Author Topic: GVWR of Woodmizer LT50  (Read 411 times)
Offline jeepcj779
  • "Watch this" - Famous last words
« on: February 08, 2020, 09:53:24 PM »
Does anyone have a picture of or have the ability to take a picture of the weight information placard on a late model LT50 or similar? I am try to determine all the regulatory requirements I am going to have to meet when towing the mill for business. Correction, I am trying to legally avoid the regulatory requirements, or determine if it is possible. Thanks
Online WV Sawmiller
    • Green's Sawmill Services
Re: GVWR of Woodmizer LT50
« Reply #1 on: February 08, 2020, 10:20:44 PM »
   If anybody out there has an LT50 this information is on your title from WM. I just checked on my LT35 and it clearly showed a 3500 lb/1588 kg GVWR for the trailer there on the title.
Offline Southside
« Reply #2 on: February 08, 2020, 10:27:49 PM »
Calling @E-Tex
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #3 on: February 09, 2020, 10:53:02 AM »
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline jeepcj779
« Reply #4 on: February 09, 2020, 11:43:08 AM »
Thank you.
Offline KirkD
« Reply #5 on: February 09, 2020, 12:05:32 PM »
Good luck finding a 15" load range E tire rated over 2850 for weight capacity.
Wood-mizer LT40HD-G24 Year 1989
Offline jeepcj779
« Reply #6 on: February 09, 2020, 12:45:39 PM »
I don't know what the specific tire size for the WM is, but...I know now. It is right on the placard. Anyway, I found a Goodyear Endurance ST225/75R15 $133.99 on Tirerack.com as the first result on Google searching "15 inch load range E trailer tire". There are seven 15" E range tires listed at etrailer.com. I am sure the Woodmizer dealer would happily sell me an OEM tire also.
Offline Southside
« Reply #7 on: February 09, 2020, 01:13:32 PM »
E-tex, do the 50's have stud wheels or the mobile home style like on the 70's?
Offline E-Tex
    • www.L2Sawmill.com
« Reply #8 on: February 09, 2020, 04:28:08 PM »
L2 Sawmill LLC
2016 Woodmizer LT50
Started by Seavee on For Sale
Last post September 03, 2019, 10:59:41 PM
by Kristen24060
LT 40 Super or LT50 Woodmizer.
Started by Tin Horse on Sawmills and Milling
Last post February 04, 2020, 10:17:32 AM
by boonesyard
2011 LT50 WoodMizer Portable Sawmill
Started by Lumber Jack on For Sale
Last post August 07, 2012, 10:32:22 PM
by Lumber Jack
Advice on adding a knuckleboom to a 14k-18k gvwr trailer
Started by jovol on Forestry and Logging
Last post December 10, 2018, 10:39:36 AM
by Mt406
