Author Topic: Norwood Blades  (Read 608 times)
Offline sawwood
Norwood Blades
« on: December 16, 2019, 04:32:58 PM »
There is a set of blades for sale here in town but they are 13.5 long. our Norwood we have been
 using 144, those with Norwood mills do you think 13.5 will fit ?
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline armechanic
Re: Norwood Blades
« Reply #1 on: December 16, 2019, 04:43:40 PM »
  I wouldn't think they will work.   13.5 = 162  and you use 144.  I would bet that is too much difference.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline hamish
Re: Norwood Blades
« Reply #2 on: December 16, 2019, 05:41:56 PM »
Norwood uses two different bands dependant upon the mill 144" and 167".
So no they aint gonna work without be rewelded.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline Woodpecker52
Re: Norwood Blades
« Reply #3 on: December 16, 2019, 06:01:41 PM »
Order from cooks or woodmizer etc.  Never fool with other peoples blades.
Offline sawwood
Re: Norwood Blades
« Reply #4 on: December 16, 2019, 07:12:57 PM »
I bought the blades, there Wood-Mizer. they where 10 blades for $50 so could not go wrong. Will have to have Wood-Mizer resize them.
 Sawwood
18" planer/molder
Offline dgdrls
  • Learning the Art of Milling Logs
Re: Norwood Blades
« Reply #5 on: December 16, 2019, 07:42:21 PM »
 Sawwood
You purchased bands that are the incorrect size?
D
Offline Stephen1
    • muskoka Sawmill
Re: Norwood Blades
« Reply #6 on: December 16, 2019, 08:50:32 PM »
 Sawwood
And if thy can't you can always resell them. That was a good price
Offline sawwood
Re: Norwood Blades
« Reply #7 on: December 17, 2019, 01:05:25 PM »
I picked up the Wood-Mizer blades to day and they are .055 X 1 1/4 X158, 7/39. These are new blades
 Do any of you Wood-Mizer guys run this type of blade? Not sure the 055 blades will work on our Norwood mill. I would have to have them cut down but would if they will work.
Sawwood
18" planer/molder
Offline Stephen1
    • muskoka Sawmill
Re: Norwood Blades
« Reply #8 on: December 17, 2019, 09:33:19 PM »
I run the .42-7/39 1.25. Great blades.There are quite a few sawyers running that blade you have. Put them up for sale here, or CL and then buy yourself some blades that fit your mill.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Norwood Blades
« Reply #9 on: December 18, 2019, 11:53:06 AM »
I ran the blades you mention on my LT-40. Turbos, the 7/39 are called. Practically a universal blade. I use only this profile in 1-1/2 .055 on my LT70 so far.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Stephen1
    • muskoka Sawmill
Re: Norwood Blades
« Reply #10 on: December 19, 2019, 09:28:01 PM »
TT do you run the .055 on your LT40?
question
What blades to run on a Norwood lm 29
Started by Maplehillfarms on Sawmills and Milling
Last post February 10, 2018, 07:31:56 PM
by dgdrls
Norwood blades
Started by r44astro on Sawmills and Milling
Last post May 15, 2012, 06:23:07 PM
by r44astro
Norwood moulder blades
Started by dogone on Sawmills and Milling
Last post January 29, 2020, 10:10:37 PM
by dogone
Buying blades for Norwood LM 26
Started by Lazyguy on Sawmills and Milling
Last post August 30, 2014, 02:24:29 PM
by Lazyguy
