Whatcha Sawin' 2020 ??
Started by Magicman, January 01, 2020, 07:26:47 AM
firefighter ontheside
I let this hackberry sit here for about a year and a half.  It is spalted, but not all the way thru.  I guess I need to go about 2 years in the future.  I just brought home some logs a month ago.  Have to remember to mill them in the fall of 2022.  Hopefully dad and I can mill then without having to worry bout the rona.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
LeeB
Hackberry go very quickly from spalt to rot. It's a fine lined game.
Quote from: LeeB on November 24, 2020, 12:47:09 PM
Thats very true.  These other logs I have are much bigger and I certainly don't want them to rot.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
   Pretty wood. I have some maple here that did that - only spalted on the ends apparently where there was more air exposure or such. Did not run the full 8' length - maybe 2' on each end. I agree if you'd waited very much longer you might have had spalted middles but rotten ends.
I got da monkey off of my back today and finished sawing that SYP whack.
This ugly was the last one to saw  :-X  but three faces did yield some 2X4's.
Luke is on "top of his job".  :o
The back stack is 12½' tall and the next is 11½' tall.
Da udder end.  The framing lumber is dimension sized 2X4's, 2X6's & 2X12's.  A 4"X15"X14' beam, four Red Oak 10"X10" posts, along with some 1"X10" & 1"X12" side limber sneaked in.  The total was 13,907 bf.
Walnut Beast
The guys got a very very nice pile of lumber. Especially with the prices now
Bruno of NH
Yes that's a whack and stack
nativewolf
Do they not have to use graded lumber there?  Don't see how they get that in a house unless an engineer/grader is coming by.  Of course with prices today that might make sense.
Liking Walnut
Grading requirements are based upon the county/municipality building codes plus the blueprint material list.  This lumber will be used to build a new home and will not be graded.
Don P
Building codes are adopted at the state level but are enforced at the local level. Local enforcement varies widely. Compliance is on the contractor not the supplier. Several states do have some form of native lumber law that allows ungraded lumber in residential. Many states have ag exemptions for farm buildings. Almost all have exemptions for small utility buildings.
nativewolf
Quote from: Don P on November 25, 2020, 08:09:05 AM
Oh I know, I guess lax or non existent compliance.  Since it is for a house it is odd to me, that's all.
Liking Walnut
@Don P    I know the county may be lax on enforcing state regs but what do the insurance companies do? Would you have problems getting it insured? I would not want to build a home and not be able to insure it or have problems later if I went to sell it if I wanted to.
My county has no restrictions as I understand but 2 adjoining counties are have them and one is very strict.
tule peak timber
Lynn, on a big job like this , do you charge differently? Flat rate ? One big pile of sticks... ;D
Bruno of NH
New Hampshire has one of the best native lumber laws on the books.
Quote from: WV Sawmiller on November 25, 2020, 09:00:01 AM
Insurance companies don't care.  Sometimes they want pictures.  Other times they might have an untrained agent take a look.
Loan companies don't care much either as long as the house appraises.  New construction loans can be a problem for owner builds.
Outside the towns in my area, the only thing that gets looked at is the septic system and plumbing.
I built my home and shop but tried to meet the building codes of the closet town just to insure I would never have a problem if I ever get annexed.  Also gave me peace of mind that I was doing it right.  The building code officer in town gladly answered all my questions.
Quote from: tule peak timber on November 25, 2020, 09:13:52 AMLynn, on a big job like this , do you charge differently? Flat rate ?
No different billing, just my standard bf sawing rate.
Regarding using ungraded lumber for home building I ask the customer:
Does your blueprint specify #2 and/or rough sawn lumber?
Do you have a building permit if required?
Have you verified with your building contractor that he is willing to build with rough sawn lumber?
Has your lending institution signed off on your building plans/blueprint?
Has your homeowner's insurance carrier signed off on your building plans/blueprint?
Beyond that, I start sawing.
TimW
HAPPY THANKSGIVING!
hugs,  Brandi
thanks Brandi, beautiful spot and log and mill.  you are on your way.
Walnut Beast
caveman
Magicman, that's a nice whack of lumber.  How many blades do you reckon you used on that job?
John and I sawed a good sized live oak for a customer yesterday afternoon.  The customer and his wife are building a house and the tree came from their home lot.  The wife does not want dark colored wood and the customer assumed that since live oak is a white oak that the wood would not be dark.  We were kind of hoping he would not want it and we would get to keep it.  He wanted a 6"x14" mantle and two slabs with one live edge for counter tops in his new gun room.  After seeing them this morning when he came to pick them up, he left with all of them.  These slabs were really good.  I should have taken better pictures but we were working by the hour.  We had to chainsaw this log into conformity from both sides(sometimes I wish we had a wide head mill).
A couple of days ago we sawed up some slash pine logs into 2x4's to use on another lumber rack to stack dry wood on inside the shop.  This sawed so much easier than the big hearted, slow grown longleaf pine we have been cutting lately.
Caveman
Bruno of NH
Quote from: caveman on November 25, 2020, 02:44:03 PMMagicman, that's a nice whack of lumber. How many blades do you reckon you used on that job?
Thanks.  5 metal strike blades, 7 dulled 4° and 3 dulled T7° blades.  This topic LINK came about because I had a box of 4° blades and this job had some knotty SYP.  I doubt that I will have the 4° blades resharpened or replaced because they dulled faster, sawed no better, and sawed much slower.
The metal strikes were anticipated because the customer has a tree removal service which was the source of all of these logs.
I can see sparks flying from that Live Oak.  ::)
I really need to learn to recognize the different blades.  I think the 10 deg do best on my LT15, but I bought some 4 deg to try.  I put something brand new on the other day and I was not impressed.  It seemed slow, even in narrow wood.  I'm guessing it was a 4.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Wood-Mizer sells a gauge to "measure" the teeth on their blades.  I painted the 4° green, the 7° red, and the 10° white.  The section of blade shown is a Turbo 7°.
