Author Topic: military 6x6 5ton  (Read 1848 times)
Offline coxy
military 6x6 5ton
« on: February 20, 2020, 07:11:04 AM »
can anyone tell me why  90% of them are convertibles and not hard tops and if you can get hard tops for them and where thanks
Offline bwstout
Re: military 6x6 5ton
« Reply #1 on: February 20, 2020, 07:27:10 AM »
the soft tops were use for mounting a 50cal the hard tops were not designed for weapons to be mounted. after the first gulf war we fitted them with a armor cab, then converted them back to soft top and hard tops then army sold the fleet out. You might try a surplus supplier. As for as I know they are no longer in production.
home built mill
Offline Bruno of NH
« Reply #2 on: February 20, 2020, 08:53:49 AM »
You can get hard tops
Google Eastern surplus in Pa.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Don P
    • Calculator Index
« Reply #3 on: February 20, 2020, 09:15:47 AM »
I've looked at getting one, parts availability and cost is my concern ???.
Offline bwstout
« Reply #4 on: February 20, 2020, 01:46:54 PM »
if you can find one with a rebuild sticker on the inside of the door from RRAD it might be a new we rebuilt several hundred from 2008 to 2010 the old Cummins engine is a tuff one in these old truck running gear is tuff also.
home built mill
Offline coxy
« Reply #5 on: February 20, 2020, 05:47:55 PM »
its an 81 general 250 cummins  thanks for the info I thought thats what the soft tops was for
Offline bwstout
« Reply #6 on: February 24, 2020, 07:22:32 AM »
yes sir
home built mill
Offline D6c
« Reply #7 on: February 27, 2020, 07:38:20 AM »
I have an '81 M931 5 ton truck tractor I use to pull a lowboy with dozer.  It has a hardtop but most I see are canvas.
The 250 Cummins is pretty gutless... I might recommend the later models that have the 400 Cummins with turbo.
They're all pretty low speed.  No way I'd ever put mine on an interstate.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: February 27, 2020, 08:01:36 PM »
The 8.3liter 6CTA is a better engine common to 5tons imo. Good motor with a good pump.
Revelation 3:20
Offline Jyoungusa
  • Member*
« Reply #9 on: February 29, 2020, 04:29:22 PM »
To answer your original question most 2.5/5ton trucks are soft top in order to facilitate being able to reduce the overall height of the truck for transportation by ship, train, truck or aircraft.  Ones that have hardtops generally were rebuilds.  Current trucks are all hardtops/armored cabs
Offline Iwawoodwork
« Reply #10 on: March 01, 2020, 09:39:55 PM »
Our road district purchased a duce and half for snow plowing, it came with no top so I welded up a top frame out of thin 1x2 in tubing. was pretty easy due to the straight lines of the truck cab. As I  recall it took me a couple of days to measure , cut fit and mig weld it  together on top of the truck, then we got a sheet metal guy to bend galvanized tin to fit the from and pop rivet/ screw  it on the frame. I think we had a couple hundred in the top.
Offline charles mann
« Reply #11 on: March 02, 2020, 11:27:06 AM »
Last time i checked, there was a guy selling 1, and i think it was in arizona. But he travels between az, to ks and 1 more state in the ks area. He was asking 1500 for it. Iv got an entire spare truck for parts. Only thing iv robbed so for is the level winder for the front winch.
Temple, Tx
Offline mike_belben
  • Pulp Friction
« Reply #12 on: March 08, 2020, 10:28:11 AM »
I have a friend in cookeville TN in the mil truck parts business.  From hummers to 5tons, and tires by the container load.  He has a DRMO contract.  Pm me for his cell.
Revelation 3:20
« Reply #13 on: March 20, 2020, 06:08:08 PM »
@coxy
you still looking for a hard top for your 5 ton? evidently the top on the military forum is still for sale.
Temple, Tx
Offline mike_belben
  • Pulp Friction
« Reply #14 on: March 21, 2020, 01:52:20 PM »
Coxy dont you have a fetish for broken 518s?
https://www.lsn.com/heavy-equipment/cat-skidder-518/6312072.html
Revelation 3:20
military 2.5 ton as a log hauler
Started by EricR on Forestry and Logging
Last post April 05, 2013, 07:05:44 AM
by MikeON
who has been in the military - any branch?
Started by lawyer_sawyer on General Board
Last post December 07, 2005, 01:43:45 AM
by VA-Sawyer
Military Flag
Started by bwstout on General Woodworking
Last post February 25, 2019, 07:43:47 AM
by bwstout
Glock 19X Military
Started by pappy19 on The Outdoor Board
Last post January 21, 2018, 09:52:50 AM
by HOLTeam
