Author Topic: Resawing 6/4  (Read 1153 times)
Offline Pepe_Silvia
Resawing 6/4
« on: November 27, 2019, 05:57:41 PM »
A guy contacted me about having a load of 6/4 x ~20" x ~10' oak boards resawn into two halves, 3/4 each minus the kerf.  Is this a bad idea for one or both of us?
It would be done on an LT15Wide.
Offline scsmith42
    • Whispering Pines Farm
Re: Resawing 6/4
« Reply #1 on: November 27, 2019, 08:10:41 PM »
If the oak is fully dry it may be much more difficult than if it were green.
I used a dedicated resaw with a carbide tipped band for resawing dry oak.
Tom's 3638D Baker band mill
Offline DPatton
    • D & S Sawmill Services
Re: Resawing 6/4
« Reply #2 on: November 27, 2019, 08:21:28 PM »
My experience is most 6/4 lumber that has had a chance to dry will no longer lay perfectly flat on the mill, thus creating variation in thickness when attempting to saw it into two or more boards.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Online JoshNZ
Re: Resawing 6/4
« Reply #3 on: November 27, 2019, 08:24:42 PM »
Why don't we use carbide tipped bands for general milling?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Resawing 6/4
« Reply #4 on: November 27, 2019, 08:42:33 PM »
That is asking for heartache.  First off, don't believe the mill can cut that low without raising the boards off the bed by laying some plywood or some such on the mill bed first.  Then, the stresses that you relieve when splitting the 6/4 is going to make some of the pieces unusable, think potato chip.  Unless you like to push yourself and your equipment to the limit, and maybe even damage your mill, I would not do it.  Sometimes it is better to just say no.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Resawing 6/4
« Reply #5 on: November 27, 2019, 09:09:07 PM »
I have tried to resaw on the mill, it didn't work too well for all the reasons people have said.  The only way I have really gotten it to work was the one time I had my wife stand on the board and walk on it to keep it flat while I was sawing.
For some reason, we stopped doing it that way. :D :D
HobbyHardwoodAlabama.com
Offline 123maxbars
    • www.outofthewoodsforestry.com
Re: Resawing 6/4
« Reply #6 on: November 27, 2019, 09:10:47 PM »
I did my first and last resaw job two weeks ago, what a pain, I charged by the hour and still didn't feel like I got my worth, never again,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Resawing 6/4
« Reply #7 on: November 27, 2019, 10:13:03 PM »
   Said the man with the one legged wife... :D
   When I saw the OP I was thinking by the time you remove the kerf you are looking at 2 - 11/16" boards. Sounds awful risky especially with 10" oak boards.
   I occasionally resaw a slab I cut too thick to salvage another 4/4 board I left in it. As often as not I regret it after as lots of times the slab lifts off the rails giving a thick and board and a 50/50 chance I will knock the set off my blade.
Offline Southside
Re: Resawing 6/4
« Reply #8 on: November 27, 2019, 10:20:07 PM »
I have my 35 set up as a dedicated re-saw, wide and dry always results in problems / complications.  I don't think I would do that job as the results are likely to disappoint the customer.
Offline barbender
Re: Resawing 6/4
« Reply #9 on: November 27, 2019, 11:13:06 PM »
I'd agree with everyone on the wide boards being sawn thin causing problems. Where I would differ is the resawing method. If you are clamping boards to your bed and sawing them one at a time, it's a good way to cause insanity. Build a jig with hold downs or a weighted wheel. Push the boards through the head like you would with a table saw, it goes fast and works awesome. Do a forum search for the Arky Resaw. Simple, cheap and effective.
Offline Brad_bb
Re: Resawing 6/4
« Reply #10 on: November 28, 2019, 12:00:33 AM »
Agreed, I would not take that job.  I would explain to the customer the perils of trying to do that.  If you think you're doubling your board coverage, you're wrong.  You'd have a lot of loss.  You're 6/4 are not flat to begin with.  Since they are wide, they should be flattened first.  By the time you do that, you now have probably 1"- 1 1/8" slabs.  You might might as well plane them to 3/4 if that is what you want.  If you try milling them, they could curl due to residual stress as has been mentioned.
