Author Topic: Forcat skidder  (Read 743 times)
Offline VTLogger
Forcat skidder
« on: March 01, 2020, 10:14:04 AM »
Just checking to see if anyone else have a forcat skidder on here?  Have a couple questions
Offline Don P
    • Calculator Index
Re: Forcat skidder
« Reply #1 on: March 01, 2020, 12:01:52 PM »
Don't have one but have used one for a little bit, we're in the mountains, it is a better low impact flatland machine. I used it for a little over a week in exchange for cleaning it up and servicing it. I nearly rolled it and stuck to the flatter places here. I got a call early the next week asking what to do to get it running again after a rollover.
Offline VTLogger
Re: Forcat skidder
« Reply #2 on: March 01, 2020, 01:34:09 PM »
Im trying to figure out how to start them in cold weather,  had mine for about 4 yrs,   the first couple I didnt need it but the last couple I really could have used it.
  It seams when it gets below 30 it does not want to start
Offline Don P
    • Calculator Index
Re: Forcat skidder
« Reply #3 on: March 01, 2020, 03:24:47 PM »
Is yours a Perkins with glow plugs and a block heater?
Offline VTLogger
Re: Forcat skidder
« Reply #4 on: March 02, 2020, 06:18:42 PM »
No,  its the older one with the 27hp Kohler motor,  I put a new carb. on it thinking it would help but no luck,, its fine when at home, I just keep in the shed with a small heater..  its when I have to leave it in the woods it be comes a problem..  it it gets real cold it just hates to start.
Offline 47sawdust
Re: Forcat skidder
« Reply #5 on: March 02, 2020, 06:59:31 PM »
Can you take a gas grill size tank with a small radiant heater on top to the spot in the woods where you leave Forcat.
I use one for a variety of different equipment.
Mick
Offline Brian_Rhoad
Re: Forcat skidder
« Reply #6 on: March 02, 2020, 07:05:34 PM »
Kohler makes a "cold weather kit" for their engines.
Offline VTLogger
Re: Forcat skidder
« Reply #7 on: March 02, 2020, 07:50:58 PM »
Cold weather kit?   I gotta looking in to that!  I like the propane heater idea
Offline RealDeal
  • I'm new! But have been lurking for over a decade
Re: Forcat skidder
« Reply #8 on: March 13, 2020, 11:46:47 AM »
I have one of the really old Forcats, with a 24hp Onan motor.  Never had problems starting down to zero, and below that I tend to not want to start any machine.  I guess check the basic things like making sure your plugs are good and that the choke actually works, and with mine I have to still give it a little throttle when choked and cold starting.  The fuel pump and vacuum line could also be a place to check, although the vacuum line isnt a fun job when its sitting out in the woods and freezing.  The cheap little fuel filter that looks like a clear fishing bobber should be full of fuel but if you have a leaking vacuum line or just a weak pump that filter wont have much fuel in it.  Could almost use a primer bulb to make sure its full on startup.  Maybe try some starting fluid too.
Offline RealDeal
Re: Forcat skidder
« Reply #9 on: March 13, 2020, 12:09:37 PM »
Now that I think about it, the Kohler engine is probably very different regarding the vacuum line and fuel pump.  In that case, forget what I said and sorry if you wasted your time reading my last post.
Forcat 2000 VS Conventional Log skidder
Started by Good Feller on Forestry and Logging
Last post June 08, 2010, 12:52:08 AM
by debushau
Tremzac Oxtrac skidder (formerly Forcat)
Started by Jasperfield on Forestry and Logging
Last post January 05, 2011, 05:30:19 PM
by madmari
new berfor forcat
Started by redneck logger on Forestry and Logging
Last post November 15, 2008, 07:57:04 PM
by redneck logger
forcat 2000
Started by VTLogger on Forestry and Logging
Last post May 07, 2016, 06:20:13 PM
by VTLogger
