Author Topic: Fuel Tank Hole  (Read 861 times)
Offline ENTS
Fuel Tank Hole
« on: February 11, 2020, 09:00:25 PM »
Working on an old 044.  While cleaning up the handle/fuel tank I noticed that one of the handle bar attachment points has a self tapping screw that appears to screw right into the fuel tank. I can push a piece of wire right thru that hole into the tank.  Not good.  Previous owner had a full wrap on this and must have used a screw that was too long.  Now the question is what to seal that hole with that will 1. Not be affected by the fuel and 2. Allow that self tapping screw (of proper length) to screw into it.
Hope all is well and have a great one.
Fred
Fred Henry,  Over Worked, Under Paid
Offline doc henderson
Re: Fuel Tank Hole
« Reply #1 on: February 11, 2020, 09:07:53 PM »
how about fiberglass, and or epoxy style sealant (JB weld ect.), or use a longer screw again and fill it with the screw.
Offline ENTS
Re: Fuel Tank Hole
« Reply #2 on: February 11, 2020, 09:15:27 PM »
Longer screw -- Since this was an auction buy, don't know saws history nor problems.  From the looks of the saw it worked hard for a living and with that screw embedded in that tank.  Must not have leaked.  However, that may be due to the screw going in for the first time and making a solid seal.  Not so sure the second time in.
Now some fiber glass (bondo) might just do the trick.  Gotta see what I have laying around in the garage.
Thanks and have a great one.
Offline Tom King
    • HistoricHousePreservation
Re: Fuel Tank Hole
« Reply #3 on: February 11, 2020, 09:31:34 PM »
For curiosity, I checked ebay, and there are many choices for a replacement, starting at $40.
I wouldn't trust Bondo for this job.  JB Weld, or some other such epoxy might do it, or even some specialty sealant for fuel tanks.
Offline Air Lad
  • Onwards and upwards
Re: Fuel Tank Hole
« Reply #4 on: February 11, 2020, 10:00:38 PM »
A little expensive but a product called Devcon in the slow dry /super strength category will work
2 x Ms 170/260c /039...Husk 142e/240e 41  272xp...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline scsmith42
    • Whispering Pines Farm
Re: Fuel Tank Hole
« Reply #5 on: February 11, 2020, 10:13:06 PM »
A former employee once threw a board in the back of his truck with a nail sticking out of it and poke a hole into the side of the fuel tank on my brand new 461.
A small self tapping screw with some silicone sealer on it solved that problem.
That was three years ago, still holding.
Tom's 3638D Baker band mill
Offline BLink
Re: Fuel Tank Hole
« Reply #6 on: February 12, 2020, 12:31:51 AM »
We were driving home from California and saw a sign for an Earthquake Fault in Nevada. We had to take the side trip!
There was larger crushed stone and one slammed into my gas tank. It was draining fairly quickly so we wasted no time getting to the next town.
It was about 6:00 pm and they were rolling up the sidewalks for the night and the only gas station had no gas tank sealant. I figured we were up a creek.
A customer suggested I rub it with a bar of soap.
What did I have to loose but a half tank of gas!?!
It Worked!!!
We made it home and it held for about 3 weeks, until it rained!  ;D
At that point I ran a lag bolt into it with a bunch of silicone on it.
It was still there, not leaking, when we parked it 7 years later!
There are a lot of Old Loggers.
There are a lot of Bold Loggers.
But there ain't a lot of Old, Bold Loggers!
Stihl 034, Stihl 009, Husquvarna 3120, 540 Allis Chalmers Loader, International T1340 Crawler Drott 4in1 Loader, JCB 1400B, Cat IT14F
Offline Ianab
Re: Fuel Tank Hole
« Reply #7 on: February 12, 2020, 03:56:23 AM »
Soap and petrol forms a sort of "jelly", actually similar to Napalm.  So in an emergency it will gum up a small hole.
But yes it's water soluble.  :D
Offline Al_Smith
Re: Fuel Tank Hole
« Reply #8 on: February 12, 2020, 06:27:27 AM »
Using the wrong type of screw is a common mistake .I've never had one get the fuel tank but had one puncture the oil tank .In that case the long wood screw type by the vibration chewed it's way through the metal  tank over time .The fix was heliarcing the case halves which is e-coated .I don't have a heliarc rig so I took it to work and the welder had to use about 3 types of filler rod before he got the right alloy .The e-coat is about like glass and needs to be completely cleaned off .It doesn't leak now and has the proper screws which are much like  blunt nose wood screws .OEM screws were about a buck a pop . .