About two years ago, I had to do some resawing(for myself).  I had to weight the boards down to keep them flat on the mill while I sawed so that they would be sawed evenly.  In this case, it didn't matter if the final board was bowed as it would be screwed in place as a trim board.  In your case, it's a wide board, that you need flat.  It would not go well at all in my opinion.  Planing it to 3/4 would be much better bet.  You're not going to get two boards from one, but you'll get one good one.
On the second page of this thread I have a video of how I was resawing.
My resaw thread
Offline longtime lurker
Re: Resawing 6/4
« Reply #11 on: November 28, 2019, 03:58:07 PM »
It's a job for a (vertical) band resaw with a hob feed.  The feed rolls press the board into the fence and holds it and you get a uniform thickness regardless of any movement in the timber or curvature in the feedstock.
I'm the champion of workarounds for want of the right equipment - but for this job theres no really satisfactory way of doing it right without the right machine.
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: Resawing 6/4
« Reply #12 on: November 28, 2019, 05:34:03 PM »
You could offer to do several of them for him and see how it works out.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Chuck White
  • Sawing Mobile since 2005
Re: Resawing 6/4
« Reply #13 on: November 29, 2019, 07:27:40 AM »
Might be a good idea to let the customer know some of the things that "could" happen when taking on a project like that, with no guarantees!
Wood can change it's mind, half way through!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Resawing 6/4
« Reply #14 on: November 29, 2019, 07:51:41 AM »
I just did 4" ash into 2" ash. They were 14" wide. He was hoping to get 1.75"  when he finishes. He will not get full length, as some are a little skinny now before he planes.
I wish I had straightened them first with the carbide blade,  then he would have got a nice 1.5" but he did not want that. I think he will now. :o
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: Resawing 6/4
« Reply #15 on: November 30, 2019, 05:14:07 AM »
     I've done that before with mixed results, and usually not good.  Got one coming up with a bunch of old full 2" pine he wants sawn in half.  I explained in detail until I was blue in the face that it's not a good idea and why, but he insists he wants to try anyway.  So...
     The one time I did it and it really worked well was with 4/4 cypress using an Arky resaw jig, but it was very well cut, not very wide and it was cypress.
WoodMizer LT50HDD51-WR
Lucas DSM
Offline Andries
  • Making buildings out of big curvy logs
Re: Resawing 6/4
« Reply #16 on: November 30, 2019, 06:02:50 AM »
I was asked to resaw pine 6x7 beams into 2x6 framing studs, a few weeks ago.
The pine was old and frozen, but a four degree band worked well. We did a truck load and anther order is coming in a few weeks.
This goes against all the advice given above, but it's what worked up here in the Glaciated North Country.  😆
If you've got the time and inclination, experiment a bit.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline millwright
Re: Resawing 6/4
« Reply #17 on: November 30, 2019, 07:48:30 AM »
I re-sawed some red oak 3x16x 10 that was about 20 yrs old. Did it on lt35. I had to weight it down then take a skim cut to flatten it. Then flipped it over and got a couple of 4/4 boards from each one. Most came out good, but some went several different directions. Had to go really slow, took a long time
Offline Deese
Re: Resawing 6/4
« Reply #18 on: December 02, 2019, 08:43:20 AM »
I always tell them only to expect one decent board from each one put on the mill. It makes me cringe thinking of resawing dry oak that wide. My hourly rate would probably be higher than the customer would be willing to pay. Very time consuming! Not fun!
2004 LT40 Super 51hp diesel
Cat Claw sharpener/Single Tooth Setter
Stihl chainsaws MS880, 661, 440, 250
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Last Summer Was HOT.
Re: Resawing 6/4
« Reply #19 on: December 02, 2019, 08:52:26 AM »
It all depends on how the resawn wood is going to be used.  If he's making pencil boxes or going to machine it to 1/2-9/16 and staple it to the wall is different from expecting more.
Resawing
Started by jim king on Sawmills and Milling
Last post May 03, 2010, 12:20:00 AM
by Meadows Miller
Resawing 4/4 walnut.
Started by firefighter ontheside on Sawmills and Milling
Last post May 16, 2018, 10:10:39 AM
by Magicman
Resawing Blades
Started by Shawn on General Board
Last post November 23, 2005, 04:57:03 PM
by iain
What is the best bandsaw to get for resawing?
Started by oakiemac on General Woodworking
Last post January 25, 2013, 06:37:50 PM
by Clark
