Author Topic: Turning a Grasshopper pipe carrier into a small log arch?  (Read 475 times)
Offline gspren
« on: February 27, 2020, 06:48:08 PM »
 I have never used or even seen a log arch in use but I do understand the principals, I just didn't/don't think I'd use one enough to justify the expense to buy one, BUT, a friend just gave me the arch with wheels from this pipe carrier so now I plan to make the top part. I plan on having two tongue ends, one to use by hand and one to hook to the ATV. This will be for firewood only and when at our hunting camp in a state forest we can't use motorized equipment, at home I can use my ATV. First question is how far behind the axle should the rear hook be? I don't plan to use a winch, just tilt front up to hook back and then tilt down to hook the front, I know I'll need to fool around but hoping someone gives me some advice to get started. To see what I have go to www.sumner.com and under material carts look for the grasshopper, I don't have the long top bar, just the arch complete with tires and wheels. Any ideas?
Online ljohnsaw
Re: Turning a Grasshopper pipe carrier into a small log arch?
« Reply #1 on: February 28, 2020, 12:38:58 AM »
So the "front" will be the (long) handle/hitch end?  That is where you will have the leverage.  I would say you want the "back" end such that you lift the front and hook the chains on the back.  It should be close enough to the wheels that you can lift the biggest log you think you will be moving by applying your body weight to the handle/hitch.  With that on the ground, then chain up the front of the log.  You want the load to be pretty much balanced on the wheels.  You don't want to be having to lift or push down too much.  If using a hitch on your ATV, you want the hitch end to be in the range of the ATV rating (50-75 pounds?)  I'd say make it sliding/adjustable like the Grasshopper shows.  You would just need a pin to keep it in place when loaded.  Don't want it shifting on you.
Doing this from scratch, and since this is "light" firewood logs, I'd make the chain a fixed point on the "back" end, have the beam able to slide through the arch (with holes for lock pins) and another fixed chain point nearer to the "front".  The telescoping handle/hitch end would be nice for storage.  Having the beam slide through the arch allows you to very easily adjust the leverage needed to lift the log and the balance point.
John Sawicky
Offline gspren
« Reply #2 on: February 29, 2020, 02:54:20 PM »
  I considered a sliding top bar but that makes it harder to put a pair of angled braces to the lower legs of the arch, moving by hand probably doesn't need them but pulling with the ATV or tractor might. The main beam will be 2" sq. tubing with 1/4 wall because I have some, but today I clamped a regular 2x4 to the arch and experimented with where to attach things, there's a flat plate 6" x 7" on top the arch that makes it easy to attach to.
Big black grasshopper
Started by metalspinner on Wanted
Last post August 16, 2007, 11:13:15 PM
by limbrat
Manufacture for small log loader rack and pinion boom turning system.
Started by logman81 on Forestry and Logging
Last post November 14, 2011, 01:29:38 PM
by logman81
PBS Carrier
Started by Larry on General Board
Last post May 03, 2008, 10:15:16 PM
by Larry
New chainsaw carrier
Started by sawdusty1 on Chainsaws
Last post January 08, 2019, 11:43:48 AM
by MAF143
