Author Topic: Any ideas on what this is?  (Read 1918 times)
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« on: November 17, 2019, 12:24:20 PM »
While resawing some stuff the other day, we pried this out of an old hand-hewn beam.  It was embedded in the surface.
It's coal black.  It barely registers on a metal detector.  Can't scratch it with a knife, hacksaw, or file.  Both ends and one face are broken.  The rest is a polished curve with small raised lines on it.  It's about 1/4" wide.  The beam had been inside a building and was in good shape.  Maybe part of an old circular sawblade?
WoodMizer LT50HDD51-WR
Lucas DSM
Online btulloh
Re: Any ideas on what this is?
« Reply #1 on: November 17, 2019, 12:28:33 PM »
Interesting.  Curious results with the file and metal detector.
Probably not of this planet.   Maybe the same material that is used in alien implants I've read about.   :D
Offline Nomad
  • Member
« Reply #2 on: November 17, 2019, 12:30:52 PM »
 :D
Lucas DSM
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #3 on: November 17, 2019, 12:41:55 PM »
Something used from a Musket as Ammo back in the Day,
Probably entered the tree first then sawn into a beam.
Always fun too investigate odd objects.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Online btulloh
« Reply #4 on: November 17, 2019, 12:47:18 PM »
The third picture down looks a bit like the base of a minie ball.  Unusual for it to be so hard, but in a pinch they'd stick anything down the barrel.
(Nomad - maybe a picture with a little more light would help?)
HM126
Offline jeepcj779
  • "Watch this" - Famous last words
« Reply #5 on: November 17, 2019, 01:20:53 PM »
Could be a rock (mineral for snobby rock collectors). Anything with a hardness above 6.5 (steel file), like quartz (7.0 hardness) up to diamond at 10.0 hardness will not get scratched by the steel file. Can't say how it got into the finished beam.
Offline jeepcj779
« Reply #6 on: November 17, 2019, 01:27:13 PM »
Might be rutile or one of the other titanium bearing heavy minerals found in NE Florida.
Offline Kainkelly
« Reply #7 on: November 17, 2019, 01:49:37 PM »
I was thinking the same thing, if you look at the bottom it looks almost as if it broke off of something.
Offline ljohnsaw
« Reply #8 on: November 17, 2019, 02:39:10 PM »
Probably entered the tree first, then sawn into a beam.
Looks like a fossilized Mastodon tooth :D
John Sawicky
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: November 17, 2019, 04:10:40 PM »
some kind of nugget :laugh:
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Nomad
  • Member
« Reply #10 on: November 17, 2019, 04:51:42 PM »
Naw, the beam was hand hewn and it was barely breaking the surface.  This got there after the beam was in use.
Lucas DSM
Offline Nomad
  • Member
« Reply #11 on: November 17, 2019, 04:53:39 PM »
Way too small to be part of a minnie ball.  Too hard, too.  Took the pics with a cell phone, so...
Lucas DSM
Offline Nomad
  • Member
« Reply #12 on: November 17, 2019, 04:55:31 PM »
Agreed.  But how do you explain the raised lines and the polished surfaces?
Lucas DSM
Offline Nomad
  • Member
« Reply #13 on: November 17, 2019, 04:56:49 PM »
Possible, but I believe this came from Ohio.  Certainly not from anywhere around here.
Lucas DSM
Offline Nomad
  • Member
« Reply #14 on: November 17, 2019, 04:59:34 PM »
Where do you find pigmy Mastodons? :D
Lucas DSM
Offline Nomad
  • Member
« Reply #15 on: November 17, 2019, 05:02:35 PM »
It certainly is broken off, on three sides.  I don't understand this.
Lucas DSM
Offline scsmith42
    • Whispering Pines Farm
« Reply #16 on: November 17, 2019, 06:32:12 PM »
It looks like a broken gear tooth to me.
Tom's 3638D Baker band mill
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: November 17, 2019, 06:45:33 PM »
Gotta be a Highly Valuable Walnut egg.  I've heard that they are as scarce as "hen's teeth".  :o
Offline Kainkelly
« Reply #18 on: November 17, 2019, 07:46:21 PM »
Must be part of a tool....
Offline jeepcj779
« Reply #19 on: November 17, 2019, 09:20:09 PM »
Actually there are several minerals that have surfaces like that right out of the ground. If it was embedded on the outside of the beam, it could have come from anywhere between Ohio (where it came from) and Florida (where I assume it was sawed last). That rock/black ceramic/mini-mastodon tooth/walnut egg could have been picked up from wherever the log was put down during handling.
question
any ideas
Started by james on Ask The Forester
Last post July 03, 2008, 09:20:43 PM
by Onthesauk
Any ideas who or how?
Started by flip on General Woodworking
Last post January 26, 2008, 06:34:13 PM
by Faron
Need ideas.
Started by Mr Mom on General Board
Last post February 24, 2006, 08:19:44 AM
by Mr Mom
Any ideas ?
Started by Fla._Deadheader on General Board
Last post July 30, 2003, 08:34:44 AM
by Bigdogpc
