Author Topic: Made an offer on this today  (Read 2075 times)
Offline Bruno of NH
« on: March 08, 2020, 03:12:33 PM »
Bobcat 974
My brother in law has a bucket for it , new engine (it runs great now 78hp perkins) and heavy duty log grapple.
And shear head.   3,700 lift it weighs 12,000 < br>
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Made an offer on this today
« Reply #1 on: March 08, 2020, 03:33:02 PM »
I looked at several before I bought mine.
The problem I had was getting in and out. Not easy for a big guy like me.
And to operate the machine you need to pull down the safety bar to the locked bottom position.
I could barely get it past my gut.
If I ever got one with one of those bars, I'd have to have it modified to account for the operators size.
Jim Rogers
Offline Bruno of NH
« Reply #2 on: March 08, 2020, 03:38:28 PM »
Jim,
This one has a huge operators cab.
I can even fit in it with the bar down.
You could easily fit in it.
Offline scsmith42
    • Whispering Pines Farm
« Reply #3 on: March 08, 2020, 04:47:40 PM »
Iím considering upgrading from my John Deer 270.  Itís good for a 3,600 lb log but Iíd like a tracked model instead of tires.
Two that Iím looking at are the Takeuchi TL12 and the Kubota SVL 95.  Both are close in terms of what they can pick up (about 2X my current JD).
Tom's 3638D Baker band mill
Offline Bruno of NH
« Reply #4 on: March 08, 2020, 06:38:35 PM »
Scott,
I have friends that have the Kubota 95 tracked machines and cant say enough good things about them.
They also have a large operator station.
Bruno
Offline Nebraska
« Reply #5 on: March 08, 2020, 09:39:50 PM »
That looks like a nice machine Bruno, I'd sure take it.
Offline Bruno of NH
« Reply #6 on: March 08, 2020, 09:59:35 PM »
I will be picking it up in the morning.
My farmer friend will pick it up with his gooseneck trailer.
Offline Southside
« Reply #7 on: March 08, 2020, 11:15:22 PM »
I thought you would ride around in it and use it to pick up logs and such, not use it as a piece of exercise equipment.   :D
Offline mike_belben
  • Pulp Friction
« Reply #8 on: March 08, 2020, 11:27:08 PM »
Now even tho that machine is obsolete, its WORTH keeping it going and working around the glitches, unlike a 742.  Those things are a beast.  Engine and pump parts should cross over to barko 980 and bobcat 1080 machines if im not mistaken.
Beware out in the woods.. you turn one or two times in a soft spot and the next time its buried.
Im jealous.
Revelation 3:20
Offline barbender
« Reply #9 on: March 08, 2020, 11:51:20 PM »
Those things look like beasts! That's almost twice the weight of my Case 1845c, and it is a very capable machine.
Offline Bruno of NH
« Reply #10 on: March 09, 2020, 05:16:39 AM »
 I won't be taking it in the woods
If that gets stuck it won't come out very easy :D
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #11 on: March 09, 2020, 09:03:46 AM »
Nice find Bruno,
let us know how it works for you,
D
Offline hacknchop
« Reply #12 on: March 09, 2020, 10:35:51 AM »
Nice machine I hope it makes things easier for you , looks like you have a busy season ahead of you a machine like that will add to production , we're happy for you. :)
Often wrong never indoubt
Offline Bruno of NH
« Reply #13 on: March 09, 2020, 10:58:03 AM »
It's getting loaded on the gooseneck and ready for the 1.5 hr ride to the mill
Offline Wudman
  • Forester
  • Eat, drink, and be merry before you go on quota!
« Reply #14 on: March 09, 2020, 12:09:38 PM »
I've run an SVL 95.  It's a hoss.  More room and more guts than a Cat 299 that I ran for the same guy.  Plus the Kubota has a swing up door.  I liked that better than the swing out on the Cat.  The Cat had some fuel guage issues and I ran it dry on a steep slope with the grapple extended.  You couldn't open the door unless the boom was completely lowered.  I didn't want to pop the emergency exit, so I sat there until somebody brought some fuel.  That was facing west in July in late afternoon.  Got a little warm in there in the 30 minutes waiting on some fuel.  The boss ran it out about a week later in a similar situation.  The guage was reading 1/4 tank.
Wudman
Offline Bruno of NH
« Reply #15 on: March 09, 2020, 12:55:04 PM »
We got to the town that the bobcat was at they posted the roads this morning.
Got it loaded quick and got on our way.
It did freeze up a little last night.
Offline Nebraska
« Reply #16 on: March 09, 2020, 02:13:01 PM »
 8) congrats on the buying the machine. May it serve it's master well.
Offline mike_belben
  • Pulp Friction
« Reply #17 on: March 09, 2020, 04:58:35 PM »
Just some skidsteer FYI.  A bobcat S250 wheel machine will load a pallet that flips a kubota SVL 75 track machine.  Same day load and unload.  If you want brute lifting the 75 is lacking. Guy went right down on his face pretty hard, then slammed back over when the pallet busted and boulders scattered.   Looked like quite a ride.
