Dynamic Green Products Inc.
Author Topic: Circular saw blades  (Read 476 times)
Offline senfschneider55
Circular saw blades
« on: January 14, 2020, 04:17:30 AM »
Hi all,
 I am new to the forum, hoping I could harvest some info from you folks.
I plan on building a small circle mill, but canīt find enough info on the proper circle blades. I
understand there is a difference in table saw and mill blades. Is there a good source for blades.
Just to complicate matters, I live in Bavaria, Germany.
Thanks in advance
Irv
Offline Ron Wenrich
  • Forester
Re: Circular saw blades
« Reply #1 on: January 14, 2020, 11:40:31 AM »
What size of blade are your intending to run?  There are mill blades that are used on edgers that are fairly small and stout.  Mill saws can run up to 60".  Saws can be made to order by saw mfg.  In this country there is B H Payne and Simonds.  I imagine they would ship to Germany.
But, you might want to check a little closer to some of the mill manufacturers in Europe.  Kara in Finland makes a circle mill and may be able to give you some information about blades closer to you.
« Reply #2 on: January 15, 2020, 12:33:07 PM »
Hi Ron,
I just want a simple hand fed mill; logs no longer than about 3ī; 6- 12" round. I tried a chain saw and was not happy
with the cut, time, and waste. I have a 6 hp 380v electric motor and several saw blades  12-20 " dia. Also have the double
pillow block bearing 2" shaft for mounting the blades.
Thanks for the quick responce
Irv
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: January 15, 2020, 01:00:21 PM »
With blades that small you have 3 choices, inserted tooth. solid steel and carbide tip tooth. There must be a carbide saw shop in your area. The gage of saw plate and the tooth count would be a question. The more teeth the more power needed.
« Reply #4 on: January 15, 2020, 03:15:36 PM »
I think I am going to put together a Bolter mill as bt ( been there ) suggested.
Thanks to all for the responses.
Irv
To err is human, to really screw up you need a chain saw !
Circular Saw Mill Blades?
Started by lowpolyjoe on Sawmills and Milling
Last post June 16, 2016, 11:18:54 AM
by lowpolyjoe
moved
MOVED: Circular saw blades
Started by Ron Wenrich on Ask The Forester
Last post January 14, 2020, 11:11:17 AM
by Ron Wenrich
lamp
new guy question# 2  circular saw blades,
Started by robotguy on Forestry and Logging
Last post September 04, 2003, 05:41:13 PM
by Ron Wenrich
Bandmill with circular blades
Started by ammhouse on Sawmills and Milling
Last post May 07, 2013, 06:58:01 PM
by Satamax
