Author Topic: heavy underbrush  (Read 790 times)
Offline retiredmechanic
  • just another old fart
heavy underbrush
« on: November 22, 2019, 11:18:41 AM »
This is my first post: I hope i'm in the right thread, Thanks for the addition. my question is about extreme underbrush growth and specifically thorny vines. they are so thick in the area i'm trying to clear out that they have grown up in to the trees and choking them out I managed to pull 1 vine down and it was about 40' long and 2" thick. I cant get access to the area to use any heavy equipment so it will be all by hand I tried burning them but they will not stay lit to burn very rocky and a 30' cliff blocks equipment any suggestions would be appreciated other than  just using hand snippers 1vine at a time. there are some awesome trees I would love to maintain. they also block my view I live on a riverbank and this is my backyard would love to also be able to fish down  there.
gunfire and chainsaws is a Sunday afternoon Lullaby in the country
Offline bluthum
  • Tick magnet.
Re: heavy underbrush
« Reply #1 on: November 22, 2019, 04:40:48 PM »
Just cut the vines off at ground level, I never pull them down   they will dry out and gradually disappear. Smaller vines I use a lopper on, mid size a hatchet or machete and the biggest ones get chain sawed. Burning works great but is tricky to get right, it can't be too dry or too wet, etc.
Offline Okefenokee_D
« Reply #2 on: November 23, 2019, 05:08:20 PM »
Roundup makes some herbicide that is ok to use around water. I know lots of people do not like to use herbicide like that, but unless if you can find a more natural herbicide then that may be your only choice.
Burning will help, but be sure to make a firebreak to mineral soil or a wet line
Offline btulloh
« Reply #3 on: November 23, 2019, 05:13:40 PM »
Cut the vines, treat the cut end immediately with something that contains triclopyr.
HM126
« Reply #4 on: November 24, 2019, 11:10:53 AM »
these are all good suggestions but I need to add a point there are like tens of thousands  of these vines it is EXTREMELY THICK and is impossible to walk through they run everywhere and the bulk of the base is about three feet high the area is about 50 ft W x 200 ft L using clippers would take me 2 years to cut through them burning didn't work amd a steel blade brush cutter just got tangled up with the vines wrapping around the shaft  it's a dillema for sure I wish I had pics but you cant get a pic until you get through the first layer it's like a wall of thorns and somehow the feral hogs have made a den in there
Offline btulloh
« Reply #5 on: November 24, 2019, 11:26:34 AM »
Ah.  Sounds familiar.
I had a similar situation. Ended up hiring a forestry mulcher. Cleaned it up and looked like a park. Best money I ever spent. Took one day.
« Reply #6 on: November 24, 2019, 01:23:43 PM »
to be certain,  what is a "Foresty Mulcher" person or machine?
Offline btulloh
« Reply #7 on: November 24, 2019, 01:46:49 PM »
Offline lxskllr
  • dummy with saw
« Reply #8 on: November 24, 2019, 03:50:51 PM »
I've been working on the farm at work. I use a brushcutter and small chainsaw. The brushcutter takes care of the small-midsize stuff, and the chainsaw for the bigger stuff. It's an ongoing job, and will likely go on as long as I feel like doing it, but it gets a little easier each time as the old growth gets thinned.
Offline square1
« Reply #9 on: November 25, 2019, 06:03:25 AM »
I guess it depends on if you have time or money. You are going to have to invest one or the other.
I've spent nearly 10 years cleaning up ~25 acres of neglected woods. I get great satisfaction from the time spent. To this day it's still a work in progress.
Thinking back.. the worst days of cleaning up those woods are still better than the best days at my day job.
Offline samandothers
« Reply #10 on: November 25, 2019, 09:58:07 AM »
I use an Echo PAS to clear thick brush I can not get the bush hog or grapple to.  I use the chain saw trimmer attachment.  It has a 10" bar. The ability to be back away from the trimmer head keeps most of the green briars from coming back on me.  I cut the bittersweet (vine) at the ground and up high taking a section out of it.  these vines can be 2 inches or better.  With briar patches I can cut vertical and horizontal and slash the stuff to get through it.  I have tried a brush cutter head but did not have as much luck.
As stated before I too don't pull it out of trees as it is wrapped up in them like a rope and can lead to a head ache if not careful.  They will die and dry out.
Best of luck.  BTW, welcome to the Forum
Offline btulloh
« Reply #11 on: November 25, 2019, 10:22:03 AM »
Small mulcher. Never saw one of the before. Small mulcher
Skid steer mulcher. Skid steer
« Reply #12 on: November 25, 2019, 11:00:03 AM »
I wish I could get a brushcutter in there but there is no way for access coming off the 30 ft cliff sounds like I will just have to wait until a very dry summer and come up from neighbors land up the riverbed when it's almost dry (Life on the Kiamichi River) https://en.wikipedia.org/wiki/Kiamichi_River I built a rock staircase down the wall then hit the THORNS now I wish I had made the rock path wider It will be an awesome place If I ever manage to get it fully accessible from the cliff there is about 40 ft to the water edge for excellent fishing this river is the only river in Oklahoma that hasn't been touched by development it's all natural Thank GOD
« Reply #13 on: November 25, 2019, 11:18:15 AM »
i REALLY LOVE THAT WALK BEHIND... I could have it lowered if it isn;t to heavy Thanks for the awesome video demonstration That is exactly what I need . how is it on slopes though or rocky terrain the rocks are app 2 ft above ground to 6 ft diam. dlope is pretty steep in places I would hate to have it push me in the river or worse get away and fall in the river LOL
« Reply #14 on: November 27, 2019, 05:35:24 PM »
Sounds like herbicide is the only way if you can't burn or get equipment in there.
Offline Klunker
« Reply #15 on: December 10, 2019, 10:51:36 PM »
Goats will clear under brush.
There are firms that will come into your place with their goats and  let them browse.
Offline thecfarm
« Reply #16 on: December 11, 2019, 05:51:22 AM »
That walk behind is a nice idea. Much better than my mini bush hog,a push lawn mower. :D ::) I've been clearing steady for 20 years. The more I clear the more I have to keep clear. But this is on a small scale.
Clearing out the underbrush
Started by bigtreesinwa on Ask The Forester
Last post August 08, 2008, 10:26:11 PM
by Brian Beauchamp
Advice on Cutting Out Underbrush (smaller trees on 10 year old clear cut)
Started by H60 Hawk Pilot on Ask The Forester
Last post January 26, 2010, 10:54:42 AM
by SwampDonkey
Too Heavy ??
Started by Magicman on Sawmills and Milling
Last post December 16, 2017, 01:45:31 PM
by Magicman
Uh-oh Log too heavy?
Started by Qweaver on Sawmills and Milling
Last post August 10, 2010, 11:27:46 PM
by carykong
