Dynamic Green Products Inc.
Author Topic: How to keep the bark on the edges  (Read 785 times)
Offline shawn55
  • MN logger
« on: November 19, 2019, 10:28:56 PM »
Looking to mill some plaques for Deer/Fish mounts and want the bark to stay.  I've heard cut and mill only in the winter. Just need some help to clarify this.  Also would I have to do anything different after they are cut before I stack them to dry.
Offline Larry
    • Copas Sawmill
Re: How to keep the bark on the edges
« Reply #1 on: November 19, 2019, 10:46:40 PM »
Late winter is the very best time to cut the trees.
Another way is to soak the bark with CA glue.  Many woodturners use this method when turning natural edge bowls.  CA will stain the wood so proceed with caution.
Offline doc henderson
« Reply #2 on: November 20, 2019, 04:56:24 AM »
time of year is helpful.  cambium grows slow in winter and is more dense.  I just glue it back if it is loose or falls off.  titebond 1 inside, or 3 if it is used outside.
I had to glue the live edge bark on this 6 pack carrier.
Offline D6c
« Reply #3 on: November 20, 2019, 06:58:00 AM »
I have an old nut cracking bowl that's essentially a turned cookie with bark on...not a crack in it.  Don't know how they preserved it but could it have been something like this stuff?
The way I read it you soak it in the solution and it replaces the water in the wood so it doesn't shrink and crack.  Not sure if it'll keep the bark tight too.
Pentacryl Green Wood Stabilizer - Preservation Solutions
Offline moodnacreek
  • Sawin by the notches
« Reply #4 on: November 20, 2019, 07:57:35 AM »
Winter cut live from the stump and winter cut on the mill [same winter]. This is the always the best way to make lumber. There will be less shrinkage so less checking and very little stain. The bark might even stay on.
Offline ncsawyer
« Reply #5 on: November 20, 2019, 12:22:49 PM »
That's a lot easier for all you guys that actually have a "winter".  I agree totally.  If I am building something for myself, especially out of pine.  I cut the logs in the winter and saw the logs in the winter. This really helps on blue stain and mold. But here in NC, sometimes we don't have much of a winter, so my window can be somewhat short some years.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Offline moodnacreek
« Reply #6 on: November 20, 2019, 12:54:19 PM »
Always wondered how it works down south. My comments are from my experience in N.Y state only. I would suppose cutting in the dormant season anywhere would be best.
Online K-Guy
    • http://www.nyle.com/
« Reply #7 on: November 20, 2019, 01:40:42 PM »
It's empty now, somebody drank all the beer and didn't share, might as well throw it away. I hope you don't have surgery today!!  :D
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline moodnacreek
« Reply #8 on: November 20, 2019, 06:47:22 PM »
Some camps up north put up cedar slab siding, bark on, and put little nails in to keep it on.
« Reply #9 on: November 20, 2019, 09:36:32 PM »
if I am making rustic, I do not like to wait for glue to dry, I use my 23 g pinner to hold it in place so I can move on to the next step while the glue dries.
Offline Brad_bb
« Reply #10 on: November 20, 2019, 11:36:41 PM »
Instead of CA glue, I use a water thin penetrating epoxy. Smith's.  Smith's on Amazon
Useful to reinforce rotted wood, empregnate wood to make it stronger(like doing it in a vacuum pot).  I've painted it on bark from some barn boards that still had their 100+ year old bark on them, and it worked to keep the bark adhered.  I tried it after seeing Matt Cremona use it.  Matt Cremona video using Smith's
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #11 on: November 21, 2019, 07:04:23 AM »
Thanks for both those links Brad. Opened my eyes to something new. I plan on looking into the penetrating epoxy more, but using a vacuum system is problematic due to size (for now). Baby steps.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Bar tops with bark on edges
Started by Jim_Rogers on Sawmills and Milling
Last post March 02, 2014, 01:58:48 AM
by Brucer
Furry Edges
Started by Kingmt on Sawmills and Milling
Last post October 24, 2015, 04:20:54 PM
by Kingmt
Sharp blade edges.
Started by Grower on Sawmills and Milling
Last post September 14, 2011, 03:46:15 AM
by Grower
Do the edges touch when you sticker?
Started by brdmkr on Drying and Processing
Last post March 13, 2006, 08:00:41 PM
by Tom
