Author Topic: New saw finally home  (Read 329 times)
Offline backwoodsdave
« on: February 12, 2020, 02:01:35 PM »
Traded a little labor for this metal frame  M14 a while back and finally had time to get it loaded up and back to my place, I plan on replacing all the bearings and machining some new wheels for the carriage, i also ended up with a wooden frame m14 that Ill keep for spare parts, I have a Perkins 4.236 I hope to use for power on the mill when I eventually get it back together, I ended up with a 46 and two 40 inserted tooth blades in the deal also, should be an interesting project.
br>
Offline Bruno of NH
Re: New saw finally home
« Reply #1 on: February 12, 2020, 02:21:29 PM »
Looking forward to pictures of the rebuilding and of you sawing with it.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline moodnacreek
  • Sawin by the notches
« Reply #2 on: February 12, 2020, 07:13:18 PM »
Good for you. It should need new bearings after sitting out. Think about rigging up a better feed. There are some photos in my gallery.
Finally home
Started by petefrom bearswamp on Sawmills and Milling
Last post April 22, 2016, 05:37:16 PM
My New Mill Is Finally Home
Started by 038magnum on Sawmills and Milling
Last post August 23, 2012, 10:16:14 AM
by haywire woodlot
Lt40 finally home/problems
Started by Ocklawahaboy on Sawmills and Milling
Last post January 15, 2013, 10:05:54 PM
by trapper
drying wood in basement with Home Depot home dehumidifier?
Started by DPForumDog on Drying and Processing
Last post September 29, 2015, 12:08:59 PM
by DPForumDog
