Author Topic: Rocky Mountain Front  (Read 1254 times)
Offline tule peak timber
  • The Wizard of Crap
    • tule peak timber
« on: November 29, 2019, 11:36:59 AM »
So two days ago a weather front came through the Rockies shutting down airports and roads and I'm fishing for trout-no matter what.When it hit full force it was like a wall of weather with snow, high winds, and 9-11 degrees temp.I had to quit and hole up in a bar along with a bunch of local hunters buying each other drinks.By 10 AM I was not fit to tie a knot .
  Lots of offers to stay in folks homes as the roads were closed back to the Great Falls airport. Terrific bunch of people in that neck of the woods for sure.
  Like an idiot I chose to jump in my car and many hours later , after seeing one or two other cars in 80 miles, got back to my hotel in white out conditions.
  I had lots of 15 inch fish and one at 26 inches and farmed an even bigger one that at least I got to see. I learned a great deal about stream fishing when it is cold- guides/lines freezing and everything I touched sticking to my fingers.The biggest problem for me was snow covered boulders on the climb down to an invisible water's edge- lots of bumps and bruises to say the least.Slow going and very tricky......
  Not my first trip to the Front and I will return in April to get the big one that got away.
After some wicked weather in Montana I come home to this...LOL
Offline sawguy21
Re: Rocky Mountain Front
« Reply #1 on: November 29, 2019, 12:09:04 PM »
Glad you made it in spite of some poor choices. :o My rods are put away for the winter, I don't fish when I have to break ice out of the tip.
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #2 on: November 29, 2019, 02:26:47 PM »
Ahhh, very nice fish, cold weather fishing is tough.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #3 on: November 29, 2019, 06:18:35 PM »
Sounds like a blast!  I've got to ask, is the mounted cougar in the bar or decor in the cabin you were staying in?
Say when
Offline nativewolf
« Reply #4 on: November 29, 2019, 06:23:34 PM »
I guess after the droughts that white stuff at home was at least a form of moisture, much needed.Fires are out for the season in CA it seems.
Liking Walnut
    • tule peak timber
« Reply #5 on: November 29, 2019, 07:10:30 PM »
The cougar and elk mounts are at the Sun Canyon lodge , where I ate breakfast-close to the continental divide.I stayed in Great falls so I could range east as well as west in search of trout. The Buckhorn in Augusta is a focal point for hunters and I dropped in several times keeping my ears open........  Last  September I went North and South in this area looking around.Only 4 days this trip but a lot of ground  covered. I had a 15 inch brown 30 minutes out of the airport.
  Both trips were a blast I love the area.I'm the only guy in eye shot for a hundred miles stalking streams, the locals find me amusing at best in this weather.Trout fear me.......
   My goal in life is to buy a section of land in this area, with water, and go out of this life in the gut of a Grizzly.
    • tule peak timber
« Reply #6 on: November 29, 2019, 07:22:32 PM »
Yes we welcome all moisture no matter what. We have had precious little this year.
Offline Roxie
  • Gender: Female
« Reply #7 on: December 01, 2019, 09:09:28 AM »
So, 'A River Runs Through It' and 'Legends of the Fall' about sums it up.  :)
Say when
Offline Skip
  • Saw hard or stay home.
« Reply #8 on: December 01, 2019, 09:17:53 AM »
Fly or spinning gear ? Love it !! ;D
Offline doc henderson
« Reply #9 on: December 01, 2019, 09:24:10 AM »
so when you cannot tie a knot, you "tie one on"!  looks like a real adventure.  glad you are home safe.
    • tule peak timber
« Reply #10 on: December 01, 2019, 10:43:04 AM »
I want to buy a second home in N.Montana and all my friends tell me that I'm not not going to be able to handle the weather. To a great degree --they are right . I had an absolute blast and learned a great deal. There is no way I'm going to load in if I don't see the place in winter and understand what I'm getting into.
