Dynamic Green Products Inc.
Author Topic: would like some advice  (Read 1333 times)
Online Southside
    • White Oak Meadows
Re: would like some advice
« Reply #20 on: November 29, 2019, 11:33:58 PM »
If regrinding is not a viable option then I would use them in cedar, or if you have that "suspect" log that just has to be sawn and the odds are decent of finding hidden treasure then open them up with a band that has no real other value to you, nothing to loose if by chance you do strike gold, or iron, steel, ceramic, etc.
Offline loghorse
« Reply #21 on: November 30, 2019, 09:43:41 PM »
if you use 4 degree for just red oak ,what wouid your set be?
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #22 on: December 01, 2019, 08:31:06 AM »
25 thou would be fine for a start, that's about where I set all of mine.  You can go more, you can go less, but .025" per side works fine.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
New Saw Advice
Started by oregon101 on Chainsaws
Last post March 12, 2008, 05:56:26 PM
by SawTroll
Need some advice
Started by Woodwalker on Drying and Processing
Last post April 23, 2007, 08:01:46 PM
by Woodwalker
Advice please.....
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post October 26, 2011, 12:23:41 AM
by Brucer
Need Advice, I'm New!
Started by BCrabtree on Sawmills and Milling
Last post February 08, 2014, 02:52:55 AM
by customsawyer
