Author Topic: Thick inserted tooth mill saws  (Read 278 times)
Offline moodnacreek
  • Sawin by the notches
« on: February 12, 2020, 07:41:25 PM »
Does anybody know what the heaviest gage inserted tooth saws where? I know there was 5/6 ga.  Did 4/5 exist ?
Offline Ron Wenrich
  • Forester
Re: Thick inserted tooth mill saws
« Reply #1 on: February 13, 2020, 10:59:55 AM »
I'm sure you can get one made, but, why would you want to?  The 5/6 probably runs a 3/8" tooth.  We had a blade like that when we bought a new Canadian mill (Morbark of Canada).  They supplied the saw.  It had a lot less teeth.
You might also get into those gauges on a cutoff circle saw.  I only ever used one on a firewood machine.  They use a different type of insert, so it may be different than what you're thinking about.
Offline moodnacreek
« Reply #2 on: February 13, 2020, 01:09:04 PM »
Oh I don't want one, just wondered because there are bits listed 5/6 so it would seem as if there once was a 4/5 or flat 5. The thickest I have is 6/7 also a new 6/8 and they are getting heavy for me nowadays. I do fine with 7/8 and would not be afraid of 8/9 if it was a good one. Those 17/64 bits can be got cheap. Thanks, Doug
inserted tooth saws
Started by crosscut on Sawmills and Milling
Last post July 12, 2005, 12:59:14 PM
by D._Frederick
In need of an inserted tooth blade
Started by ahiggins1 on Wanted
Last post December 19, 2009, 01:13:26 AM
by ahiggins1
Inserted tooth blade
Started by SCSawyer on Wanted
Last post August 01, 2007, 09:32:38 PM
by woody1
Inserted Tooth Source
Started by Charles135 on Sawmills and Milling
Last post October 24, 2012, 11:14:05 AM
by Jeff