Revelation 3:20
Offline Bruno of NH
« Reply #18 on: March 09, 2020, 05:40:16 PM »
Unloaded the 974 it has quick attach but it looks bigger than my other quick attach forks and bucket
I will have to see in the morning if they work.
Offline mike_belben
  • Pulp Friction
« Reply #19 on: March 09, 2020, 10:44:02 PM »
Your forks probably arent rated for what that bear can lift.
Revelation 3:20
Offline Mountaynman
  • work from the southern adks to the catskills in NY
« Reply #20 on: March 10, 2020, 07:38:21 AM »
I will also agree with what an animal those machines are backed into an amish customer with a load of larch for his mill about this time of year and as i was unloading the frost gave way and the truck sank to the axles yup all of them the steers were still up and he says i can pull you out with my skid steer kind of chuckled and called a buddy for help. He comes roarin up with his machine 12" axle extensions, tractor tires and chained up , he had picked up a pallet of fence posts for extra weight that thing just squatted and pulled me out like something ive never seen before amazing said it handles 2 ton all the time
Semi Retired too old and fat to wade thru waist deep snow hand choppin anymore
Offline Bruno of NH
« Reply #21 on: March 10, 2020, 08:09:02 AM »
I have an extra set of rims and tires.
My brother in law said we should make up dual wheel set up for mud season  :D
Offline mike_belben
  • Pulp Friction
« Reply #22 on: March 10, 2020, 07:51:39 PM »
2 ton is nothing for a 9 series. That machine is "rated" for 3700 which i believe is 50% of tip load, so 7400lbs tip which means someone good can probably toe walk 4 ton or so. They ride smooth on 2 wheels and dont tear the ground up either.
;D
Revelation 3:20
Offline Stephen1
    • muskoka Sawmill
« Reply #23 on: March 10, 2020, 09:56:32 PM »
Good score, that will go great around the mill.
Offline Bruno of NH
« Reply #24 on: March 11, 2020, 04:53:20 AM »
Belive it or not for such a heavy machine it's light on the ground.
Makes less of a foot print than the 873 I was borrowing.
And the yard is soft.
Offline Bruno of NH
« Reply #25 on: March 11, 2020, 05:01:19 AM »
 I know it's old but if I run it right and take care of it.
I hope it will serve me well.
Offline Stephen1
    • muskoka Sawmill
« Reply #26 on: March 11, 2020, 09:16:03 AM »
I have an older 1993 742 with a mitsubishi propane engine,and it has run 7 years for me. I had to do a head gasket and new radiator, but it just runs and runs. I wish it could lift more.
Offline Bruno of NH
« Reply #27 on: March 12, 2020, 07:55:08 PM »
Using big Bob around the mill yard.
This thing is a beast.
Offline tacks Y
« Reply #28 on: March 12, 2020, 08:04:27 PM »
Must be a keeper if you already named it. Do you like the fork grapple? I am looking at grapple buckets now.
Offline Bruno of NH
« Reply #29 on: March 12, 2020, 08:37:24 PM »
Tacks Y,
Yes I like the fork grapple around the mill yard.
It works good for what I do.
I would also like a root grapple they work great for clean up jobs.
My friend has one.
Offline Banjo picker
« Reply #30 on: March 14, 2020, 06:10:51 PM »
Nice score Bruno.
Offline ehp
  • logger/chainsaw hack
« Reply #31 on: March 14, 2020, 07:13:47 PM »
Bruno that is what I sort on the landing with is a skidsteer , they are fast and quite strong . I got a new S740 yesterday . I have used some of the smaller machines and its surprising on how big of a log they will pick up and move
Offline Bruno of NH
« Reply #32 on: March 15, 2020, 09:08:01 AM »
The only issue so far is my other sae quick attach stuff won't fit the quick attach.
I will have to find someone to make a blank plate then have a sae quick attach welded to it.
I can't find anything all ready built.
Offline Stephen1
    • muskoka Sawmill
« Reply #33 on: March 15, 2020, 12:35:42 PM »
Great name. "Big Bob"
Can you post a pic of the fork grapple and the name of it. I really need one at my bush yard, it is very rough terrain.
Offer made and accepted - Timber Harvester Sawmill
Started by warren46 on Sawmills and Milling
Last post October 04, 2013, 02:52:41 PM
by Magicman
What I made today
Started by wiam on General Board
Last post June 10, 2005, 11:43:41 AM
by Gilman
Made a Little Find Today
Started by DanG on General Board
Last post June 20, 2012, 10:35:47 AM
by Magicman
Made some sawdust today.
Started by fishpharmer on Sawmills and Milling
Last post March 18, 2010, 07:03:08 PM
by James P.
