Dynamic Green Products Inc.
Author Topic: Cam follower bearings  (Read 698 times)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« on: January 10, 2020, 10:14:40 PM »
I thought changing these was in the manual,but it isn't...
I seem to remember a trick where you prop the outboard edge of the saw head up with a board or can't hook.
Can someone refresh my memory?
lots of dull bands and chains
Online WV Sawmiller
    • Green's Sawmill Services
Re: Cam follower bearings
« Reply #1 on: January 10, 2020, 10:25:36 PM »
   I think the LT40 is different than the LT35 but be very sure you have the head secured before you remove the cam follower. On the LT35 that bottom cam follower bearing is the only thing holding the head to the bottom rail. Good luck and be very careful.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: January 11, 2020, 06:32:49 AM »
Forestry Forum member @Bibbyman covered the procedure very well in "Useful Sawmill Mods"
Go here:      https://forestryforum.com/board/index.php/topic,7789.0.html
I changed all 6 of them on my mill in about 2 hours, by myself!
Change them "One at a Time", for safety!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: January 11, 2020, 07:54:22 AM »
Dan, you use the prop when changing the lower cam followers.
For the top, use a pry bar to lift the head at that point and use a thick screwdriver, etc. as a wedge to hold it up.  You only need to lift it high enough to turn the roller which is not much.
Offline Dan_Shade
« Reply #4 on: January 11, 2020, 02:49:44 PM »
Thanks for the info.
I've been looking at them this afternoon, they all move freely, but sometimes the head feels "bumpy" when moving forward or gigging back.
I have been having some issues with the feed, tightening the belt will make it go a bit better.
I've been sawing a lot of large poplar lately, going through a 20+ inch cant was really taxing the feed.
I also didn't have the frame quite level, the loader side was slightly up hill.  Not sure if that was making it worse or not.
Online donbj
« Reply #5 on: January 11, 2020, 02:58:17 PM »
Check your chain. It may have some links seizing up and that will cause that as well, or junk caught in the chain
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: January 11, 2020, 04:59:54 PM »
Also be absolutely sure that all of the power feed bearings are turning smoothly.  A "too tight" power feed chain will destroy those bearings.
Offline Dan_Shade
« Reply #7 on: January 11, 2020, 10:12:31 PM »
How do you change these?
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: January 11, 2020, 10:20:07 PM »
That's much different from mine, but I would say take the center bolt out to remove the entire assembly ??
Offline Dan_Shade
« Reply #9 on: January 11, 2020, 10:24:41 PM »
This is the one on the other side.  (the end opposite of the hitch)
Online WV Sawmiller
« Reply #10 on: January 11, 2020, 10:33:14 PM »
   If you do what is holding the head on to the frame? Check that very carefully and make sure the head is secured. Also don't raise the head any higher than you have to to help keep it from being more unstable. I think the instructions also warn to chain the head to a sturdy structure before starting.
   I did not pay attention to those cautions and I dropped the whole head unit off mine which is a very traumatic and a very dangerous experience.
   As I remember there is a hex socket in the shaft you can use to help loosen/tighten the assembly if it is the same as mine. I did not use one the last time I changed mine but I suspect an impact wrench would have been very helpful.
   The next time I change one I will be working from the rear of the mill so I don't have to thread so much chain over the sprocket too.
Offline jcbrotz
    • Brotzmans Woodworks
« Reply #11 on: January 12, 2020, 05:17:18 AM »
take a wedge and drive it lightly in the end that will raise the rollers enough to remove the weight and unbolt the center bolt and remove and replace the rollers then reinstall.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: January 12, 2020, 06:23:30 AM »
Absolutely.  The cam follower has a hex socket head, so hold the nut and use an Allen wrench or a hex driver to remove it.
Offline jb616
  • Hobby Sawyer
« Reply #13 on: January 12, 2020, 11:06:16 AM »
I learned the "One at a Time" the hard way....still have all my limbs but the engine cherry picker in the corner of the garage came in handy... >:( > :-\
Sealed bearings or greasable bearings on blade guides
Started by fathead on Sawmills and Milling
Last post October 31, 2012, 08:22:34 AM
by Cypressstump
McGill cam follower number for track
Started by mmartone on Sawmills and Milling
Last post February 19, 2013, 07:15:28 PM
by drobertson
bearings
Started by kev on Sawmills and Milling
Last post May 08, 2009, 07:23:49 PM
by ARKANSAWYER
10-10 bearings
Started by MickMac on Chainsaws
Last post October 16, 2017, 03:20:43 PM
by MickMac
