Author Topic: Saw Mills  (Read 1074 times)
Offline Ianab
Re: Saw Mills
« Reply #20 on: January 13, 2020, 02:24:39 AM »
Fair enough, I don't think it would be the right mill for you either. Chainsaw slabbers come into their own on the really BIG logs. A band mill that can handle a 5 ft dia log is neither cheap nor portable.  If you are looking at slabbing logs under 28". then a bandsaw makes sense. And if you primarily want to cut slabs, then you probably don't NEED the power options, as long as you have some way to move logs and slabs, like a tractor / forklift etc.
I do agree that mesquite, being one of the harder woods, you want a bit more power, and blade selection is important.
Mills taking all hardwoods (correction: not "mills" but any industry buyer)
Started by livemusic on Forestry and Logging
Last post August 08, 2019, 09:58:04 PM
by Southside
Used Mills?
Started by Sloken on Sawmills and Milling
Last post January 15, 2005, 08:59:04 PM
by Jeff
Mills in NC
Started by Donald_J on Sawmills and Milling
Last post December 30, 2002, 06:18:31 PM
by DouginUtah
Looking at mills
Started by W8AT on Sawmills and Milling
Last post May 04, 2019, 04:09:46 PM
by ladylake
