Author Topic: good day  (Read 1672 times)
Offline trimguy
good day
« on: November 29, 2019, 08:21:48 PM »
in another thread I was having issues with my saw and got it worked out. I had about 7 hours uninterrupted at my homemade sawmill and had a great day.feel free to snicker and chuckle but this was my best day so far. my mill is manual.
 and I joined this club shortly after I finished my mill. but I guess my membership was due. ;D
Offline Chuck White
  • Sawing Mobile since 2005
Re: good day
« Reply #1 on: November 29, 2019, 08:38:51 PM »
Looks like your had a very good day, except for that one oops!  :embarassed:
Most of us have been there and done that!  ;)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Southside
Re: good day
« Reply #2 on: November 29, 2019, 08:47:13 PM »
There are two types of sawyers, those who try to cut off a piece of their mill with the band, and those who lie about not doing so.  Welcome to the other side.  :D
Offline WV Sawmiller
    • Green's Sawmill Services
Re: good day
« Reply #3 on: November 29, 2019, 08:49:31 PM »
Most of have been there and done that!  ;)
Some more than once - Not that is has ever happened to me, of course. :D :D
Congratulations Trimguy. Keep up the good work. Every day and every log is a new learning experience.
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: good day
« Reply #4 on: November 29, 2019, 09:18:57 PM »
When I was racing motocross and got a new helmet, the first thing I did was drop it to put the first scuff in it without my head in it. Was supposed to be good luck and keep me from crashing. Must not have helped me though, the announcer didnt call me by my number (22), instead called me BBB Bales, bails bad. Hopefully taking a bite of your side support will be your new helmet drop and bring you some luck.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
Re: good day
« Reply #5 on: November 29, 2019, 11:58:13 PM »
That's one way to check if there's any teeth with too much set ;)
Time to build a blade guard. I built one for mine to stop carriage travel (push feed) if the blade is less than 1/4" above a stop. When I bought my mill summer before last, I eventually noticed it had cuts near the top of all three stops. I ground them out and welded them in and also made and added a fourth stop this past summer. I also marked my stops so I know what height I must not go less than when I set them. I have hit metal, but it's been nails.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Old Greenhorn
Re: good day
« Reply #6 on: November 30, 2019, 06:06:17 AM »
Congrats. There are few better feelings than a good day of sawing! I can't wait to get back on mine. Looks like you have some good work to start working with.
 As for your 'stop encounter', that could never happen to me. Well not in a very long time. well maybe not a 'very' long time, but a long time. OK, it was 2 weeks ago, but that's a pretty long time, isn't it? :D ;D
 Have a great time with the mill, looks like you have many more hours of joy in front of you.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Offline ManjiSann
  • Doing more with less because I can't afford more;)
Re: good day
« Reply #7 on: November 30, 2019, 07:57:59 AM »
Nice boards!  Keep up the good work!
Brandon
Poulan Pro 5020AV, Husky 390XP
Online Nebraska
  • I'm new! Lurked for quite a while, learning !
Re: good day
« Reply #8 on: November 30, 2019, 09:42:18 PM »
Well you got more sawn today than I did. Looks good.
Offline Iwawoodwork
Re: good day
« Reply #9 on: December 01, 2019, 12:55:21 AM »
Kbeitz has a picture in his gallery of what he added to his mill to prevent sawing the backstops. He built a metal arm that reaches out over the blade inline with the backstop, looks like an easy fab job.
Offline jmouton
  • never enough time
    • Log-Gistics
Re: good day
« Reply #10 on: December 02, 2019, 07:33:53 PM »
boy that wasnt even close,,,,,  we have done it too
lt-40 wide ,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,066,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline trimguy
Re: good day
« Reply #11 on: December 08, 2019, 06:47:17 PM »
I will just add to this post instead of starting a new one. I had to relocate my mill to another field where there was more logs piled up.i got it set up and ready togo. I layed out and leveled cement blocks for 5 air drying stacks [ i'm glad that's over. I was dreading it. all I want to do is cut wood]. I also built a couple of pallets to stack lumber on to set on the blocks. I did get to cut 4 logs . 8)   everything went great and I didn't hit any metal. :D. so everything should be ready to just cut next time I get a chance go back up there. hopefully that will be next weekend, you know, that whole work thing. also wanted to say, since I've joined I have gotten better with the computer but, I don't know if this forum is a blessing or a curse ? I have my mill straightened out and its cutting great. on the other hand I "had" to up grade to a Logrite 60" cant hook and a hookaroon. I need a hydraulic mill, I need a sawmill shed, I need a drying shed, I need a kiln, I need a blade sharpener, I need more wood working tools. :D really its all blessing ! looks like I'm in for the long haul with this hobby. oh yea, I need more time.
