Dynamic Green Products Inc.
Author Topic: Stihl MS260  (Read 591 times)
Offline uffda
Stihl MS260
« on: February 20, 2020, 03:54:39 PM »
Stihl MS260 had excessive bar oil.  I tried to adjust the oil pump but no adjustment screw.  I took the clutch out and found that there is no adjustment on the oil pump.  I looked up parts diagram for this saw and I find that all oil pumps have an adjustment screw.  Whats the deal?? :-\
Offline lxskllr
  • dummy with saw
Re: Stihl MS260
« Reply #1 on: February 20, 2020, 04:13:46 PM »
Looking at the manual, an adjuster appears to be optional. If you've looked where it typically is, I'm guessing you don't have that option.
Offline uffda
Re: Stihl MS260
« Reply #2 on: February 20, 2020, 05:34:58 PM »
I looked on Ebay and found only one that didn't have an adjustment screw.  It was plastic and had to order from Germany for $48 plus dollars.  Sounds ridiculous not to have an adjustment screw.
Offline lxskllr
  • dummy with saw
Re: Stihl MS260
« Reply #3 on: February 20, 2020, 05:54:03 PM »
Perhaps you can fit an adjustable oiler to your saw. I'd be surprised if they made different chassis for the options. If there's a useless hole in the bottom, or some kind of knockout, I'm guessing an adjustable oiler will fit right in. I'm only guessing though. Perhaps someone with first hand knowledge can confirm?
Offline sablatnic
Re: Stihl MS260
« Reply #4 on: February 20, 2020, 06:18:14 PM »
It is possible to install an adjustable pump. You'll need pump, clutch drum and the pump drive / worm.
I wouldn't do it.
Offline uffda
Re: Stihl MS260
« Reply #5 on: February 22, 2020, 02:58:28 PM »
I want to go ahead and replace the old version oil pump (no adjustment) with the new version.  Is there an aftermarket brand that is better than others.  The part # is 1121 007 1043. There are all sorts of them on Amazon and Ebay. :-\
Offline sablatnic
Re: Stihl MS260
« Reply #6 on: February 23, 2020, 02:21:00 AM »
Is the number just the pump or is it a conversion kit?
Offline Mad Professor
Re: Stihl MS260
« Reply #7 on: February 23, 2020, 09:53:00 PM »
The 026/260 pizz out oil when you leave them idling for any time as the pump is crank, no clutch driven.
Is this what OP is seeing as "excessive oil"
Offline uffda
Re: Stihl MS260
« Reply #8 on: February 24, 2020, 08:13:19 PM »
The 1121 007 1043 is the conversion kit.
Stihl 026 VS MS260 Pro
Started by Deere80 on Chainsaws
Last post September 07, 2018, 07:51:56 AM
by Deere80
Stihl MS260 Pro (026)
Started by Mark M on Chainsaws
Last post February 10, 2003, 06:40:55 PM
by jokers
Stihl 026/MS260 max RPM
Started by SJK on Chainsaws
Last post January 12, 2015, 05:10:03 PM
by SJK
Stihl MS260 repairs
Started by vermontStihl on Chainsaws
Last post June 22, 2018, 11:15:44 AM
by teakwood
