Author Topic: Log consider froze at what temp  (Read 1056 times)
Online doc henderson
Re: Log consider froze at what temp
« Reply #20 on: February 08, 2020, 05:30:11 AM »
yes, I thought surely all that frozen wood would make it colder in there.  even though there is not yet a roof or walls. :) :) :)
Offline PA_Walnut
« Reply #21 on: February 08, 2020, 07:25:09 AM »
A laser thermometer is helpful when you suspect your logs may/could be frozen. I store my logs in the shade and if there's a cold spell, then warms it's difficult to guess if they are frozen or not. A zap with the laser at a few spots (once opening the log) will take the guess work out.
Good luck.
LT40HD Wide 35HP Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline moodnacreek
  • Sawin by the notches
« Reply #22 on: February 08, 2020, 08:38:01 PM »
  Related question here - aren't some trees naturally drier , i.e lower moisture content, than others so don't they saw easier in normally frozen conditions than others? I thought cedar and I know ash have a naturally lower moisture content than others. Wouldn't they saw more like normal, non-frozen conditions?
A bsolutely, the drier the better as far as frost is concerned. The heat at the teeth is just enough to thaw the frozen sap as it is made into sawdust. But instead of shooting out of the kerf it refreezes in the kerf and the side that gets the most pushes the saw blade off line.
Offline moodnacreek
« Reply #23 on: February 08, 2020, 08:43:24 PM »
Not rare at all if you live in the land of ice and snow. Id say more prevalent in smooth bark trees like aspen and alders.
Wouldn't know an alder if I tripped over one but aspen, yes, that wood can be more water than wood.
Offline barbender
« Reply #24 on: February 08, 2020, 09:12:34 PM »
Here's a nice "sunburst" frost cracked black ash. That type of frost crack is common in black ash and red oak up here.
Offline barbender
« Reply #25 on: February 08, 2020, 09:15:17 PM »
Try that again with some zoom🙄
Offline moodnacreek
« Reply #26 on: February 09, 2020, 08:45:21 AM »
Up on our mountains white oak can do this and I never knew what caused it.
Offline jeepcj779
  • "Watch this" - Famous last words
« Reply #27 on: February 09, 2020, 12:48:25 PM »
That appears to be a butt log.
Offline barbender
« Reply #28 on: February 09, 2020, 01:50:25 PM »
It is
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #29 on: February 09, 2020, 03:48:26 PM »
Those wood make nice cookies.  ;)
« Reply #30 on: February 09, 2020, 05:21:17 PM »
just have to keep them in the freezer!! :) :)
Offline barbender
« Reply #31 on: February 09, 2020, 10:45:26 PM »
They typically fall apart.
Offline Don P
    • Calculator Index
« Reply #32 on: February 09, 2020, 11:21:23 PM »
The truck, trailer and Lucas are on the other side of a creek and the frost went out today. Sawing was easy, the question now is, at what temp will the mud freeze back up :D
hell froze over
Started by goose63 on General Board
Last post January 07, 2014, 07:27:46 PM
by clww
Forum Like Froze Mud
Started by Fla._Deadheader on General Board
Last post October 23, 2004, 09:03:07 PM
by Paschale
5 Deg. F and, of course, my pipes froze.
Started by Weekend_Sawyer on General Board
Last post February 08, 2007, 08:50:38 AM
by bitternut
Froze up 4 wheeler.
Started by starmac on General Board
Last post April 04, 2016, 01:34:19 AM
by starmac
