Dynamic Green Products Inc.
Author Topic: Turbo 747 Blade Question  (Read 828 times)
Offline Tarheel
    • Fireside Farm and Sawmill
« on: December 13, 2019, 10:56:08 AM »
Hi y'all,
I just bought a new LT40 wide with 38HP Kohler engine. I'm running the 747 Turbo blades and I'm getting significant rippling on the board surface. Am I going too slow? My mill has 4 hours on it, so the blade tension has been recently set, and I've only tested it out on 34" wide maple and resawing 24" wide dry white oak.
For reference, for the last eight years, I've run a 1994 LT40 with 4 degree blades and have not had many rippling issues. I definitely learned my pacing from that machine. On the new machine, I was instructed to pace myself by listening to when the engine has a little pull on it and hold it there. With that 34" wide maple, though, when I got rippling on the surface, it's hard to believe that I would still need to speed up to twice the speed I was used to on my old machine.
Any advice welcome. Thanks!
Online Bruno of NH
Re: Turbo 747 Blade Question
« Reply #1 on: December 13, 2019, 11:03:08 AM »
I have the same mill and run the 747 and 7 turbo
I get the same ripples
I still run 4 when I'm doing some high end slabs.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: December 13, 2019, 12:38:39 PM »
What thickness are the bands?
When I ran .045 Turbos on my 40, the finish was not acceptable.
When I switched to .055 Turbos the finish was significantly better and is my standard band now.
I had a box of 747 x .055x 1.5 x 195 delivered a couple days ago, and will run them next week, in some maple and walnut.  See how they do.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: December 13, 2019, 12:46:06 PM »
I will be interested to hear . So far Ive only used 1-1/2 055 195 turbos on my new mill. Yesterday a bunch of 30-34 wide cuts in RO and maple, frozen. Very smooth but when starting to dull really wide will bog down 55hp if not careful. Dont want to add another blade profile but if 747s can go faster I might.
Online Bruno of NH
« Reply #4 on: December 13, 2019, 12:56:45 PM »
YH
The 747 in .55 do cut much better
I only have 5 at the moment and they are at Resharp
My others are .45
Offline Tarheel
« Reply #5 on: December 13, 2019, 01:38:50 PM »
Thanks for advice. I spoke with someone at Woodmizer who said that washboarding can occur with the 747s on wider hardwood slabs. He also recommended leaning into the speed a little more. I was running the .045 x 1 1/4 x 171. I ordered some 4 degree blades just to have for wider hardwood cuts and a smoother finish. Glad I caught it before a client comes next week to resaw a kiln-dried curly walnut beam for veneer!
Problem with the Wide Head Turbo 7 Blade
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post September 28, 2019, 03:36:40 PM
by millwright
Double Hard Turbo 7 verses Bi-Metal Turbo 7
Started by Beavertooth on Sawmills and Milling
Last post July 04, 2017, 09:01:19 AM
by petefrom bearswamp
Blade question
Started by sawyerkirk on Sawmills and Milling
Last post January 27, 2004, 04:54:15 PM
by dutchman
I have a Blade Question
Last post October 18, 2018, 06:45:18 PM
by curved-wood
