Author Topic: water lubrication  (Read 779 times)
Offline crozier
water lubrication
« on: February 08, 2020, 01:21:30 PM »
I have a Woodmizer LT 28. I'm having trouble regulating the lube water. It seems as though I get a pretty good stream of water then back it off the slightest bit, the water stops.  Should I try a different type of valve?
Offline Woodpecker52
Re: water lubrication
« Reply #1 on: February 08, 2020, 01:30:45 PM »
Blow out the valve and line with air hose sometimes just funk in the line and valve.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #2 on: February 08, 2020, 01:45:42 PM »
The valve on the tank on my LT 35 was plastic.  I replaced it with a brass hose bib. It works way better and has finer adjustment.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline SunnyHillFarm
« Reply #3 on: February 08, 2020, 02:09:54 PM »
I had the same problem with my LT 27. I use a gas pilot swing valve in the feed line closer to me. I use that to regulate on and off once the main valve is set. This has worked well for me. Getting the plastic valve flow just right is a problem sometimes.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #4 on: February 08, 2020, 03:59:27 PM »
  Did you crack/open the air vent on top? If it gets stopped up it will prevent proper water flow too. Just a thought.
Offline donbj
« Reply #5 on: February 08, 2020, 04:10:42 PM »
An idea I had for this was to install a small low current draw water pump in line before the valve so there was always pressure against the valve and wouldn't plug as easily. Just a few pounds would do I'd think (5-10). That way if it did plug, just a quick blip of the valve would clear it and flow would still be regulated with the valve as usual.
Another advantage would the constant pressure. As the water level in the tank goes down so does the pressure(head) in the system. A little pump may solve that problem.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #6 on: February 09, 2020, 07:35:24 AM »
One of my mills is the older (1990) WM Lt40 HD. It has the gravity feed water lube tank located on the top of one of the masts. Works well but when I raised it an additional 10" up in height, water pressure also increased, big plus.
Offline millwright
« Reply #7 on: February 09, 2020, 07:56:45 AM »
On my lt35 I added another valve beyond the first one. I then use that one to regulate the flow, and use the first one to turn the lube on and off thus not changing the flow amount.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: February 09, 2020, 08:14:59 AM »
There are many ways to vary the flow; windshield washer pump and a hazard flasher.  smiley_headscratch  smiley_idea
Offline crozier
« Reply #9 on: February 10, 2020, 09:26:04 PM »
My vent is open so it is not pulling a vacuum.  I like the idea of using a hose bib type valve.
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #10 on: February 10, 2020, 10:24:26 PM »
When we had an lt-28, we opened the plastic tank valve to the proper amount of flow for what we were sawing and had another brass valve in line that we would open at the beginning of the cut and close at the end.  Occasionally the screen before the tank valve would need to be cleaned/blown out.  I spent the last 30 minutes looking through my gallery but was unable to find a picture of it.
Caveman
Offline Steve Carson
« Reply #11 on: February 11, 2020, 02:06:54 PM »
I added a second valve also that I could reach from the same side of the mill I operate from. Set the top one to flow how you want it and the second one is just an on off.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: February 11, 2020, 07:38:56 PM »
I think I plumed mine just the opposite!
The valve on the water jug opens the flow, and the one right near the control console adjusts "how much flow"!
I also have a solenoid valve mounted under the platform that the fuel, and the water jug sits on!
It's wired to ground, and to the #2 lug on the feed drum-switch!
Water only flows when the sawhead is going forward, when it stops or backs up, the valve shuts the water off!
It's the same valve that's used in the Wood-Mizer Lube Mizer system!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline boonesyard
  • I've got a little sawdust in my pocket
« Reply #13 on: February 12, 2020, 09:42:59 AM »
Pictures of your setup would be great if you have some?
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline Chuck White
« Reply #14 on: February 12, 2020, 12:18:01 PM »
I don't have any pics!
I mounted the solenoid valve on the underside of the fuel and water platform, and ran a line from the water jug to the valve, then across to the point where the water drips on the blade, then installed a "fine adjustable" valve in the line near the console!
It's a very basic setup, but it really works well!
~Chuck~
Offline boonesyard
« Reply #15 on: February 12, 2020, 02:14:37 PM »
Sounds like a nice inexpensive solution, thanks.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
On demand domestic hot water using water to water heat exchanger?
Started by Fether Hardwoods on Firewood and Wood Heating
Last post July 26, 2015, 09:50:11 PM
by r.man
Lubrication or dry cut
Started by Arkyrick on Sawmills and Milling
Last post July 22, 2018, 06:56:15 AM
by bandmiller2
Lubrication
Started by Shawn on Sawmills and Milling
Last post March 22, 2006, 09:17:06 PM
by kelLOGg
Lubrication
Started by twostroke_blood on Sawmills and Milling
Last post June 03, 2005, 05:59:42 AM
by brucehuggins