Offline ENTS
Re: Fuel Tank Hole
« Reply #9 on: February 12, 2020, 01:53:22 PM »
Thanks to all for the suggestions.
Devcon  Wow, there is a boat load of different types.
I have some JB Weld in the garage.
Lots of after market handles out there.  I only found 1 that was not flippy cap.
At this point in time I think I'll go with the JB Weld since I have some.  Need to get this saw up and running to see if a new handle/tank is worth it.
Fred
Offline ENTS
Re: Fuel Tank Hole
« Reply #10 on: February 13, 2020, 03:11:07 PM »
O.K.  That one non flippy cap turned out to be flippy cap.  Anyone have a good handle/fuel tank non flippy for this 044?
Later,
Offline Pine Ridge
  • Part-time logger, Full time loafer
Re: Fuel Tank Hole
« Reply #11 on: February 13, 2020, 03:38:29 PM »
HL supply has lots of aftermarket parts for an 044, they have treated me great ordering a few parts from them.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
Offline Al_Smith
Re: Fuel Tank Hole
« Reply #12 on: February 13, 2020, 05:43:39 PM »
It doesn't make much difference .I've put together several with a flippy plus a screw cap .The flippy is not what goes bad but the o -ring stiffens up .I have about a dozen of them I forgot the size of but that's all it is .I got them at work because I had nearly an unlimited supply .I'd imagine you could find them on flea bay for a quarter a pop if you bought a bag full which is not a bad idea  knowing how flippy  caps go .
Re: Fuel Tank Hole
« Reply #13 on: February 13, 2020, 05:47:57 PM »
the oil and gas caps are different in design, and i got a set for $4 on amazon.  fit perfect.  i like the old caps better. (non flip type)
Offline ENTS
Re: Fuel Tank Hole
« Reply #14 on: February 13, 2020, 09:31:02 PM »
Push come to shove, I may have to go with a flippy cap replacement.  I have a couple implements with flippys and have no problem with them.  However, with this saw I'd rather stay with what it came with, screw in cap.  Still searching.  :)
Offline ENTS
Re: Fuel Tank Hole
« Reply #15 on: February 13, 2020, 09:48:07 PM »
HL supply --  Looked thru their site.  Only handle I saw was (wow, a palindrome) a farmertec and it didn't show the cap side.  Sent them a note but I'm willing to bet it's flippy.
I've been everywhere, e-bay, this site, that site, etc.  and only see flippy replacement.  May have to go that direction.
Later,
Re: Fuel Tank Hole
« Reply #16 on: February 13, 2020, 10:11:04 PM »
If you have an older dealer, not neat and tidy like all the John Deere dealers.  they may have a shelf of part saws. I can check with our local dealer.  I have an 046 but it is my favorite saw.  so are the rest of them!! :)
Offline Pine Ridge
Re: Fuel Tank Hole
« Reply #17 on: February 13, 2020, 11:17:15 PM »
Later,
Later,
You might dig a little deeper on HL supplies website, they have the old style aftermarket caps, and several different handles for an 044.
Offline Al_Smith
Re: Fuel Tank Hole
« Reply #18 on: February 14, 2020, 08:30:09 AM »
You might check "chainsawR " .I don't know if Scott still owns it or not .Another is Northwood saw .BTW Northwood listed the 0-rings for less than 2 bucks a pop .The flea bay pirates are trying to sell them for more than the entire flippy from a dealer plus 2 bucks to ship them .
You have to know what OEM prices are to compare to flea bay weather or not it's deal or a rip off .I'm in the process of rebuilding two Partner P-100 saws which in this area are rare .I thought it would be a good idea to replace the piston pin bearings .My word they wanted I think nearly 40 bucks for those things Found them on flea bay,12 bucks a pop free shipping .So that was a deal .
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
Re: Fuel Tank Hole
« Reply #19 on: February 14, 2020, 10:10:41 AM »
About 9 yrs ago a hole got "nicked" (dont ask) in the side of the tank on my Echo cs600P.
JB weld held for 7 years then I had to put another patch on.
The stuff is great.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
hole in tank
Started by coxy on Forestry and Logging
Last post December 17, 2013, 04:03:43 PM
by DDDfarmer
Diesel fuel contamination in 518 fuel tank
Started by giant splinter on General Board
Last post February 17, 2013, 07:31:07 AM
by Autocar
046 fuel tank
Started by golden foot on Wanted
Last post January 06, 2010, 11:33:12 AM
by golden foot
sad
Dry Fuel Tank
Started by Fla._Deadheader on Health and Safety
Last post January 07, 2007, 10:15:38 PM
by Bill
