Dynamic Green Products Inc.
Author Topic: Made an offer on this today (up grades )  (Read 10629 times)
Offline mike_belben
  • Pulp Friction
Re: Made an offer on this today (up grades )
« Reply #160 on: August 27, 2020, 10:51:13 AM »
I dont know the layout on that machine but the hydraulic cooler is probably in series with the filter and if it is above the filter it will drain out.  Maybe 4 or 5 gallons? Have a few clean pails ready.  I used to have a $10 home depot plastic cement pan that was perfect for those jobs
Dont beat yourself up bruno, yer learnin.
Revelation 3:20
Offline Bruno of NH
« Reply #161 on: August 27, 2020, 11:05:01 AM »
One more ?
The air filter doesn't have a inner filter .
Should it ?
When I look on line it comes up without and with .
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline mike_belben
  • Pulp Friction
« Reply #162 on: August 27, 2020, 11:38:34 AM »
Thats hard to say if bobcat made them single or dual.  Does it look like there is space for an inner?  Does the canister have any witness marks from one seated there in the past?
Revelation 3:20
Offline Bruno of NH
« Reply #163 on: August 30, 2020, 01:16:10 PM »
What type of hydraulic fluid should I use in Big Bob?
The cheap 303
Universal tractor fluid
Or other
Offline mike_belben
  • Pulp Friction
« Reply #164 on: August 30, 2020, 01:43:12 PM »
 popcorn_smiley
Revelation 3:20
Offline snowstorm
« Reply #165 on: August 30, 2020, 05:02:19 PM »
The cheap 303
Or other
all depends on how much you like big bob
Offline Bruno of NH
« Reply #166 on: August 30, 2020, 06:23:01 PM »
I like Bob
I'm growing fond of the big fella.
Offline barbender
« Reply #167 on: August 30, 2020, 07:24:44 PM »
I'd run whatever the manual calls for. I'd imagine it's an ISO hydraulic fluid, probably a 46 weight, but I'm just guessing. Don't go with the cheapest you can find. I use the oil from our local bulk supplier, I think it's about $10 a gallon.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #168 on: August 30, 2020, 09:48:13 PM »
I've been running cheap TSC tractor fluid in my 753 for a long time...
Offline Bandmill Bandit
« Reply #169 on: September 02, 2020, 11:53:32 AM »
I started running 15/40 synthetic with a defoamer additive in ALL my industrial hydraulic systems in 1978.
Had an 76, 1840 Uni-loader that blew out 2 pumps and a drive motor before warranty was up. On the last trip to the case dealer for the repair job, Case put in the 15/40 with the defoamer and the rest is history. Traded it up to an 82, 1845 but never turned a bolt on the hydraulics again in almost 5000hrs.
The 1845 is still running at just past 20,000 hrs. Had full tear down rebuild of engine, pumps, motors, rams and bushings at just shy of 17,000 as it was just plain tired and I did an engine refresh at just shy of 9000 before I sold it. Other  than a few hoses and bucket bushing that thing has been a good and reliable little work horse on the farm. Ran 2 more 1845Cs up to 7-8000 ish hrs with the 15/40 mix with narry an issue.
Offer made and accepted - Timber Harvester Sawmill
Started by warren46 on Sawmills and Milling
Last post October 04, 2013, 02:52:41 PM
by Magicman
What I made today
Started by wiam on General Board
Last post June 10, 2005, 11:43:41 AM
by Gilman
Made some sawdust today.
Started by fishpharmer on Sawmills and Milling
Last post March 18, 2010, 07:03:08 PM
by James P.
Made my first payment today
Started by arlostone on Sawmills and Milling
Last post November 29, 2012, 07:34:33 AM
by Meadows Miller
