Dynamic Green Products Inc.
Author Topic: Will these board dry straight  (Read 1103 times)
Offline kelLOGg
« on: January 14, 2020, 12:26:36 PM »
I am sawing SYP for a customer into 12, 8 and 3 inch wide boards. Slabs that are about 12 to 13 wide and are ideal (dimensionally) for edging to 11" and resawing to 3 and 8 inches. However, the cathedral grain (which is centered on the 11" board) is now off center on the 8" board. See pic. Will the 8" boards dry straight? Note: the boards are from the outer part of the log and nowhere near the pith.
 <b
r>
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Southside
    • White Oak Meadows
Re: Will these board dry straight
« Reply #1 on: January 14, 2020, 12:53:12 PM »
There is nothing I can see there that will give you any problems, that is perfectly fine flat sawn pine.  Aside from sawing from a very stressed log, with SYP what you want to be careful with in order to avoid crook is to either not have any juvenile wood mixed in with the sap wood, or to make sure that it is balanced on either side.  Good job!!
White Oak Meadows
Offline kelLOGg
« Reply #2 on: January 15, 2020, 06:06:13 AM »
Thanks for the reply. Any success I have sawing is due mostly to what I have learned on the FF.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: January 15, 2020, 08:04:31 AM »
Probably OK, but I find that it is always best if you can balance the rings.
Offline kelLOGg
« Reply #4 on: January 15, 2020, 08:17:52 AM »
I saw no way to balance the rings without wasting the boards
Online alan gage
« Reply #5 on: January 15, 2020, 09:35:39 AM »
I had a similar debate with myself last weekend when working with wide boards. I did the same as you and now have off balance 6-7" boards. Since they're already air dried and will soon be screwed to the wall I'm hoping it's ok. Too much work and waste otherwise.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline kelLOGg
« Reply #6 on: January 15, 2020, 11:33:54 AM »
Uh Oh. Time will tell if I end up in the same boat
Online doc henderson
« Reply #7 on: January 15, 2020, 11:39:00 AM »
what is the intended use?  very specific widths.
Offline kelLOGg
« Reply #8 on: January 15, 2020, 11:46:39 AM »
It is for home siding for a customer/friend. All I know is the 12 and 3 inchers are for vertical board and batten. The 8 inchers will be horizontal siding and if they crook it'll be difficult to nail them straight. There are only 2 boards cut this way.
Offline Southside
    • White Oak Meadows
« Reply #9 on: January 15, 2020, 11:55:07 AM »
I am not disagreeing with WDH here, but centering the circles is not something I have ever intentionally done, and pine is by far the majority of what I saw.  Makes sense that it would be best practice to do so.
White Oak Meadows
« Reply #10 on: January 15, 2020, 01:26:06 PM »
B&B can be forgiving.  if he has trouble, he knows a guy with a sawmill.
Offline WDH
« Reply #11 on: January 15, 2020, 08:45:50 PM »
It is like a lot of things where it is better to do one thing, but it is not always practical to do it ;D
Offline Florida boy
  • Young sawyer with my first mill
« Reply #12 on: January 17, 2020, 09:07:32 AM »
From my experience as long as you stay away from pith with good logs it works. The closer to pith the more crook you have . Good size diameter logs help a lot.
Offline Woodpecker52
« Reply #13 on: January 17, 2020, 09:40:53 AM »
A proper driven nail of the right size and length will cover a multitude of crook.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline scsmith42
    • Whispering Pines Farm
« Reply #14 on: January 18, 2020, 12:32:49 AM »
Bob, I always try to center, but when thats not possible Ill place the off center boards near the bottom of the stickered pile for maximum weight on top. Ive had good success with this method.
Tom's 3638D Baker band mill
Offline kelLOGg
« Reply #15 on: January 18, 2020, 06:23:31 AM »
They will be near the bottom. The stacks will be nearly 6' high before all is sawn. Thanks
Putting a straight edge on a board
Started by oakiemac on Drying and Processing
Last post August 25, 2004, 05:32:19 AM
by oakiemac
Sawing a straight Elm board, mission impossible?
Started by Celeriac on Sawmills and Milling
Last post December 30, 2009, 07:16:08 PM
by woodmills1
Cutting Straight, Staying Straight
Started by matariki on Chainsaws
Last post March 21, 2019, 11:32:48 AM
by mredden
cant seem to cut straight
Started by Dave VH on Sawmills and Milling
Last post January 07, 2012, 11:07:26 AM
by Dave VH
