Author Topic: Tree twist  (Read 541 times)
Offline charles mann
Tree twist
« on: January 28, 2020, 04:38:44 PM »
What would cause a tree, during growth, to twist/spiral?
Unsure of oak species, but i saw an oak around 30” diameter, with a very noticable twist/spiral in the bark, which im assuming the twist is also in the wood structure too.
Temple, Tx
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Tree twist
« Reply #1 on: January 28, 2020, 04:56:31 PM »
My understanding is it is an adaptation to a difficult growing condition, as the spiral grain makes for a much more strong and stable structure. Think wind or difficult rooting conditions and things like that.
Re: Tree twist
« Reply #2 on: January 28, 2020, 07:40:32 PM »
Would this type of growth cause an issue during drying, more so than wood with less to no twist?
The tree i saw looked like a dang corkscrew, which is why it caught my eye.
They are phasing up to start widening the road in that area and its on public, state right of way, so it’ll be coming down. If im hm, plans are to retrieve as many as i can haul off
Temple, Tx
Offline doc henderson
Re: Tree twist
« Reply #3 on: January 28, 2020, 07:46:57 PM »
yes I think so.  I believe @GeneWengert-WoodDoc spoke about this last year.  we can see what he has to say.  I guess you can always cut it and see.
Re: Tree twist
« Reply #4 on: January 28, 2020, 08:55:59 PM »
Ill hang a bar in it, but if it wont be worth the value of a politician, i’ll use it for cooking or heating, not waste a good band on it. But i’ll wait on mr. gene to comment before writing it off as heating wood.
Temple, Tx
Online Jeff
  • Fearless Leader
Re: Tree twist
« Reply #5 on: January 28, 2020, 09:37:50 PM »
Id not waste my time. Twisted log, twisted lumber.
Offline thecfarm
Re: Tree twist
« Reply #6 on: January 29, 2020, 07:15:25 AM »
Unless someone has a project for twisted wood, I see firewood.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Tree twist
« Reply #7 on: January 29, 2020, 07:55:06 AM »
There are some trees that commonly grow with spiral grain like sweetgum, blackgum, elm, hackberry, and sycamore.  In the commercial markets, these species are usually sawn into pallet wood or low grade industrial wood.  The reason is that the spiral grain leads to drying defects, especially twist and warp.  If these woods are quartersawn, they are more stable, but in the Industry, that is not economically viable.  If you do saw the log, and it is large enough, you could quartersaw it to minimize the twist and warp.
Offline Ron Wenrich
Re: Tree twist
« Reply #8 on: January 31, 2020, 04:35:28 PM »
I was always told that spiral grain was genetics.  Some species are more prone to it.  I've seen it in tulip poplar as well as some of the other mentioned species.
Our wood products prof told a story about there being a problem with telephone lines in Wyoming back in the 1950s.  Us old pharts remember when the telephone lines had crossbars on the poles and they carried a lot of lines.  Major lines used to run along the railroad beds.
The problem they had was that the lines were being broken in certain areas of the line.  They were rather remote, and they thought maybe somebody was cutting the lines.  It turned out that the poles were lodgepole pine.  They are very prone to spiral grain.  Apparently, there were a couple of poles with opposite twists and as the humidity level changed, they would turn.  Eventually they would break the wire as the twist was magnified by the crossbars.
Offline reride82
Re: Tree twist
« Reply #9 on: January 31, 2020, 06:42:10 PM »
Can confirm the twist in lodgepole. As I have been taught, most start with a left hand twist and as they mature they either develop a right hand twist or straight grain. Those that stay with a left hand twist are very prone to twist as they dry. So, power companies developed standards for the amount of twist they would allow for their poles. It is also a concern for log home construction as they twist as they dry in place.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline Jesse Duke
Re: Tree twist
« Reply #10 on: May 15, 2020, 06:11:33 PM »
I'm not sure how common ironwood is but it twists pretty noticeably as I recall.
New twist on gas and go
Started by sawguy21 on General Board
Last post March 18, 2014, 12:28:41 PM
by Delawhere Jack
How much twist in a log ?
Started by Tramp Bushler on Sawmills and Milling
Last post July 15, 2019, 01:49:48 PM
by Tramp Bushler
clip
Is it possible to un-twist timbers?
Started by vtframer on Timber Framing/Log construction
Last post November 26, 2017, 09:11:58 PM
by MbfVA
Cows... with a new twist.
Started by Tillaway on General Board
Last post October 14, 2002, 05:51:56 PM
by C_Miller
