easy to deal with, while others take an act of congress to get across.  This particular owner isn't too bad.  They fly the line on a regular basis, so you will get a visit if you don't contact them on the front end.
Wudman
Offline Randy88
« Reply #8 on: December 03, 2019, 05:55:00 AM »
Wudman, thanks for the explanation on how the bridges are built.
As for the pipelines, that's completely different than in my state, no contact is ever needed unless your digging near one, anyone can drive over them with anything at any weight as many times as they'd like without contacting them at all.    I've got farmers routinely going over pipelines with machines in excess of 150,000 lbs and its legal to do so and unless your deep ripping fields, ordinary tillage doesn't require contact with any pipeline company.
Unless their line is less than 15 inches deep, they are not required to tell the landowner how shallow it is either, I know of three places locally a high pressure gas pipeline is above ground and exposed in farmers fields, one is even exposed in a creek, its up in the air high enough you can walk under it, has been like that for almost two decades now.
I'd be curious to know why any pipeline would care if your moving tree's across the line on a skid road in your state when these three and four axle manure tankers pulled by huge four wheel drive tractors and  the larger grain carts, some almost 1500 bushels can cross them in my state and most lines are not even four feet deep and have no issues.
I wonder if in your area there is so much rock the line is bedded in, they are concerned the added weight will cause a rock to puncture their line?
Offline OntarioAl
« Reply #9 on: December 03, 2019, 07:32:13 AM »
Randy
Your last comment hit the nail on the head.
rocks damaging the protective sheathing or penetration with a resulting big boom.
We also have issues with frost penetration so all  crossings are approved by the pipeline company .
Temporary crossings use swamp matts roads require excavation and burying the pipe in beach sand  corduroy matt on top of sand then at least 2 feet of gravel.
cheers
Al
Al Raman
Offline Randy88
« Reply #10 on: December 03, 2019, 08:19:49 AM »
So in essence the pipeline companies never installed their lines correctly and now they are passing the costs and liability of this onto those who are going to cross their lines and those states are not stepping up to the plate and addressing this issue, and allow the liability and expense to be passed onto those who need to cross the lines??
Also curious, if their recommendations are followed, and the one's crossing them pay for the added costs, if something were to happen, are those crossing them still liable, or who pays for damage??
Offline OntarioAl
« Reply #11 on: December 03, 2019, 01:18:01 PM »
They are engineered crossings put in under the supervision of the pipeline representatives (usually 2 on site ) once in place to their satisfaction its the pipelines baby
Cheers
Al
Al Raman
Offline BargeMonkey
« Reply #12 on: December 03, 2019, 10:23:53 PM »
 We have a large one about 3 miles away, I don't think its too deep, clearing contractor got it about 5yrs ago and it was hundreds of thousands not counting the cost to fix it, local FD's where very well compensated. Im working directly under the high voltage transmission lines running to just outside Albany right now on this job, they fly over checking the lines weekly and if you get close to a tower they will let you know. We are looking to buy our own 30-40' 3x section steel bridges, ive got a set of wooden 20s now that work well and have them on a job currently. We go for the yearly pipeline dinner, unless your the very basic clueless homeowner is about the only way your getting out of being hammered with fines anymore if you don't call 811, fencing contractor outside Albany pounded a post thru a fiber optic transmission line and it about put him under.
portable bridges
Started by mark686 on Forestry and Logging
Last post May 14, 2013, 07:55:35 AM
by bill m
setting bridges
Started by smwwoody on Forestry and Logging
Last post April 04, 2013, 08:50:59 PM
by gspren
Living bridges.
Started by Ianab on General Board
Last post October 29, 2011, 07:18:38 AM
by thecfarm
Anybody know about building bridges
Started by Ernie on General Board
Last post July 14, 2005, 01:32:39 PM
by MSU_Keith
