Author Topic: LT15 Wide  (Read 343 times)
Offline charles mann
LT15 Wide
« on: November 30, 2019, 11:21:38 PM »
i plan on buying the 15 wide after i get my wide mill build finished. if previously owned a 15 series mill and upgraded to the wide, how is the cut performance between the wide and the previous 15 series models?
Temple, Tx
Re: LT15 Wide
« Reply #1 on: November 30, 2019, 11:26:12 PM »
@booman instead of hijacking the other LT15 topic, i figured id start a new query, in addition to asking you direct since you own the wide.
thanks for insight you can provide.
Temple, Tx
Offline booman
Re: LT15 Wide
« Reply #2 on: December 01, 2019, 06:16:04 AM »
Before I bought the Wide, I was concerned about two things.  Will it cut flat and will the 25 hp be enough.  I did some research on fitting a higher hp engine on the Wide.   The muffler placement was always a problem.  So I stuck with the stock 25 hp Kohler.   It has performed just fine, even in full wide cuts and I cut a lot of mesquite.  The cut has also been flat but I always try to have a sharp blade on when cutting full width.   The cutter head also feels more rigid because of the extra carriage rollers on the outside beam.   The main beams and cross bunks have also been upgraded to heavier gauge metal.  Hope this helps.
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
Re: LT15 Wide
« Reply #3 on: December 01, 2019, 10:25:46 PM »
It helped a good bit. The wide may be to wide since ill already slabbing mill, but im not gonna stress those big bands for less than 30, but i also would have to see a 16-28 tree go to the burn pile.
Temple, Tx
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
LT15 vs LT15 wide?
Started by gump on Sawmills and Milling
Last post January 29, 2019, 07:43:56 AM
by randy d
Soon to be new LT15 Wide owner
Started by Smithkp on Sawmills and Milling
Last post August 07, 2018, 06:16:28 PM
by SawyerTed