Re: good day
« Reply #12 on: December 08, 2019, 07:23:43 PM »
   Thanks for posting more. As to the shed and such that is typically one of the first things many of us build/built when we got our mill. it is a great way to use your practice lumber and cut an assortment of framing and sheeting lumber. Since it is for your own use you know what is acceptable whether a cosmetic issue interferes with use for its intended use, etc. I used my practice lumber to build a lumber storage shed and it still includes the longest lumber (20'6" headers) for a couple of the bays on my shed. I built 2 bays then realized I had enough room and used roofing left over to build another bay. When I built it I was worrying about how to join/add on to the end and realized it was much simpler to just cut an additional 14' 2X6 rafter than try to move the old one. I realized then it was a lot of fun not having to worry that much about wood cost - if you need another board just cut it. Keep us posted.
Offline trimguy
Re: good day
« Reply #13 on: December 08, 2019, 09:17:03 PM »
a saw mill shed is my next project. that's what part of the lumber is for out of the logs that I need to cut up.can I ask what you used for a header ? I think I wanting my opening to be 24' with knee braces [I think that's the right term] to cut the span down to 16'. I was thinking 3- 2 x 10's . 2 x 6 rafters for a shed roof 12' wide and 2' over hang front and back. strip the rafters with 1 x 6's and tin on the roof. no snow load . any thoughts ?
Re: good day
« Reply #14 on: December 08, 2019, 09:40:11 PM »
    I built mine out of poplar. Made them 2"X12"X20.5' . Each bay is about 12' X 18'. I later added shelves but I use mine for lumber not equipment storage. I used locust poles for uprights and squared the sawed surfaces on the mill. I used 2X6's 14' long for rafters and got used roofing off a barn being torn down. I don't have over $500 in this shed and that is mostly the roof and nails.
   I don't know how you'd brace a span as long as what you are describing. The 1X sheeting I put on my corners at 45 degree angles gives me a lot of extra strength. I'd use 2X12 instead of 2X10's. When I added the 3rd bay I scabbed on and bolted the 2X12's together with other 2X12's on the front and back and several feet of overlap. How tall do you plan on making it? I would think the taller you make it the easier the bracing becomes. I'd think you'd want the low end of the braces to be 6' or more off the ground. With no snow load you won't have the same issues I do but mine has stood up well so far. How about wind issues in your area?
   Any reason you can't put extra uprights on the back side? I did on mine because I only needed the wide width on the front on mine.
Online Nebraska
Re: good day
« Reply #15 on: December 08, 2019, 09:51:36 PM »
The saw dust addiction is strong. Spent quite a bit of today stacking lumber getting ready for real winter. I didn't have to build my wood shed just had to clean it out and evict the possums. There are some structural calculators for beams on the forum if you look in extras up top, and lots of experience in building things in the timber framing that's where I'd ask. I've been going through the I need to get/find/buy stages as well, I think it's a pretty symptom with the disease. @WV Sawmiller  I really like that shed if I've never mentioned it before.
Re: good day
« Reply #16 on: December 08, 2019, 09:57:10 PM »
I too suffer from shed envy, but I don't know if that one would handle our snow loads. Still, after spending an hour shoveling a foot of snow off my stack today, most anything would be better.  ;D :D
Offline Peter Drouin
    • A&P Saw mill LLC
Re: good day
« Reply #17 on: December 09, 2019, 01:00:20 PM »
How I started, no roof.
Then this.
Then on and on,  :D :D :D :D ::)
A&P saw Mill LLC.
License NH softwood grader.
Re: good day
« Reply #18 on: December 09, 2019, 04:27:13 PM »
   And you know what - I bet is still isn't big enough! :D
Online btulloh
Re: good day
« Reply #19 on: December 09, 2019, 04:35:09 PM »
 :D  Right.
No shed has ever been big enough.  :D
HM126
A good hearty soup receipe that warms up the next day good.
Started by luvmexfood on FOOD! FOOD! FOOD!
Last post October 19, 2014, 11:32:50 AM
by luvmexfood
Good Timber Sales, Good Forest Management
Started by Phorester on Forestry and Logging
Last post February 28, 2005, 01:17:50 PM
by Doc
good family fun! and soon to be good eatin
Started by sandsawmill14 on General Board
Last post June 15, 2015, 09:20:48 AM
by Magicman
9 Good Fingers and 1 Not so Good
Started by Wudman on Health and Safety
Last post March 18, 2019, 12:01:19 AM
by samandothers
