Author Topic: converting Prentice 210C to joysticks and slasher controls  (Read 593 times)
Offline Sam Strom
« on: January 05, 2020, 01:48:06 AM »
Hey all. I have a Prentice 210C that was not setup from factory with slasher controls. have any of you plumbed in your own controls? mine has levers too, I would like to convert it to joysticks, but if I can get slasher controls thats the main thing needed. thank you much
-Sam-
Offline BargeMonkey
Re: converting Prentice 210C to joysticks and slasher controls
« Reply #1 on: January 05, 2020, 01:57:20 AM »
 Barsaw or circle saw ? When you say "controls" are you just saying a handle or are you plumbing the machine from scratch ? The handle assembly for my Barko was 70.00 bucks on ebay. Again what do you have now ? Is the valve body there and your just hooking it up ? Are you going mechanical joystick or pilot control ? Someone converted my Barko over ? , literally a couple brackets, cables, heim joints, done. "Joystick control". 🤣
Offline Sam Strom
« Reply #2 on: January 05, 2020, 02:03:19 AM »
I would really like to plumb in a circle saw.
I have the levers. a 2 way joystick for the buckboard and cut function, and I also have a power devider for the circle saw to spin. the problem is plumbing it in. I was trying to plumb the saw function into the return of the main valve bank, but i believe it over pressured the system and blew a few o-rings out of the valves, and i spent half a day cleaning and putting them back. so I need to know how to do it the right way.
the joystick controls would be a HUGE plus but aren't necessary
Offline BargeMonkey
« Reply #3 on: January 05, 2020, 02:24:38 AM »
 In a couple days I will get some pictures of how my Barko is rigged up, cables hooked to the old 5 lever spools, if your handy it's not a hard thing to do. I'm no help on the circle saw, @MaineLogger may know.
Offline Sam Strom
« Reply #4 on: March 14, 2020, 02:25:17 AM »
barge monkey, any luck on those pictures? if you want, you can send them through text too. thanks for the help!
-sam-
320-515-0486
Offline BargeMonkey
« Reply #5 on: March 14, 2020, 08:54:32 PM »
-sam-
320-515-0486
 I will get them 👍 machines been in my yard and I just haven't seen it. Be a 518 #
Offline BargeMonkey
« Reply #6 on: March 23, 2020, 01:38:31 AM »
 Cabs got to be cleaned 😂 completely rewired, done alot of work to it this time in the yard.
Here's pictures of how it hooks to the 4 levers.
Converting Prentice 600B to joystick controls
Started by justagyppo on Forestry and Logging
Last post March 02, 2020, 10:34:05 AM
by BargeMonkey
210 prentice slasher problem
Started by xalexjx on Forestry and Logging
Last post October 22, 2016, 08:03:27 PM
by xalexjx
plumbing a slasher to a 210 prentice
Started by donny hochstetler on Forestry and Logging
Last post December 29, 2014, 12:35:51 PM
by BargeMonkey
Prentice 310E slasher saw problems
Started by qsloggingil on Forestry and Logging
Last post May 24, 2014, 01:13:16 AM
by qsloggingil
