Author Topic: Hydro ax 570 help greatly appreciated  (Read 486 times)
Offline air1514
« on: March 04, 2020, 12:12:57 PM »
I just bought a timber king tk350. Same as hydro ax 570 except with a cat engine.   First question, how to raise the cab. I can't get the pins to come out. And the jack gets tight but won't move the cab. I can wiggle the cab with a pry bar. But can figure out how to get it up.
            Also, the saw head won't work. All other hydraulic functions work great. Very fast and responsive. I can hear something click when I press the saw button. But the saw never moved. The engine doesn't drag down.  Am I just not doing the right things or do I actually have a problem?
Offline air1514
Re: Hydro ax 570 help greatly appreciated
« Reply #1 on: March 04, 2020, 12:15:46 PM »
Thanks ahead of time for any and all help. It's really appreciated!  I don't know squat about a feller buncher. And can't seem to find any manuals for it to buy.   Forums seem to be about the only way to get out of paying a high dollar dealer mechanic
Offline air1514
« Reply #2 on: March 04, 2020, 12:30:39 PM »
I just found out the auction company unhooked the saw under the dash .  So I'm hoping that problem is solved when I get home
Offline Firewoodjoe
  • Im getting old
« Reply #3 on: March 04, 2020, 12:34:35 PM »
If I remember right those pins are a half pin. They have a flat on one side. U turn it with pressure on the jack and when it bounces up free you got it. But they also rust in. So good luck.
Offline kiko
« Reply #4 on: March 04, 2020, 02:55:19 PM »
Do your cab pins look like this?
Offline air1514
« Reply #5 on: March 05, 2020, 08:52:22 AM »
Thanks firewoodjoe. I think your right. I just haven't held my tongue just right yet or something lol. I'll get it eventually.
 Kiko, they look similar to that. Mine only have two bolt holes instead of four.
Offline kiko
« Reply #6 on: March 05, 2020, 04:35:56 PM »
Ok the tk340 that I have uses the cab pins like in my picture which must be removed completely.  If has two bolts and a hole in the end of the pin to put the cab jack bar to turn the pin, then like firewood Joe said.  It is probably not a bad idea the jack the cab and check and clean a new to you machine.  It is not necessary to jack the cab to get to get to the saw solonoid.  Sitting in the seat left side engine door closest to cab  is where the solonoid to turn the saw on is.
New to the website. A million questions. Any advice greatly appreciated
Started by kentuckylogger on Ask The Forester
Last post December 06, 2013, 11:51:27 PM
by kentuckylogger
Criticism welcome, Ideas appreciated.
Started by LeeB on The Outdoor Board
Last post December 20, 2020, 07:41:15 PM
by LeeB
Going to harvest some of my timber, any advice will be appreciated.
Started by sflynn on Forestry and Logging
Last post November 18, 2010, 09:54:51 PM
by beenthere
Researching planers-any information would be appreciated
Started by oakiemac on Drying and Processing
Last post March 02, 2010, 10:30:12 PM
by timbob