   Not enough unfrozen surface to cast lures so I just stuck to worms and drifting down current under the ice edges.
  I was a commercial fisherman for quite a while and the adventure part of this trip reminded me of Alaska long lining in the winter, exhilarating and alive.
  A curious effect is that in low temps and high winds there is good traction on the roads-but you just cannot see anything ahead.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #11 on: December 01, 2019, 11:21:41 AM »
We play in the same backyard Rob.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
    • tule peak timber
« Reply #12 on: December 01, 2019, 11:46:10 AM »
Slow--steady---and live to tell the tale ! Be careful out there :)
Offline sawguy21
« Reply #13 on: December 01, 2019, 11:53:02 AM »
I don't miss that!!
Online Southside
    • White Oak Meadows
« Reply #14 on: December 01, 2019, 01:20:33 PM »
Man that's a lot of sawdust blowing around - must be a really large mill there..... :D
White Oak Meadows
Offline barbender
« Reply #15 on: December 01, 2019, 01:29:01 PM »
One thing I've noticed out in the mountain west, that is very different than Minnesota- the climate and weather can vary a LOT depending on your location. I know some of the valleys, even up into Montana, can have pretty mild winters (this is relative, I am from northern MN😁). But the weather can also be more severe, what we call a blizzard here would often go unnoticed out West. Maybe you should come spend a winter with us up in MN, then everywhere else (except maybe the North Slope😁) will seem kind of mild😊 Oh yeah, "It was a good death."😉
Offline Gearbox
« Reply #16 on: December 01, 2019, 07:21:43 PM »
I have been over Rogers many times . I like the area around Lincoln best .
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: December 02, 2019, 08:51:44 AM »
There is no way to not have an enjoyable time in Montana or any of the West-NW.  Bad is good and I guess that worse is even better.  I did find out in October, 1973, that even a simple mistake can/will get us Southern Flatlanders in serious trouble.  It's not the same game and the Rockies have their own rules.  :-\
Offline K-Guy
    • http://www.nyle.com/
« Reply #18 on: December 02, 2019, 10:04:58 AM »
I knew a couple spots outside of Enderby, BC where I could go in the winter to fish streams. Generally they have mild winters there and sometimes the fishing wasn't bad but mostly small rainbows 6-8 inches long. But my worst day of fishing still beats my best day at work!!
Andries
I remember being out in Winterpeg (Winnepeg for the rest of you. ;D) and driving in that stuff around there.
Whenever you get out into the real wild areas, you have to remember you are now playing by natures rules and Mother Nature has a steep learning curve. :D
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline reride82
« Reply #19 on: December 02, 2019, 12:06:55 PM »
Looks like you had quite the time Rob! :D That was a fun storm for sure, I made a round trip to Lewistown(Central MT) Wednesday Afternoon through Thursday night. What usually takes 3.5-4 hours, took most of 6 hours.  I love the Gibson Reservoir/Sun River/ Bob Marshall area! I haven't done it yet, but you should look into the South Fork of the Flathead River float. Either hike or pack into the upper basin and float/fish your way out. Beings it is a wilderness area there isn't any motorized traffic which reduces the fishing pressure. Basically, its 40 miles of the best cutthroat fishing in Montana. You should also give the Big Hole River and Clark Fork River a visit as well :D Just remember, Winter isn't always done in April up here ::)
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Rocky Mountain Elk Foundation
Started by Autocar on The Outdoor Board
Last post March 24, 2011, 02:06:39 PM
by Fast Randy
Rocky Mountain Oysters
Started by Mooseherder on FOOD! FOOD! FOOD!
Last post February 18, 2014, 02:21:12 PM
by Magicman
Rocky Mountain trout
Started by tule peak timber on FOOD! FOOD! FOOD!
Last post November 11, 2019, 07:53:03 PM
by tule peak timber
Rocky mountain spotted fever
Started by yukon cornelius on Health and Safety
Last post November 08, 2018, 05:26:10 PM
by Bruno of NH
