Author Topic: OWB Chimney question  (Read 304 times)
Offline Arctiva
« on: December 27, 2019, 02:13:40 PM »
I have a woodmaster 434 with just a 12" or so above the burner stack. I've been having issue with the wood in back not burning good/alot of black chunks and not good hot embers.
But if I leave the damper open a 1/4 way problem solved gets better air flow then. Would putting a longer chimney stack on create more air flow with the damper shut? The fan is on the door and only has1 fan.
I assume I'd burn a little less wood not having to keep the damper open all the time.
Thoughts?
Offline E Yoder
  • Heating with a HeatMaster G7000
Re: OWB Chimney question
« Reply #1 on: December 27, 2019, 11:00:56 PM »
I'm guessing what is happening is the air is hitting the wood and jumping straight up above the tubes and out the chimney. Opening the damper at the rear of the tubes sends some air to the back. I don't think a higher chimney will change anything, it's how that model is designed. ?
HeatMaster dealer in VA.
G7000
Chimney question
Started by Raider Bill on General Board
Last post September 13, 2008, 11:21:37 PM
by Don P
Owb chimney question
Started by Dairyman on Firewood and Wood Heating
Last post January 23, 2021, 08:12:51 PM
by E Yoder
Chimney/woodstove question
Started by tyb525 on Firewood and Wood Heating
Last post December 22, 2010, 08:34:36 AM
by Handy Andy
insulation around chimney question
Started by yukon cornelius on Firewood and Wood Heating
Last post December 24, 2013, 11:22:12 PM
by sparky23
